zabbix_server 4.4.10 Crashing...
  • yzcfan
    • Sep 2020
    I have a zabbix server running v2.4.8, I upgrade it to v4.4.10. My upgrade method is using old MySQL DB, but the zabbix_server daemon (v4.4.10) is installed in a new server which is running a CentOS 7.8.
    After upgrade successfully, zabbix_server running normally for about 1day, then I got a Crashing.
    Here's the logs
    21732:20200919:084557.811 error reason for "AMZ-SIN-YMTrack-10-15:zagent.http.get['http://127.0.0.1:8080/ok', vn_check, 'trace-profile|time_elapsed']" changed: Value "" of type "string" is not suitable for value type "Numeric (unsigned)"
    21729:20200919:084559.248 error reason for "AMZ-SIN-YMTrack-10-15:zagent.http.get['http://127.0.0.1:8080/ok', vn_check, 'conv-profile|time_elapsed']" changed: Value "" of type "string" is not suitable for value type "Numeric (unsigned)"
    21724:20200919:084738.712 Got signal [signal:11(SIGSEGV),reason:1,refaddr:([IMG]https://www.zabbix.com/forum/core/image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==[/IMG]​nil)]. Crashing ...
    21724:20200919:084738.712 ====== Fatal information: ======
    21724:20200919:084738.712 Program counter: 0x558838145045
    21724:20200919:084738.712 === Registers: ===
    21724:20200919:084738.712 r8 = 7f025594c060 = 139648002474080 = 139648002474080
    21724:20200919:084738.712 r9 = 5588390b7125 = 94043560964389 = 94043560964389
    21724:20200919:084738.712 r10 = 2 = 2 = 2
    21724:20200919:084738.712 r11 = 0 = 0 = 0
    21724:20200919:084738.712 r12 = 558838245c17 = 94043545820183 = 94043545820183
    21724:20200919:084738.712 r13 = 1 = 1 = 1
    21724:20200919:084738.712 r14 = 0 = 0 = 0
    21724:20200919:084738.712 r15 = 0 = 0 = 0
    21724:20200919:084738.712 rdi = 1999999999999999 = 1844674407370955161 = 1844674407370955161
    21724:20200919:084738.712 rsi = 0 = 0 = 0
    21724:20200919:084738.712 rbp = 7ffe607b02c0 = 140730517095104 = 140730517095104
    21724:20200919:084738.712 rbx = 3c = 60 = 60
    21724:20200919:084738.712 rdx = a = 10 = 10
    21724:20200919:084738.712 rax = 0 = 0 = 0
    21724:20200919:084738.712 rcx = 0 = 0 = 0
    21724:20200919:084738.712 rsp = 7ffe607b0190 = 140730517094800 = 140730517094800
    21724:20200919:084738.712 rip = 558838145045 = 94043544768581 = 94043544768581
    21724:20200919:084738.712 efl = 10202 = 66050 = 66050
    21724:20200919:084738.712 csgsfs = 33 = 51 = 51
    21724:20200919:084738.712 err = 4 = 4 = 4
    21724:20200919:084738.712 trapno = e = 14 = 14
    21724:20200919:084738.712 oldmask = 0 = 0 = 0
    21724:20200919:084738.712 cr2 = 0 = 0 = 0
    21724:20200919:084738.712 === Backtrace: ===
    21724:20200919:084738.713 12: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 4.576468 sec, syncing configuration](zbx_backtrace+0x42) [0x55883817e77c]
    21724:20200919:084738.713 11: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 4.576468 sec, syncing configuration](zbx_log_fatal_info+0x151) [0x55883817e9fa]
    21724:20200919:084738.713 10: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 4.576468 sec, syncing configuration](+0x1a9d92) [0x55883817ed92]
    21724:20200919:084738.713 9: /lib64/libpthread.so.0(+0xf630) [0x7f0258713630]
    21724:20200919:084738.713 8: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 4.576468 sec, syncing configuration](+0x170045) [0x558838145045]
