Zabbix vs Mattermost
  • jbrveen
    • Oct 2020
    Hi there guys! We are using Zabbix for our monitoring and we want to have an automated message to our MatterMost instance. We can't get this to work: it constantly gives an Mattermost notification failed: SyntaxError: invalid json (at offset 1).
    I've been searchin'everywhere, including here, to find a solution. I'm using the MatterMost integration shipped within Zabbix. I can see on my MatterMost server that the identification goes correctly (to say: if I'm using a wrong bot_token it gives a warning in my MatterMost log, if I'm using the correct bot_token it doesn't say anything).
    This is the configuration shipped within Zabbix. Anyone? Cause I've been trying to debug this for hours and hours and it's driving me crazy. I do have a working connection with Slack, so I can connect Zabbix to Slack and use Matterbridge to connect Slack to Mattermost, but that seems a bit... bloated.
    var SEVERITY_COLORS = [
    '#97AAB3', '#7499FF', '#FFC859',
    '#FFA059', '#E97659', '#E45959'
    var RESOLVE_COLOR = '#009900';
    var SEND_MODE_HANDLERS = {
    alarm: handlerAlarm,
    event: handlerEvent
    if (!String.prototype.format) {
    String.prototype.format = function() {
    var args = arguments;
    return this.replace(/{(\d+)}/g, function(match, number) {
    return number in args
    ? args[number]
    : match
    function isEventProblem(params) {
    return params.event_value == 1
    && params.event_update_status == 0
    function isEventUpdate(params) {
    && params.event_update_status == 1
    function isEventResolve(params) {
    return params.event_value == 0;
    function getPermalink(mattermost_url, team_name, postid) {
    return '{0}/{1}/pl/{2}'.format(
    mattermost_url.replace(/\/+$/, ''),
    team_name,
    postid
    function getChannel(send_to) {
    switch (true) {
    case /.+\/#.+/.test(send_to):
    return getChannelByName(send_to);
    case /@.+/.test(send_to):
    return getDirectChannel(send_to);
    default:
    return getChannelByID(send_to);
    function getChannelByName(send_to) {
    var team_chan = send_to
    .trim()
    .split('/#');
    var resp = JSON.parse(req.Get(
    Mattermost.channel_byname.format(team_chan[0], team_chan[1]),
    JSON.stringify(fields)
    if (req.Status() != 200) {
    throw '[{0}] {1}'.format(resp.status_code, resp.message);
    return resp;
    function getDirectChannel(send_to) {
    Zabbix.Log(5, '[ Mattermost Webhook ] Call {0}({1})'.format(
    arguments.callee.name,
    JSON.stringify(arguments)
    var teamUser = send_to
    .trim()
    .split('/@'),
    bot = getBotUser(),
    user = getUserByName(teamUser[1]);
    var resp = JSON.parse(req.Post(
    Mattermost.direct_channel,
    JSON.stringify([bot.id, user.id])
    Zabbix.Log(5, '[ Mattermost Webhook ] Result {0}: {1}'.format(
    JSON.stringify(resp)
    if (req.Status() != 201) {
    resp.team_name = teamUser[0];
    return resp;
    function getChannelByID(channelID) {
    Mattermost.get_channel.format(channelID),
    return resp;
    function getBotUser() {
    Mattermost.bot_user,
    return resp;
    function getUserByName(userName) {
    Mattermost.user_byname.format(userName),
    return resp;
    function getTeamByID(teamID) {
    Mattermost.get_team.format(teamID),
    return resp;
    function createProblemURL(zabbix_url, triggerid, eventid, event_source) {
    var problem_url = '';
    if (event_source === '0') {
    problem_url = '{0}/tr_events.php?triggerid={1}&eventid={2}'
    .format(
    zabbix_url,
    triggerid,
    eventid
    else {
    problem_url = zabbix_url;
    return problem_url;
    function getTagValue(event_tags, key) {
    var pattern = new RegExp('(' + key + ':.+)');
    var tagValue = event_tags
    .split(',')
    .filter(function (v) {
    return v.match(pattern);
    .map(function (v) {
    return v.split(':')[1];
    })[0]
    || 0;
    return tagValue;
    function handlerAlarm(req, params) {
    var channel = getChannel(params.send_to);
    var fields = {
    channel_id: channel.id,
    props: {}
    if (isEventProblem(params)) {
    var team_name = channel.team_name
    ? channel.team_name
    : getTeamByID(channel.team_id).name;
    fields.props.attachments = [
    createMessage(
    SEVERITY_COLORS[params.event_nseverity] || 0,
    params.event_date,
    params.event_time,
    createProblemURL(params.zabbix_url, params.trigger_id, params.event_id, params.event_source)
