Zabbix server crashes while logrt checking
  • valerie gurshman
    • Mar 2015
    • 11
    I create new item to check alert.log of oracle database and monitor ORA- errors.
    the item should monitor specific error:
    logrt["C:\Oracle\diag\rdbms\jda74\jda74\trace\alert_jda7 4.log","ORA-00600",UTF-8,10,skip]
    after creating a trigger , the server started to crash.
    the error :
    9294:20150319:131043.008 Got signal [signal:11(SIGSEGV),reason:1,refaddrnil)]. Crashing ...
    9294:20150319:131043.008 ====== Fatal information: ======
    9294:20150319:131043.008 Program counter: 0x30ff5378b6
    9294:20150319:131043.026 ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
    9294:20150319:131043.026 ================================
    9294:20150319:131043.026 Please consider attaching a disassembly listing to your bug report.
    9294:20150319:131043.026 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
    9151:20150319:131043.028 One child process died (PID:9294,exitcode/signal:255). Exiting ...
    9151:20150319:131045.029 syncing history data...
    9151:20150319:131045.029 syncing history data done
    9151:20150319:131045.029 syncing trends data...
    9151:20150319:131045.173 syncing trends data done
    9151:20150319:131045.174 Zabbix Server stopped. Zabbix 2.2.3 (revision 44105).
    please help
