Zabbix Agent Userparameters overloads the System
  • ahrar.ahmed
    • Aug 2019
    Hi.
    I am monitoring unbound DNS. Snapshots of Items and ps output attached with this...
    This is the Userparamter
    UserParameter=unbound[*],sudo /usr/sbin/unbound-control stats_noreset | grep $1= | cut -d= -f2
    Default Polling interval is 60s i have also tried scheduled and flexible intervals as well..
    Total Items being monitord are around 80. So after one minute Zabbix Server polls unbound machine...
    The problem i face is that i want Zabbix agent to run this command once "sudo /usr/sbin/unbound-control stats_noreset | grep $1= | cut -d= -f2
    But instead, for every item it run this separately (80 times) which results in processor overhead...
    Can some one help me how can i achieve to poll unbound statistics only once, not like 80 times.
Name:	same query multiple times.png
ID:	410945Click image for larger version
Name:	item examples.png
  • tim.mooney
    • Dec 2012
    • 1436
    You'll probably have to redesign your custom item that runs the command to collect the data, but the solution to the issue is to use dependent items: https://www.zabbix.com/documentation...ependent_items
    • ahrar.ahmed
      • Aug 2019
      Thank You for your reply.. I will try dependent item and let you know if it worked for me..
      • ahrar.ahmed
        • Aug 2019
        Thank you Tim
        Dependent Item solved my problem
