item value in trigger name
  • losos_sk
    • Aug 2012
    Hello, I have two items checked over snmp in template for cisco switch:
    Description of port
    Status of port (up down)
    I would like to have in name of trigger for status of port its value for description.
    And if my port description on switch is "printer" and the port on switch goes down I need to see on dashboard something like:
    Host ---- Issue
    Switch01-----Port down-priter
    Any ideas? I know how to get values for both, i got trigger when the port goes down, just need to get there the description.
    Thank you
  • aib
    • Jan 2014
    • 1615
    try to create a trigger which will have two parts:
    1) check if port is down
    2) check if Description is not empty
    Then you can create trigger Name , which include {ITEM.VALUE1} for port's status and {ITEM.VALUE2} for port's Description.
    Sincerely yours,
    Aleksey
    • losos_sk
      • Aug 2012
      excelent, ty
