Zabbix server mysql connection issue
  • niteen
    • Feb 2015
    I have installed Zabbix on centos6 system...But it have issue with mysql database connectivity....It starts with following information....
    2196:20150225:120012.901 Cannot connect to the database. Exiting...
    603:20150225:120013.077 Starting Zabbix Server. Zabbix 2.0.13 (revision 48919). 603:20150225:120013.079 ****** Enabled features ****** 603:20150225:120013.079 SNMP monitoring: YES 603:20150225:120013.079 IPMI monitoring: YES
    603:20150225:120013.079 WEB monitoring: YES
    603:20150225:120013.079 Jabber notifications: YES
    603:20150225:120013.079 Ez Texting notifications: YES
    603:20150225:120013.079 ODBC: YES
    603:20150225:120013.079 SSH2 support: YES
    603:20150225:120013.079 IPv6 support: YES
    603:20150225:120013.079 ******************************
    603:20150225:120013.081 [Z3001] connection to database 'zabbix' failed: [0] received invalid response to SSL negotiation: J
    but fail with mysql connection issue...
    32196:20150225:115544.414 Database is down. Reconnecting in 10 seconds. 32196:20150225:115554.415 [Z3001] connection to database 'zabbix' failed: [0] received invalid response to SSL negotiation: J
    Mysql have_ssl setting is disabled in mysql database....
  • kloczek
    • Jun 2006
    • 1771
    AFAIK zabbix server and web frondend does not support using SSL with mysql DB backend.
