Failed to start zabbix server
  • sandyrondonc
    • Sep 2020
    I have the following problem to start zabbix server at first time
    OS: Ubuntu 20.04 DB:Mysql
    -- Support: http://www.ubuntu.com/support
    -- A start job for unit zabbix-server.service has begun execution.
    -- The job identifier is 54545.
    set 09 13:33:31 soporte-VirtualBox zabbix_server[76816]: zabbix_server [76816]>
    set 09 13:33:31 soporte-VirtualBox systemd[1]: zabbix-server.service: Control >
    -- Subject: Unit process exited
    -- Defined-By: systemd
    -- An ExecStart= process belonging to unit zabbix-server.service has exited.
    -- The process' exit code is 'exited' and its exit status is 1.
    set 09 13:33:31 soporte-VirtualBox systemd[1]: zabbix-server.service: Failed w>
    -- Subject: Unit failed
    -- The unit zabbix-server.service has entered the 'failed' state with result '>
    set 09 13:33:31 soporte-VirtualBox systemd[1]: Failed to start Zabbix Server.
    -- Subject: A start job for unit zabbix-server.service has failed
    -- A start job for unit zabbix-server.service has finished with a failure.
    -- The job identifier is 54545 and the job result is failed.
    lines 6341-6368/6368 (END)
  • tim.mooney
    • Dec 2012
    • 1434
    That just tells us that there was an error. It doesn't give us any information about what the error might be. It also looks like some of the messages may have been cut off.
    Try using the "-l" (for "long output") with the 'systemctl status' command and the service name(s) for the services in question, to see if there's more information about what the source of the problem is.
