Zabbix Trigger Boolean irregularity
  • JeffNL
    • Mar 2020
    • 17
    Situation with two trigger for SSL-certificate-warnings:
    1st Trigger:
    Severity: Information
    Problem expression:
    {Website:ssl_cert_check.sh["expire","{HOST.HOST}","443"].last()}<28 and {Website:ssl_cert_check.sh["expire","{HOST.HOST}","443"].last()}>=14
    Recovery expression:
    {Website:ssl_cert_check.sh["expire","{HOST.HOST}","443"].last()}<14 or {Website:ssl_cert_check.sh["expire","{HOST.HOST}","443"].last()}>=28
    2nd Trigger:
    Severity: Warning
    Problem expression:
    Last value = 8
    Both triggers show “Problem”, while I expect only the 2nd trigger to show “Problem”.
    How can that be?
    Is it a bug?
    I already upgraded to the latest version, but the problem remains.
    Does anybody know why the 1st trigger still shows “problem”?
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    It's not possible. I have just checked it with the latest version (5.2.0rc1). Could you double-check it?
    • JeffNL
      • Mar 2020
      • 17
      Hi Dimir,
      Thanks for checking on your version.
      We are runnig version 5.0.4
      • JeffNL
        • Mar 2020
        • 17
        Today the problem is gone.
        Like magic, because no new things were tried to solve this strange issue.
        Maybe some delayed thing after the upgrade I did?
        Problem gone ->
