Hostname not changing on frontend
  • Apolymoxic
    • Aug 2020
    Hi all!
    First post here. I have searched, and found similar topics, but none of them helped me.
    I have installed the Zabbix agents on CentOS7. In the config (/etc/zabbix/zabbix_agentd.conf), I changed all that was needed for the host to sync with the server, but changing "Hostname" does not seem to help.
    The original line was "Hostname=Zabbix server"
    I changed this to "Hostname=MyComputer"
    After the agent (re)starts, it does sync up on the front end, but the hostname still shows as "Zabbix server".
    I read on one of the posts here that the agent name had to be under 8 characters? That doesn't make sense to me, but out of curiosity, I tried that, too. It didn't work. So, I tried to use the "HostnameItem" and set it as it's default "HostnameItem=system.hostname" (I did comment out "Hostname="). Still, that did not work.
    Any ideas on what I can do on the host to change the name of the host on the frontend? I do not want to have to configure the hostname on the frontend manually, if at all possible.
    Thank you in advance!
  • isaqueprofeta
    • Aug 2020
    • 154
    It doesn't "sync up" just by using the Zabbix agent. If you want to do something like using the Hostname from zabbix_agentd.conf I advise you to use active agent Auto Registration, you can look up about it here: https://www.zabbix.com/documentation...o_registration
    • Apolymoxic
      • Aug 2020
      My apologies, I should have said that I have auto-registration setup (I believe).
      I install the agent, configure it, and then start the agent, and poof - it appears on the front end.
      But, I probably have something messed up, because I have just noticed that out of the three hosts configured this way, they all have the same interface (172.26.65.72:10050). That can't be right, can it?
      • Apolymoxic
        • Aug 2020
        Well, I figured it out. I had fat fingered the PSK and it wasn't registering with TLS. I figured it wouldn't register at all, but it did.
        Oh well.
        Thank you!
        • isaqueprofeta
          • Aug 2020
          • 154
          No problem! Great that you figured it out!
