Information that host is OK - no active alarms
  • sabat
    • Aug 2018
    • 13
    Hello, I need to display on my dashboard that specific host is OK - no active alarms (triggers). How to do that?
  • isaqueprofeta
    • Aug 2020
    • 154
    I'd try to use "Problem hosts" Widget in Dashboard, or use a Map.
    If you want to try you can go with a Grafana Dashboard using Stats Panel.
    • igorj
      • Jul 2020
      There is a widget, at least on 5.0.1 called "Problem hosts", you can select there what you want to have in it as mentioned above
      • Hamardaban
        • May 2019
        • 2713
        You can also display a map with an icon corresponding to the network node. When there are no problems with this node, we see the green OK. If there are problems (triggered triggers), the image may change. For more information, see the documentation https://www.zabbix.com/documentation...ation/maps/map
        • sabat
          • Aug 2018
          • 13
          This is something what I wanted but not totally. How can I have status OK / NOK of Host/Host Group placed on dashboard or screen section?
          • dimir
            Zabbix developer
            • Apr 2011
            • 1080
            Will Problems by severity dashboard widget work for you?
