I recently noticed that the data that is being recorded in the DB and showing in Latest Data is not correct. I ran an SNMP walk on the device and saw the raw data for a particular OID number. Then I checked the OID under the Host Item and the OID was correct. Since we have upgraded to Version 5.0 there is a "Test" button on the bottom of the Item configuration page. I decided to test the item and it showed the correct values and compared them to the SNMP walk that I preformed. So I am lost as to why in the Test Zabbix is able to pull the right data but when storing it and showing in latest data it is correct. Here is some screen shots showing what I am talking about.
I have also uploaded a screen shot of the full item configuration showing everything.
We are using SNMPv3 and that has not effect any other device that we use this with.
The issues only seem to be with certain items and not all the items for the switches that we are monitoring.
I will be grateful for any insight that you can provide. Thank you.
