Zabbix Vmware No Latest Data, Error: URL using bad/illegal format or missing URL
  • XimingFeng
    • Sep 2020
    I am tyring to setup Zabbix server to monitor my vsphere environment.
    I followed this tutorial https://bestmonitoringtools.com/vmwa...er-vm-vsphere/
    Create a user in the Administrators group. Enable VMWare Collector
    StartVMwareCollectors=3
    VMwareFrequency=60
    VMwarePerfFrequency=60
    VMwareCacheSize=32M
    VMwareTimeout=120
    Next
    sudo systemctl restart zabbix-server
    Then I added the host (my vcenter server) using the account credential I just created in Macros with template "Template VM VMware"
    After long time I am still getting nothing from the latest data and plus in the server log there is "URL using bad/illegal format or missing URL" error
  • ZaBeast
    • Sep 2019
    • 42
    Since the Zabbix 5.0 version, VMware templates are using macros {$VMWARE.URL}, {$VMWARE.USERNAME}, and {$VMWARE.PASSWORD} that are configured on the template “Template VM VMware macros”. Make sure that those macros are configured correctly - more info
    • uwillc
      • Mar 2021
      It seems that you have wrong configuration for your vSphere/ESXi in the macros section... make sure that you configured URL properly as https://IP_OR_FQDN/sdk
      • webrunner
        • May 2022
        See this: https://kb.vmware.com/s/article/1003218
        So it should be: https://IP_OR_FQDN/sdk/vimService.wsdl
        • hai.dao
          • Jun 2022
          • 19
          i have same issue & i detected my reason is template vmware guest (6.4) not automatic add macro value.
          You must to complete macros value of this template , i mean you must to check macro value again.
