lld: there is no way to create host with macro value from customized macro
  • gralech
    • Oct 2020
    • 12
    Good day!
    I'm trying to create lld rule, wich create host with macro, wich value get from library of global or templated macro (same template)
    ex:
    1. Template A has library of passwords: {$RMQ.API.PASSWORD} (default value), {$RMQ.API.PASSWORD:"Service1"}, {$RMQ.API.PASSWORD:"Service2"} ...
    2. lld rule in Template A creating hosts, with attached default rmq template, with macro {$RMQ.API.PASSWORD:"{#SERVICE_NAME}"} - and it's value not resolved, either library of passwords in template A or in Global macros
    is this possible?
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    If I understood you correctly this functionality is not supported. Are the actual passwords coming from lld? If yes, just use lld macros in item prototypes. If not, what's the use to have this dynamic way, just using
    seems to be a good idea.
    • gralech
      • Oct 2020
      • 12
      No actual passwords not coming from lld. I want to keep passwords library in template or in global macros
