orabbix-1.2.3 on Zabbix 2.4.1 (ERROR on main - Connections is empty)
  • izn0g00d
    • Mar 2015
    • 16
    Hello All,
    I have downloaded the suse vm for zabbix and it works great. However, I am facing issues trying to install orabbix-1.2.3 on Zabbix 2.4.1. I have placed the orabbix on the same server as the zabbix server.
    My java version is :
    java version "1.7.0_75"
    Java(TM) SE Runtime Environment (build 1.7.0_75-b13)
    Java HotSpot(TM) 64-Bit Server VM (build 24.75-b04, mixed mode)
    executing run.sh error -->
    ./run.sh
    linux-qvvt:/opt/orabbix # Stopping
    java.lang.Exception: ERROR on main - Connections is empty
    at com.smartmarmot.orabbix.Orabbixmon.run(Orabbixmon. java:101)
    at com.smartmarmot.orabbix.bootstrap.main(bootstrap.j ava:50)
    errors in the error log -- >
    cat orabbix.log
    2015-03-12 23:04:43,569 [main] INFO Orabbix - Starting Orabbix Version 1.2.3
    2015-03-12 23:04:44,281 [main] INFO Orabbix - Orabbix started with pid:20444
    2015-03-12 23:04:44,281 [main] INFO Orabbix - PidFile -> ./logs/orabbix.pid
    2015-03-12 23:04:44,475 [main] INFO Orabbix - DB Pool created: org.apache.commons.dbcp.datasources.SharedPoolData Source@59887d29
    2015-03-12 23:04:44,475 [main] INFO Orabbix - URL=jdbcracle:thin:@192.168.1.26:1521rcl
    2015-03-12 23:04:44,475 [main] INFO Orabbix - maxPoolSize=10
    2015-03-12 23:04:44,475 [main] INFO Orabbix - maxIdleSize=1
    2015-03-12 23:04:44,475 [main] INFO Orabbix - maxIdleTime=1800000ms
    2015-03-12 23:04:44,475 [main] INFO Orabbix - poolTimeout=100
    2015-03-12 23:04:44,475 [main] INFO Orabbix - timeBetweenEvictionRunsMillis=-1
    2015-03-12 23:04:44,475 [main] INFO Orabbix - numTestsPerEvictionRun=3
    2015-03-12 23:04:44,578 [main] ERROR Orabbix - Error on Configurator for database orcl -->IO Error: The Network Adapter could not establish the connection
    2015-03-12 23:04:44,579 [main] INFO Orabbix - This Database orcl removed
    2015-03-12 23:04:44,579 [main] ERROR Orabbix - ERROR on main - Connections is empty
    config.props -->
    #comma separed list of Zabbix servers
    ZabbixServerList=linux-qvvt
    ZabbixServer1.Address=192.168.1.6
    ZabbixServer1.Port=10051
    #pidFile
    OrabbixDaemon.PidFile=./logs/orabbix.pid
    #frequency of item's refresh
    OrabbixDaemon.Sleep=300
    #MaxThreadNumber should be >= than the number of your databases
    OrabbixDaemon.MaxThreadNumber=100
    #put here your databases in a comma separated list
    DatabaseList = orcl
    #Configuration of Connection pool
    #if not specified Orabbis is going to use default values (hardcoded)
    #Maximum number of active connection inside pool
    DatabaseList.MaxActive=10
    #The maximum number of milliseconds that the pool will wait
    #(when there are no available connections) for a connection to be returned
    #before throwing an exception, or <= 0 to wait indefinitely.
    DatabaseList.MaxWait=100
    DatabaseList.MaxIdle=1
    #define here your connection string for each database
    orcl.Url=jdbcracle:thin:@192.168.1.26:1521rcl
    orcl.User=zabbix
    orcl.Password=zabbix
    #Those values are optionals if not specified Orabbix is going to use the general values
    orcl.MaxActive=10
    orcl.MaxWait=100
    orcl.MaxIdle=1
    orcl.QueryListFile=./conf/query.props
    I have tried on Ubuntu, suse and windows and they all produce the same error.
    zabbix-server(OS)| Agent(OS) |Database Version
    Ubuntu | solaris 10 | 9i
    Suse | windows 7 | 11g
    The steps i have followed are from the orabbix website.
    Kindly extend your help.
    Regards,
    izn0g00d
  • izn0g00d
    • Mar 2015
    • 16
    anyone encountered this issue?
    • izn0g00d
      • Mar 2015
      • 16
      trying to keep this thread on top....
      • OriginNG
        • Dec 2014
        • 15
        I don't know how good you knowledge about oracle is but I think you're having problems with a firewall between you orabix install and the server.
        Try is you can install an oracle client on you suse/orabix server (instantclient is the easiest), then try to connect from sqlplus to your database server. I think this won't work either because of the firewall. The problem with oracle is that the client connects to port 1521 on the database server (listener) which will validate the servicename/sid and the client will get back a random high numbered port which it will use to do its work. The last step is where most firewalls will block your client because you can't know on beforehand what port the client is going to use. For that to work you'll need a firewall with app support.
        Regards,
        Joop
        • izn0g00d
          • Mar 2015
          • 16
          Hello OriginNG,
          I have tested with sqlplus:
          sqlplus "zabbix/zabbix@(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=1 72.17.58.220)(PORT=1521))(CONNECT_DATA=(SID=XXX))) "
          and am able to get a connection....
          but still same error when i execute ./run.sh
          • OriginNG
            • Dec 2014
            • 15
            Originally posted by izn0g00d
            Hello OriginNG,
            You're connecting to database server @ 172.17.58.220 but in you're config for orabix you're having a 192 address.
            • izn0g00d
              • Mar 2015
              • 16
              I was trying to obfuscate my post with the 192 address..
              Good news the problem is solve with the connection. There was a space at the end of the database name(SID ) ...
              Now am strugling with the empty graphs..
              loving the trouble shooting
              • alusvedejs
                • Jul 2011
                • 11
                how did you solve the connection problem?
                Hi everyone
                i am hitting similar problem
                i have zabbix server 2.4.0 with orabbix 1.2.3
                when i try to start orabbix it cannot connect to my databases.
                and when this happens database throw ORA-3136 in alert log:
                TNS-12535: TNSperation timed out
                ns secondary err code: 12606
                nt main err code: 0
                nt secondary err code: 0
                nt OS err code: 0
                Client address: (ADDRESS=(PROTOCOL=tcp)(HOST=hostname)(PORT=35281) )
                WARNING: inbound connection timed out (ORA-3136)
                how to work this around?
                the problem is with orabbix because i try to connect to 3 different databases on different servers. even different database versions and platforms.
                all of them write ORA-3136 in alert log when i try to start orabbix.
                and the orabbix shuts down with
                i am wondering about (PORT=35281) in alert log. where do that comes from because database is listening and i am connecting to port 1521?
                • izn0g00d
                  • Mar 2015
                  • 16
                  My issue was due to the fact that the SID had a space at the end [ORCL _ ] which i couldnt see
                  • alusvedejs
                    • Jul 2011
                    • 11
                    any other suggestions?
                    anyone?
                    • alusvedejs
                      • Jul 2011
                      • 11
                      forget it
                      i found the solution.
                      i lost 3 days becauce "hostname" returned different value than was in my "/etc/hosts" on zabbix/orabbix server
                      • izn0g00d
                        • Mar 2015
                        • 16
                        I would suggest you try with the suze vm first
                        • syman888
                          • Jul 2022
                          • 12
                          Originally posted by alusvedejs
                          forget it
                          Excuse me
                          Can you please explain the solution in detail? I also met the same problem, thank you.​
