"SQL statement execution has failed" at login screen.
  • alex_vy
    • Apr 2020
    Hi all,
    My Zabbix VM (Ubuntu/MySQL/apache) had a full hard drive recently, which caused MySQLd to stop, and of course the whole Zabbix environment.
    I cleared some data to start it again, so I could do some cleanup from the inside.
    Unfortunately, now I'm confronted with the following issue when trying to log in:
    SQL statement execution has failed "INSERT INTO sessions (sessionid,userid,lastaccess,status) VALUES ('45638099965b4f61de9965a66673cc3e','10','1600874767','0')".
Name:	Schermafbeelding 2020-09-23 om 17.26.25.png
    Something obviously went wrong with the database.
    Does anyone know what steps I could take to fix this issue?
    Many thanks in advance,
    Alex
  • Atsushi
    • Aug 2013
    • 2028
    Do you allow the database connection user permission to update the database for Zabbix?
    ex.
    mysql> grant all privileges on zabbix.* to zabbix@localhost;
    Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
    • alex_vy
      • Apr 2020
      ex.
      I tried this now, but I'm still faced with the same error when trying to login as the admin.
      When I try to login as an LDAP user, I get the following error:
      [LIST][*]SQL statement execution has failed "INSERT INTO sessions (sessionid,userid,lastaccess,status) VALUES ('9afa2e92d9cf16b32a5ea191952b70d8','10','16009380 26','0')".[/LIST]
Name:	Screen Shot 2020-09-24 at 11.00.34.png
      I'm unsure what is going on with the database. Any troubleshooting idea's to figure this out?
      Kind regards,
      Alex
      • provels
        • Apr 2020
        • 93
        I think I had a similar issue after running out of disk space.
        Take a look at this thread. https://www.zabbix.com/forum/zabbix-...ory Scroll down to Post #10.
        In short, you need to:
        1. Increase the disk space available to the VM.
        2. Create a new partition in the available space.
        3. Add the new partition to the existing volume.
        4. Extend the file system over the extended volume.
        Hope this helps.
        • alex_vy
          • Apr 2020
          Hope this helps.
          Hi Provels,
          Yes, this was part of the solution. I the meantime I've managed to add the partition to the volume, so space is fine.
          The issue itself however was an extra line I added to mySQL's conf file previously. After deleting this, all is back to normal.
          Thanks for the help!
          Alex
          • tashihyolmo01
            tashihyolmo01 commented
            Hi alex
            Can you please elaborate the solution.
            how did u exactly do to solve the problem?
            regards;