    21724:20200919:084738.713 7: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 4.576468 sec, syncing configuration](DCsync_configuration+0x8a2) [0x55883814e452]
    21724:20200919:084738.713 6: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 4.576468 sec, syncing configuration](dbconfig_thread+0x202) [0x5588380248fa]
    21724:20200919:084738.713 5: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 4.576468 sec, syncing configuration](zbx_thread_start+0x37) [0x55883818c1ff]
    21724:20200919:084738.713 4: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 4.576468 sec, syncing configuration](MAIN_ZABBIX_ENTRY+0x9b1) [0x558838017488]
    21724:20200919:084738.713 3: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 4.576468 sec, syncing configuration](daemon_start+0x305) [0x55883817dfe5]
    21724:20200919:084738.713 2: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 4.576468 sec, syncing configuration](main+0x312) [0x558838016ad5]
    21724:20200919:084738.713 1: /lib64/libc.so.6(__libc_start_main+0xf5) [0x7f02555a6555]
    21724:20200919:084738.713 0: /usr/sbin/zabbix_server: configuration syncer [synced configuration in 4.576468 sec, syncing configuration](+0x40b69) [0x558838015b69]
    21724:20200919:084738.713 === Memory map: ===
    21724:20200919:084738.713 558837fd5000-5588382c8000 r-xp 00000000 fd:01 673494 /usr/sbin/zabbix_server_mysql
    21724:20200919:084738.713 5588384c7000-558838536000 r--p 002f2000 fd:01 673494 /usr/sbin/zabbix_server_mysql
    21724:20200919:084738.713 558838536000-558838541000 rw-p 00361000 fd:01 673494 /usr/sbin/zabbix_server_mysql
    21724:20200919:084738.713 558838541000-55883854b000 rw-p 00000000 00:00 0
    21724:20200919:084738.713 558839088000-5588390a9000 rw-p 00000000 00:00 0 [heap]
    21724:20200919:084738.713 5588390a9000-5588390d6000 rw-p 00000000 00:00 0 [heap]
    21724:20200919:084738.713 5588390d6000-55883916e000 rw-p 00000000 00:00 0 [heap]
    21724:20200919:084738.713 7f0244000000-7f0244021000 rw-p 00000000 00:00 0
    21724:20200919:084738.713 7f0244021000-7f0248000000 ---p 00000000 00:00 0
    21724:20200919:084738.713 7f024b3be000-7f024b3c4000 r-xp 00000000 fd:01 658672 /usr/lib64/libnss_dns-2.17.so
    21724:20200919:084738.713 7f024b3c4000-7f024b5c3000 ---p 00006000 fd:01 658672 /usr/lib64/libnss_dns-2.17.so
    21724:20200919:084738.713 7f024b5c3000-7f024b5c4000 r--p 00005000 fd:01 658672 /usr/lib64/libnss_dns-2.17.so
    21724:20200919:084738.713 7f024b5c4000-7f024b5c5000 rw-p 00006000 fd:01 658672 /usr/lib64/libnss_dns-2.17.so
    21724:20200919:084738.713 7f024b5c5000-7f024b5c6000 ---p 00000000 00:00 0
    21724:20200919:084738.716 7ffe60792000-7ffe607b3000 rw-p 00000000 00:00 0 [stack]
    21724:20200919:084738.716 7ffe607fb000-7ffe607fd000 r-xp 00000000 00:00 0 [vdso]
    21724:20200919:084738.716 ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
    21724:20200919:084738.716 ================================
    21724:20200919:084738.716 Please consider attaching a disassembly listing to your bug report.
    21724:20200919:084738.716 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
    21722:20200919:084738.717 One child process died (PID:21724,exitcode/signal:1). Exiting ...
    zabbix_server [21722]: Error waiting for process with PID 21724: [10] No child processes
    21722:20200919:084738.737 syncing trend data...
    21722:20200919:084738.791 syncing trend data done
    21722:20200919:084738.791 Zabbix Server stopped. Zabbix 4.4.10 (revision 4db30afc70).
