Cant exclude interface (fw) from Network interface discovery
  • Martin Jørgensen
    • Feb 2020
    • 10
    HI
    I have a simple but strange problem.
    On my Linux Zabbix agent2 i have this output from zabbix_agent2 -p
    net.if.discovery   [s|[{"{#IFNAME}":"lo"},{"{#IFNAME}":"veth104i0"},{"{#IFNAME}":"fwpr112p0"},{"{#IFNAME}":"fwpr113p0"},{"{#IFNAME}":"fwbr103i0"},{"{#IFNAME}":"fwln102i0"},{"{#IFNAME}":"fwln113i0"},{"{#IFNAME}":"vmbr0"}
    My plan is to exclude all interfaces starting with "fw"
    I have done these things
    1. Adding ^fw.* - "Result is false" to global Regular expressions, under "Network interfaces for discovery" - don't work, interfaces is still getting discovered and created on host.
    2. Adding ^fw.* to {$NET.IF.IFNAME.NOT_MATCHES} macro on template - don't work, interfaces is still getting discovered and created on host.
    3. Set ^fw.* To filters under the Network interface discovery rule - don't work, interfaces is still getting discovered and created on host.
    Every time i removed the templates from the host and run zabbix_server -R config_cache_reload, then reapplied the templates.
    Network discovery is set to 5m for testing.
    Running Zabbix server 5 and Agent is Linux Agent2
    On https://regexr.com/
    ^fw.* matches all interfaces starting with fw
    I have the same problem with Interface named tap
  • Archer
    • Nov 2020
Name:	Screenshot from 2020-11-01 18-47-30.png
    try to fix interfaces in macros
    • hh_ph
      • Nov 2020
      • 15
      I'm also working on this and would love a filter or regex answer
      I have attempted the above but it didn't appear to work.