    Mattermost.post_message,
    result.tags.__mattermost_post_id = resp.id;
    result.tags.__mattermost_channel_id = channel.id;
    result.tags.__mattermost_channel_name = channel.name;
    result.tags.__mattermost_message_link = getPermalink(
    params.mattermost_url,
    team_name,
    resp.id
    else if (isEventUpdate(params)) {
    fields.root_id = getTagValue(params.event_tags, 'mattermost_post_id');
    if (params.event_source === '0') {}
    createMessage(
    params.event_update_date,
    params.event_update_time,
    createProblemURL(params.zabbix_url, params.trigger_id, params.event_id, params.event_source),
    true
    Mattermost.post_message, JSON.stringify(fields)
    else if (isEventResolve(params)) {
    fields.channel_id = getTagValue(params.event_tags, 'mattermost_channel_id');
    fields.id = getTagValue(params.event_tags, 'mattermost_post_id');
    createMessage(
    RESOLVE_COLOR,
    params.event_date,
    params.event_time,
    var post_id = getTagValue(params.event_tags, 'mattermost_post_id');
    resp = JSON.parse(req.Put(
    Mattermost.chat_update.format(post_id),
    function handlerEvent(req, params) {
    var fields = {
    props: {}
    ? channel.team_name
    createMessage(
    params.event_date,
    params.event_time,
    var resp = JSON.parse(req.Post(Mattermost.post_message, JSON.stringify(fields)));
    team_name,
    resp.id
    createMessage(
    false
    createMessage(
    RESOLVE_COLOR,
    params.event_recovery_date,
    params.event_recovery_time,
    function createMessage(
    event_severity_color,
    event_date,
    event_time,
    problem_url,
    isShort
    var message = {
    fallbac: params.alert_subject,
    title: params.alert_subject,
    color: event_severity_color,
    title_link: problem_url,
    footer: problem_url,
    fields: [
    title: 'Host',
    value: '{0} [{1}]'.format(params.host_name, params.host_ip),
    short: true
    title: 'Event time',
    value: '{0} {1}'.format(event_date, event_time),
    short: true
    message.fields.push(
    title: 'Severity',
    value: params.event_severity,
    short: true
    title: 'Opdata',
    value: params.event_opdata,
    short: true
    if (!isShort && params.event_source === '0') {
    title: 'Event tags',
    value: '`{0}`'.format(params.event_tags.replace(/__.+?:(.+?,|.+)/g, '') || 'None'),
    short: true
    title: 'Trigger description',
    value: params.trigger_description,
    short: true
    if (params.event_source !== '0' || params.event_update_status === '1') {
    title: 'Details',
    value: params.alert_message,
    short: false
    return message;
    function validateParams(params) {
    if (typeof params.bot_token !== 'string' || params.bot_token.trim() === '') {
    throw 'Field "bot_token" cannot be empty';
    if (isNaN(params.event_id)) {
    throw 'Field "event_id" is not a number';
    if ([0, 1, 2, 3].indexOf(parseInt(params.event_source)) === -1) {
    throw 'Incorrect "event_source" parameter given: "' + params.event_source + '".\nMust be 0-3.';
    if (params.event_source !== '0') {
    params.event_nseverity = '0';
    params.event_severity = 'Not classified';
    params.event_update_status = '0';
    params.send_mode = 'event';
    if (params.event_source === '1' || params.event_source === '2') {
    params.event_value = '1';
    if (params.event_source === '1') {
    params.host_name = params.discovery_host_dns;
    params.host_ip = params.discovery_host_ip;
    if ([0, 1, 2, 3, 4, 5].indexOf(parseInt(params.event_nseverity)) === -1) {
    throw 'Incorrect "event_nseverity" parameter given: ' + params.event_nseverity + '\nMust be 0-5.';
    if (typeof params.event_severity !== 'string' || params.event_severity.trim() === '') {
    throw 'Field "event_severity" cannot be empty';
    if (params.event_update_status !== '0' && params.event_update_status !== '1') {
    throw 'Incorrect "event_update_status" parameter given: ' + params.event_update_status + '\nMust be 0 or 1.';
    if (params.event_value !== '0' && params.event_value !== '1') {
    throw 'Incorrect "event_value" parameter given: ' + params.event_value + '\nMust be 0 or 1.';
    if (typeof params.host_ip !== 'string' || params.host_ip.trim() === '') {
    throw 'Field "host_ip" cannot be empty';
    if (typeof params.host_name !== 'string' || params.host_name.trim() === '') {
    throw 'Field "host_name" cannot be empty';
    if (typeof params.mattermost_url !== 'string' || params.mattermost_url.trim() === '') {
