zabbix install dependencies 5.0.4
  • darfie21
    • May 2015
    I'm trying to a fresh install of zabbix 5.0 on centos 8. When I attempt to install package zabbix-web-mysql-5.0.4-1.el8.noarch.rpm I get this error:
    [root@zabbix ~]# rpm -iv zabbix-web-mysql-5.0.4-1.el8.noarch.rpm
    warning: zabbix-web-mysql-5.0.4-1.el8.noarch.rpm: Header V4 RSA/SHA512 Signature, key ID a14fe591: NOKEY
    error: Failed dependencies:
    zabbix-web-deps = 5.0.4-1.el8 is needed by zabbix-web-mysql-5.0.4-1.el8.noarch
    When I try to install the dependency zabbix-web-deps I get this error:
    # rpm -iv zabbix-web-deps-5.0.4-1.el8.x86_64.rpm
    warning: zabbix-web-deps-5.0.4-1.el8.x86_64.rpm: Header V4 RSA/SHA512 Signature, key ID a14fe591: NOKEY
    zabbix-web-database = 5.0.4-1.el8 is needed by zabbix-web-deps-5.0.4-1.el8.x86_64
    I cant install either package as they seem to be asking for each other. What am I doing wrong ?
    I currently have these package installed:
    zabbix-server-mysql-5.0.4-1.el8.x86_64
    zabbix-web-5.0.4-1.el8.noarch
  • tim.mooney
    • Dec 2012
    • 1430
    Don't use rpm directly. Use yum or dnf.
    Install them in a single transaction, rather than one by one.
    • ZaBeast
      • Sep 2019
      • 42
      Are you using the official Zabbix installation guide?
      You can this guide: https://bestmonitoringtools.com/how-...entos-or-rhel/
      It has more details and information.
      • Atsushi
        • Aug 2013
        • 2028
        I also recommend using the official repositories and using the dnf command to install.
        When installing dependent packages with the rpm command, try to install the dependent packages side by side as arguments.
        ex.
        # rpm -iv zabbix-web-mysql-5.0.4-1.el8.noarch.rpm zabbix-web-deps-5.0.4-1.el8.x86_64.rpm
