Zabbix server service does not start "anymore"
  • Eine Mail
    • Oct 2020
    • 13
    Hello...
    I'm new here at Zabbix and slowly work my way through the functions...
    Yesterday, in the middle of the business, the message suddenly came "Zabbix server is not running: The information displayed may not be up to date."
Name:	2020-10-22 08_24_49-Konfiguration der Benutzer.png
    So just hopped on the Linux server and want to restart the service with a restart ... Unfortunately does not work!
    Following data:
    Linux system:
    - Ubuntu 20.04 completely updated
    - Firewall is deactivated
    -> zabbix ran without problems for a good 2-3 weeks
    Zabbix system: - Zabbix 5.0 LTS / Ubuntu 20.04 / PostgreSQL / Apache
    - Check in /etc/zabbix/web/zabbix.conf.php whether everything is set correctly. (but it worked before too :-))
    - with -> sudo service zabbix-server start / stop / restart tries to restart the service. (also restarted the server)
    - with -> systemctl list-units --all --type = service --no-pager | grep zabbix -> the status checked
    I am not good in Linux, the result is a bit confusing for me: -> Result: zabbix-server.service | loaded | activating | auto-restart | Zabbix server
Name:	2020-10-22 08_48_20-LX-Ubuntu20TLS - VMware Remote Console.png
    To be honest, I have no idea where to look
    I still found this error today, but unfortunately I cannot eliminate it or classify it
Name:	2020-10-22 11_34_32-LX-Ubuntu20TLS - VMware Remote Console.png
    If someone has an idea, I would be very happy ...
    Best regards Andy
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    The reason is most probably in the log file
    /var/log/zabbix/zabbix_server.log
    I assume you need to increase the value of some type of cache. Usually this looks something like this:
    $ tail -n 100 /var/log/zabbix/zabbix_server.log
    20244:20201022:135445.088 Starting Zabbix Server. Zabbix 5.0.4 (revision {ZABBIX_REVISION}).
    20244:20201022:135445.088 ****** Enabled features ******
    20244:20201022:135445.088 SNMP monitoring: YES
    20244:20201022:135445.088 IPMI monitoring: NO
    20244:20201022:135445.088 Web monitoring: YES
    20244:20201022:135445.088 VMware monitoring: NO
    20244:20201022:135445.088 SMTP authentication: YES
    20244:20201022:135445.088 ODBC: NO
    20244:20201022:135445.088 SSH support: NO
    20244:20201022:135445.088 IPv6 support: YES
    20244:20201022:135445.088 TLS support: YES
    20244:20201022:135445.088 ******************************
    20244:20201022:135445.088 using configuration file: /etc/zabbix/zabbix_server.conf
    20244:20201022:135445.092 current database version (mandatory/optional): 05000000.0/05000002.0
    20244:20201022:135445.092 required mandatory version: 05000000.0
    20244:20201022:135445.098 server #0 started [main process]
    20246:20201022:135445.099 server #1 started [configuration syncer #1]
    20246:20201022:135445.107 __mem_malloc: skipped 0 asked 64 skip_min 18446744073709551615 skip_max 0
    20246:20201022:135445.107 [file:dbconfig.c,line:96] __zbx_mem_malloc(): out of memory (requested 64 bytes)
    20246:20201022:135445.107 [file:dbconfig.c,line:96] __zbx_mem_malloc(): please increase CacheSize configuration parameter
    The message means you need to increase the value of CacheSize in /etc/zabbix/zabbix_server.conf .
    • Eine Mail
      • Oct 2020
      • 13
      Thank you for your response.
      I'm on a different track right now and will look at your proposal afterwards.
      At the moment I see an entry "PidFile = / var / run / zabbix / zabbix_server.pid" in zabbix_server.conf,
      but this file does not exist in the directory.
      I'm currently looking for where this file could be.
      I think that could be the problem ;-)
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        The file appears when Zabbix server starts successfully, since it fails to do so probably it shouldn't be there. I'd check the log file.
        • Eine Mail
          • Oct 2020
          • 13
          Hey...
          You're rigth.
Name:	2020-10-22 14_13_00-LX-Ubuntu20TLS - VMware Remote Console.png
          I Change the CacheSize to 250M
          Why was this parameter switched off by default??? :-)
          A HUGE thank you :-)
          • dimir
            Zabbix developer
            • Apr 2011
            • 1080
            We try to form the default configuration file so that user has all the information about each parameter. As to CacheSize:
            ### Option: CacheSize
            # Size of configuration cache, in bytes.
            # Shared memory size for storing host, item and trigger data.
            # Mandatory: no
            # Range: 128K-64G
            # Default:
            # CacheSize=8M
            seems it's pretty straightforward. The default value (when commented out) is 8 MB, and you have the min and max supported values. We recommend to add new line after that section when you want to override:
            # Mandatory: no
            # Range: 128K-64G
            # Default:
            # CacheSize=8M
            CacheSize=250M
            • charliemav
              • Jun 2022
              So this all makes perfect sense.... I added a bunch of Cisco devices on Friday with the templates and jumped up the demand on the server. No doubt the CacheSize was impacted. However, after reading this post, I adjusted the CacheSize parameters (many of the others as well), and still I can't get the Zabbix Server service to start. Log file still says out of memory.
              sudo grep CacheSize -A 1 /etc/zabbix/zabbix_server.conf
              ### Option: VMwareCacheSize
              # Size of VMware cache, in bytes.
              VMwareCacheSize=32M
              CacheSize=16G
              ### Option: HistoryCacheSize
              # Size of history cache, in bytes.
              HistoryCacheSize=256M
              ### Option: HistoryIndexCacheSize
              # Size of history index cache, in bytes.
              ### Option: TrendCacheSize
              # Size of trend write cache, in bytes.
              TrendCacheSize=32M
              ### Option: TrendFunctionCacheSize
              # Size of trend function cache, in bytes.
              TrendFunctionCacheSize=32M
              ### Option: ValueCacheSize
              # Size of history value cache, in bytes.
              ValueCacheSize=250M
              Went to the (seemingly) ridiculous number of 16G for the base CacheSize - still no dice. What am I missing here?