    throw 'Field "mattermost_url" cannot be empty';
    if (!/^(http|https):\/\/.+/.test(params.mattermost_url)) {
    throw 'Field "mattermost_url" must contain a schema';
    if (['alarm', 'event'].indexOf(params.send_mode) === -1) {
    throw 'Incorrect "send_mode" parameter given: ' + params.send_mode + '\nMust be "alarm" or "event".';
    if (typeof params.send_to !== 'string' || params.send_to.trim() === '') {
    throw 'Field "send_to" cannot be empty';
    if (isNaN(params.trigger_id) && params.event_source === '0') {
    throw 'field "trigger_id" is not a number';
    if (typeof params.zabbix_url !== 'string' || params.zabbix_url.trim() === '') {
    throw 'Field "zabbix_url" cannot be empty';
    if (!/^(http|https):\/\/.+/.test(params.zabbix_url)) {
    throw 'Field "zabbix_url" must contain a schema';
    try {
    var params = JSON.parse(value);
    validateParams(params);
    var req = new CurlHttpRequest(),
    fields = {},
    result = {tags: {}};
    if (typeof params.HTTPProxy === 'string' && params.HTTPProxy.trim() !== '') {
    req.SetProxy(params.HTTPProxy);
    req.AddHeader('Content-Type: application/json; charset=utf-8');
    req.AddHeader('Authorization: Bearer ' + params.bot_token);
    params.mattermost_url = params.mattermost_url.replace(/\/+$/, '');
    params.zabbix_url = params.zabbix_url.replace(/\/+$/, '');
    var APIEndpoint = params.mattermost_url + '/api/v4/';
    var Mattermost = {
    post_message: APIEndpoint + 'posts',
    get_channel: APIEndpoint + 'channels/{0}',
    get_team: APIEndpoint + 'teams/{0}',
    chat_update: APIEndpoint + 'posts/{0}',
    direct_channel: APIEndpoint + 'channels/direct',
    channel_byname: APIEndpoint + 'teams/name/{0}/channels/name/{1}',
    user_byname: APIEndpoint + 'users/username/{0}',
    bot_user: APIEndpoint + 'users/me'
    params.send_mode = params.send_mode.toLowerCase();
    params.send_mode = params.send_mode in SEND_MODE_HANDLERS
    ? params.send_mode
    : 'alarm';
    SEND_MODE_HANDLERS[params.send_mode](req, params);
    return JSON.stringify(result);
    else {
    return 'OK';
    catch (error) {
    Zabbix.Log(4, '[ Mattermost Webhook ] Mattermost notification failed: ' + error);
    throw 'Mattermost notification failed: ' + error;
  • vincent1890
    • Nov 2020
    • 11
    event: handlerEvent
    ? args[number]
    : match
    team_name,
    postid
    switch (true) {
    default:
    .trim()
    .split('/#');
    return resp;
    .trim()
    .split('/@'),
    bot = getBotUser(),
    return resp;
    return resp;
    return resp;
    return resp;
    return resp;
    .format(
    zabbix_url,
    triggerid,
    eventid
    else {
    return problem_url;
    .split(',')
    .map(function (v) {
    })[0]
    || 0;
    return tagValue;
    var fields = {
    props: {}
    ? channel.team_name
    createMessage(
    params.event_date,
    params.event_time,
    team_name,
    resp.id
    createMessage(
    true
    createMessage(
    RESOLVE_COLOR,
    params.event_date,
    params.event_time,
    var fields = {
    props: {}
    ? channel.team_name
    createMessage(
    params.event_date,
    params.event_time,
    team_name,
    resp.id
    createMessage(
    false
    createMessage(
    RESOLVE_COLOR,
    event_date,
    event_time,
    problem_url,
    isShort
    var message = {
    fields: [
    title: 'Host',
    short: true
    short: true
    title: 'Severity',
    short: true
    title: 'Opdata',
    short: true
    short: true
    short: true
    title: 'Details',
    short: false
    return message;
    try {
    fields = {},
    var Mattermost = {
    ? params.send_mode
    : 'alarm';
    else {
    return 'OK';
    catch (error) {
    Hello
    Did you manage to find the problem I use Zabbix 5.2 and I have the same behavior as you?
    Thank you and have a good day
    • jaayb
      • Jan 2024
      Had the same problem. Solution was that I was using the Token ID instead of the access token in the mattermost template. I also changed the zabbix username to zabbix-alerter vs "zabbix alerter" as the documentation said. Finally the mattermost url is just the fqdn of the server vs the web hook url which is what I was using. You have to copy the access token as mattermost indicates that it won't be shown again after the first time it is created. I thought the token id shown in the bot settings was the access token. Had to delete and recreate the token to get the access token value.
