Cannot parse as a valid JSON object for custom discovery rule
  • Valelinn
    • Feb 2018
    I'm running Zabbix 5.0.2, and I've trying to create a custom discovery rule. I tried a very simple test to see how this works:
    1. I created a discovery rule on a host with key "test.discovery".
    2. From the Zabbix server itself, I run the following command: zabbix_sender -z 127.0.0.1 -s "testhost" -k test.discovery -o {"{#SITENAME}":"test.com"}
    3. However, Zabbix gives me the following error message:
      Invalid discovery rule value: cannot parse as a valid JSON object: invalid object name at: '{#SITENAME}:test.com}'
    I've tried different variations of the JSON value:
    • [{"{#SITENAME}":"test.com"}]
    • "{"{#SITENAME}":"test.com"}"
    • "[{"{#SITENAME}":"test.com"}]"
    but all just return the same result.
    I'm really at a loss here as to what I'm doing wrong. Any assistance would be appreciated.
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Bash strips out your double quotes. In order to be on the safe side always single-quote the while json value:
    zabbix_sender -z 127.0.0.1 -s testhost -k test.discovery -o '[{"{#SITENAME}":"test.com"}]'
    • moora
      • Dec 2021
      I have similiar problem:
      1511:20221105:165212.896 cannot process returned result: cannot parse as a valid JSON object: invalid object format, expected opening character '{' or '[' at: 'OK'
      is there i way to find out in which item the problem is happening?
      I will then use the recommended solutions from you, but the json is so short, I cannot find it
      Thak you
      • markfree
        • Apr 2019
        • 875
        I have an environment with the same issue and I could not find any error in any Discovery rule.
        ffg
        • Markku
          • Sep 2018
          • 1784
          Can you markfree post the JSON here?
          The previous poster had a simple problem: plain string OK is not valid JSON for sure.
          Markku
          • markfree
            • Apr 2019
            • 875
            My issue is exactly like moora's.
            Like him, I cannot find where that string is coming from.
            • Markku
              • Sep 2018
              • 1784
              Can you then show the discovery rule configuration with relevant scripts if present, and the output of the discovery rule key? Note also the preprocessing rules.
              Markku
              • moora
                • Dec 2021
                Markku
                I see the problem in the zabbix log - I have no idea vwhere it is comming from
