Cannot find hosts beyond 1000 under Configuration -> Host menu?
  • caixianghua
    • Jan 2015
    My current Zabbix environment contains about 1600+ hosts.
    Some of administrators disabled several hosts. However, it is very hard to find which hosts had been disabled.
    So I decided to find them in the Configuration -> Host menu.
    However, I find that when the amount of hosts reach 1000+, I cannot find other hosts beyond 1000.
    Is there any workaround except I search the not-monitored hosts from each host group?
  • gleepwurp
    • Mar 2014
    • 119
    which Zabbix version are you using?
    I'm using Zabbix 2.4.4 and I have no such issues (See Attached Image)
    G.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Have a look at Administration->General->GUI. There is a parameter called "Search/Filter elements limit" which can be increased if you feel so.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • caixianghua
        • Jan 2015
        Yes, the problem has been resolved according to your suggestion.
        Thanks a lot!
