Access denied for user 'replace_user'@'localhost' (using password: YES)
  • patsonbass
    • Oct 2020
    I am new in ZABBIX, I downloaded and installed a ZABBIX appliance, today.
    I tried to launch the web application, but i encounter this error message: Access denied for user 'replace_user'@'localhost' (using password: YES).
    Please can you help?
    Kind Regards,
  • gurulee
    • Jan 2021
    I have the same problem after just downloading zabbix_appliance-5.2.4-qcow2.tar and importing it into my KVM. At first boot I go to the webUI and I get the error:
    • Jun.Liu
      • Apr 2007
      • 91
      I met the same problem when importing a zabbix appliance to KVM. after some investigation, it looked like some information and data are missing in zabbix configuration and database. I resolved the problem with the below steps
      1. stop the zabbix server with the command 'systemctl stop zabbix-server'.
      2. modify the `/etc/zabbix/zabbix_server.conf`, change the 'DBUser' to 'zabbix_srv' and 'DBPassword' to your selected.
      3. modify the `/etc/zabbix/web/zabbix.conf.php`, change the `$DB['USER']` to 'zabbix_web', and `$DB['PASSWORD']` to your selected.
      4. login the MySQL and alter both users zabbix_srv and zabbix_web's password to your selected.
      5. start the zabbix server with command: `systemctl start zabbix-server`.
      The problem should be solved if everything goes well. but if you encountered the below error msg in the zabbix_server.log as I did:
      1656:20210314:045850.835 cannot use database "zabbix": its "users" table is empty (is this the Zabbix proxy database?)
      that means some data are missed in the 'users' table of the zabbix db. You should drop zabbix database, create it again and populate it with the DB script according to the zabbix documents.
      after the above steps. my problem was solved. hope it can help.
      • Hasabadusa23
        • Dec 2023
        • 11
        Thank you very much for this information. Its terrible that zabbix is not writing this in the user manual...
        The zabbix installation, is it Appliance or anything else is always a pain in the ass and the use of google for 8 hours till every error is gone which could have been fixed if they would EVER test the appliances and tutorials they write...
        I'm stuck right now here after I did the changes u recommended:
        zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid
        1389:20240116:145349.567 using configuration file: /etc/zabbix/zabbix_server.conf
        1389:20240116:145349.577 cannot use database "zabbix": its "users" table is empty (is this the Zabbix proxy database?)​
        Why ? why do I use an appliance where I expect everything is working and I have to maybe re-initialise the database with the script ?
        • Hasabadusa23
          • Dec 2023
          • 11
          I dropped the zabbix db, created a new zabbix db and then reinitialised the database with
          zcat /usr/share/zabbix-sql-scripts/mysql/server.sql.gz | mysql --default-character-set=utf8mb4 -uzabbix_srv -p zabbix
          Now it's working.
          Please Zabbix Team add this to your tutorial.
          • Hasabadusa23
            • Dec 2023
            • 11
            The next error (OF COURSE there are more errors on this appliance...) is the message at the webinterface system information:
            zabbix Unsupported charset or collation for tables
            So you also need to fix this with this tutorial:
            https://www.zabbix.com/documentation...b_charset_coll
            OF OCURSE it is not working completly because it doesnt change the charset or collation for the tables but JUST for the database...
            So you need to convert the collation for every table.
            The command
            SELECT CONCAT('ALTER TABLE ',TABLE_SCHEMA,'.',TABLE_NAME,' CONVERT TO CHARACTER SET utf8mb4 COLLATE utf8mb4_bin;') AS alter_sql FROM information_schema.tables WHERE table_schema = 'zabbix';
            is showing you changes, but OF COURSE it is not working...
            So I needed to write a script with chatgpt that alters every table step by step
            #!/bin/bash
            # Verbindungsparameter für MySQL
            MYSQL_USER="USERNAME"
            MYSQL_PASSWORD="PASSWORD"
            MYSQL_DATABASE="zabbix"
            # SQL-Abfrage, um die 'ALTER TABLE'-Anweisungen zu generieren
            SQL_QUERY=$(mysql -u$MYSQL_USER -p$MYSQL_PASSWORD -Nse "SELECT CONCAT('ALTER TABLE ', table_name, ' CONVERT TO CHARACTER SET utf8mb4 COLLATE utf8mb4_bin;') FROM information_schema.tables WHERE table_schema = '$MYSQL_DATABASE';")
            # Ausführung der generierten 'ALTER TABLE'-Anweisungen
            echo "$SQL_QUERY" | mysql -u$MYSQL_USER -p$MYSQL_PASSWORD $MYSQL_DATABASE
            • Hasabadusa23
              • Dec 2023
              • 11
              Oh and for the next error with the numeric values you need to do this
              My config file was here
              not sure what you mean with
              /ui/conf/zabbix.conf.php
              Never saw a directory with the name "ui"
            • Armaro
              • Jan 2024
              I followed this recipe:
              Let's learn how to install the zabbix server already configured and ready for use with the zabbix appliance on VirtualBox.
              Got the same error, googled it and ended up here, quickly realized that something banally simple was the reason for the error message.
              Deleted the virtual machine and restarted with a clean slate.
              Followed the write-up this time and then it worked!
              The problem was that I was a bit too quick to log in to the web interface, first log in to the console then the web interface :-)
              • pbpm
                • Nov 2010
                Many thanks for your suggestion Armaro of only following what is in the recipe you linked.
                Not sure about the reasons but, I thought the problem was into the Network Adapter setting, but probably is only time needed to run the initial configuration script for appliance, particularly Zabbix.
                I have struggled last days trying to understand why db zabbix was not created and so relative users, zabbix_srv and zabbix_web.
                It's really enough to follow what said into
                Zabbix Appliance on VirtualBox » Simplificando Redes
                Thank for sharing
                pm
                • dimir
                  Zabbix developer
                  • Apr 2011
                  • 1080
                  It's sad to see all the victims here but the actual reason for issues like that is that something went wrong during the deployment of the image. The "replace_user" shouldn't even be visible to a user. The deployment process has steps to replace it with real user name. All a user needs to know is documented here:
                  We should probably add a section telling what to do in situations like this, when something gone wrong. I'm glad that you fixed all the "unfinished" jobs by yourself, well done. Sorry it took you so much time.
                  For all the other victims:
                  if you encounter an issue like this (something is definitely wrong) please just remove everything and re-deploy the image, it should help in most cases.
                  UPD: created an issue: https://support.zabbix.com/browse/ZBX-25771
                  • dimir
                    Zabbix developer
                    • Apr 2011
                    • 1080
                    Thanks to our documentation team there is now a new section "Troubleshooting":
