how to re-enable timeout'd checks
  • toxicgarden
    • Feb 2015
    I've searched this forum and the whole internet (twice! ) for any solution, but couldn't find one up to now. Here's my situation: i'm running several checks against a machine using external scripts. From time to time, those scripts run into timeouts. That's okay and doesn't show any issue at all, as long as those timeouts are sporadical. But after the first timeout, zabbix (2.2 running on SLES 11SP1) disables those checks completely. When i look under "last data", i only see that the host is completely disabled. Is there anyway to re-enable those checks, even if they ran into timeout once before? I've already set the timeout-value to 30s within the server-config, but just this one script will keep timeouting even if i'd set it to one minute.
