Error: Failure when receiving data from the peer
  • aymenrz
    • Oct 2020
    Someone can help me please, I have a problem with zabbix mail notification after upgrading zabbix server from jessie to buster debian version
    Error:
    Media type test failed.
    • Failure when receiving data from the peer
    I can sent mail using : curl smtp://smtp.example.com --mail-from [email protected] --mail-rcpt [email protected] --upload-file email.txt
    Regards
  • Mbo
    • Oct 2020
    The same for me on centos8+Zabbix5.0.5, can you help us please ??? Maybe it's a bug from Centos8 because it worked fine with Centos7 with the same parameters in zabbix media types
    • Mbo
      • Oct 2020
      For me it was the old exchange 2010 smtp that not accept the new sercurity protocol for STARTTLS with centos 8 so the solution is to install Zabbix on centos 7 and it works !! So becareful on the smtp server version used.
      • Rudlafik
        • Nov 2018
        • 168
        Hi, thx your last post help me this is my solution>
