Another Housekeeper optimization post. This time for 5.x! :-D
  • cstackpole
    • Oct 2006
    • 225
    Greetings,
    I'm having issues with my housekeeper getting the well known "processes more than 75% busy" alerts. I should probably start looking at migrating my MySQL into partitions with the amount of data Zabbix is injesting but I'm hoping to spend some time tweaking Housekeeper first to see if that helps. Unfortunately, a LOT of the information I'm finding is pretty old. I'm on Zabbix 5.0.2 and some of the suggestions that are top hits on a popular search engine I know for certain are no longer applicable fixes for newer Zabbix releases.
    So I'm hoping to start a new thread that Zabbix 5.x installations might be able to use. What are some of the first things to start looking at and tweaking for better housekeeper optimizations?
    Here's what I'm seeing.
    25003:20200928:083508.353 executing housekeeper
    25003:20200928:094555.083 housekeeper [deleted 672790 hist/trends, 3552779 items/triggers, 0 events, 4 problems, 0 sessions, 0 alarms, 0 audit, 0 records in 4246.722568 sec, idle for 1 hour(s)]
    25003:20200928:104558.790 executing housekeeper
    25003:20200928:114626.005 housekeeper [deleted 671358 hist/trends, 2610440 items/triggers, 0 events, 3 problems, 0 sessions, 0 alarms, 0 audit, 0 records in 3627.214430 sec, idle for 1 hour(s)]
    25003:20200928:124630.019 executing housekeeper
    25003:20200928:135021.344 housekeeper [deleted 618734 hist/trends, 2600000 items/triggers, 0 events, 2 problems, 0 sessions, 0 alarms, 0 audit, 0 records in 3831.323302 sec, idle for 1 hour(s)]
    Here is a manual run so that I could ensure plenty of pretty graphs.
    4526:20200928:153535.199 forced execution of the housekeeper
    4526:20200928:153535.200 executing housekeeper
    4526:20200928:163928.022 housekeeper [deleted 282963 hist/trends, 2600000 items/triggers, 0 events, 3 problems, 0 sessions, 0 alarms, 0 audit, 0 records in 3832.819007 sec, idle for 1 hour(s)]
    I've posted an image of the Zabbix server's utilization of housekeeper internal processes and the graph dump of the sql server which has the MySQL Zabbix template. The last time I had a housekeeper issue, it ended up clearly being a SQL issue, but this time theres no immediate red flags for me there.
    Any suggestions on how admins tune HouseKeeper for Zabbix 5.x?
    Thanks!
