After update to Zabbix 5.0 custom script starts sent 503 error
  • Gutsycat
    • Nov 2017
    • 72
    Zabbix 4.4 and script works fine.
    After update to Zabbix 5.0 I receive 503 Server Error: Service Unavailable for url: http://<zabbix-ip-address>/zabbix/api_jsonrpc.php
    I set request_terminate_timeout = 1d but this does not help.
    Any help, please.
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Did you install frontend from packages?
    • gcalenko
      Zabbix developer
      • Mar 2017
      • 27
      Can you please check does the frontend working? Looks like it is misconfiguration of web server.
      • Gutsycat
        • Nov 2017
        • 72
        Yes.
        Frontend works but sometimes when I try to view Latest data I have the same 503 Error code.
        Seems I need to configure some timeout variable but I do not know which one.
        • gcalenko
          Zabbix developer
          • Mar 2017
          • 27
          Zabbix requires to php.ini variable "max_execution_time" to be set not less as 5 minutes, if you receive 503 error in less time then you probably should configure your web server timeout. What web server do you use?
          • Gutsycat
            • Nov 2017
            • 72
            I'm using Apache2 with CentOS 7
