Zabbix Bug on latest data
  • killmasta93
    • Oct 2019
    • 45
    Hi currently running 5.0.2 zabbix server with db postgre everything was working fine then all of sudden when i click on latest data just hangs on there which is odd because it was working fine yesterday.
    i checked the logs on zabbix server couldn't find anything odd
    # This is a configuration file for Zabbix server daemon
    # To get more information about Zabbix, visit http://www.zabbix.com
    ### Option: ListenPort
    # Listen port for trapper.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10051
    ### Option: SourceIP
    # Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: LogType
    # Specifies where log messages are written to:
    # system - syslog
    # file - file specified with LogFile parameter
    # console - standard output
    # Mandatory: no
    # Default:
    # LogType=file
    ### Option: LogFile
    # Log file name for LogType 'file' parameter.
    # Mandatory: yes, if LogType is set to file, otherwise no
    # Default:
    # LogFile=
    LogFile=/var/log/zabbix/zabbix_server.log
    ### Option: LogFileSize
    # Maximum size of log file in MB.
    # 0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    LogFileSize=0
    ### Option: DebugLevel
    # Specifies debug level:
    # 0 - basic information about starting and stopping of Zabbix processes
    # 1 - critical information
    # 2 - error information
    # 3 - warnings
    # 4 - for debugging (produces lots of information)
    # 5 - extended debugging (produces even more information)
    # Mandatory: no
    # Range: 0-5
    # Default:
    # DebugLevel=3
    ### Option: PidFile
    # Name of PID file.
    # Mandatory: no
    # Default:
    # PidFile=/tmp/zabbix_server.pid
    PidFile=/var/run/zabbix/zabbix_server.pid
    ### Option: SocketDir
    # IPC socket directory.
    # Directory to store IPC sockets used by internal Zabbix services.
    # Mandatory: no
    # Default:
    # SocketDir=/tmp
    SocketDir=/var/run/zabbix
    ### Option: DBHost
    # Database host name.
    # If set to localhost, socket is used for MySQL.
    # If set to empty string, socket is used for PostgreSQL.
    # Mandatory: no
    # Default:
    # DBHost=localhost
    ### Option: DBName
    # Database name.
    # Mandatory: yes
    # Default:
    # DBName=
    DBName=zabbix
    ### Option: DBSchema
    # Schema name. Used for PostgreSQL.
    # Mandatory: no
    # Default:
    # DBSchema=
    ### Option: DBUser
    # Database user.
    # Mandatory: no
    # Default:
    # DBUser=
    DBUser=zabbix
    ### Option: DBPassword
    # Database password.
    # Comment this line if no password is used.
    # Mandatory: no
    # Default:
    DBPassword=mypass
    ### Option: DBSocket
    # Path to MySQL socket.
    # Mandatory: no
    # Default:
    # DBSocket=
    ### Option: DBPort
    # Database port when not using local socket.
    # Mandatory: no
    # Range: 1024-65535
    # Default:
    # DBPort=
    ### Option: HistoryStorageURL
    # History storage HTTP[S] URL.
    # Mandatory: no
    # Default:
    # HistoryStorageURL=
    ### Option: HistoryStorageTypes
    # Comma separated list of value types to be sent to the history storage.
    # Mandatory: no
    # Default:
    # HistoryStorageTypes=uint,dbl,str,log,text
    ### Option: HistoryStorageDateIndex
    # Enable preprocessing of history values in history storage to store values in different indices based on date.
    # 0 - disable
    # 1 - enable
    # Mandatory: no
    # Default:
    # HistoryStorageDateIndex=0
    ### Option: ExportDir
    # Directory for real time export of events, history and trends in newline delimited JSON format.
    # If set, enables real time export.
    # Mandatory: no
    # Default:
    # ExportDir=
    ### Option: ExportFileSize
    # Maximum size per export file in bytes.
    # Only used for rotation if ExportDir is set.
    # Mandatory: no
    # Range: 1M-1G
    # Default:
    # ExportFileSize=1G
    ############ ADVANCED PARAMETERS ################
    ### Option: StartPollers
    # Number of pre-forked instances of pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    StartPollers=150
    ### Option: StartIPMIPollers
    # Number of pre-forked instances of IPMI pollers.
    # The IPMI manager process is automatically started when at least one IPMI poller is started.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartIPMIPollers=0
    ### Option: StartPreprocessors
    # Number of pre-forked instances of preprocessing workers.
    # The preprocessing manager process is automatically started when preprocessor worker is started.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # StartPreprocessors=5
    ### Option: StartPollersUnreachable
    # Number of pre-forked instances of pollers for unreachable hosts (including IPMI and Java).
    # At least one poller for unreachable hosts must be running if regular, IPMI or Java pollers
    # are started.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    StartPollersUnreachable=100
    ### Option: StartTrappers
    # Number of pre-forked instances of trappers.
    # Trappers accept incoming connections from Zabbix sender, active agents and active proxies.
    # At least one trapper process must be running to display server availability and view queue
    # in the frontend.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    StartTrappers=10
    ### Option: StartPingers
    # Number of pre-forked instances of ICMP pingers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartPingers=1
    ### Option: StartDiscoverers
    # Number of pre-forked instances of discoverers.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartDiscoverers=1
    ### Option: StartHTTPPollers
    # Number of pre-forked instances of HTTP pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartHTTPPollers=1
    ### Option: StartTimers
    # Number of pre-forked instances of timers.
    # Timers process maintenance periods.
    # Only the first timer process handles host maintenance updates. Problem suppression updates are shared
    # between all timers.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # StartTimers=1
    ### Option: StartEscalators
    # Number of pre-forked instances of escalators.
    # Mandatory: no
    # Range: 0-100
    # Default:
    # StartEscalators=1
    ### Option: StartAlerters
    # Number of pre-forked instances of alerters.
    # Alerters send the notifications created by action operations.
    # Mandatory: no
    # Range: 0-100
    # Default:
    # StartAlerters=3
    ### Option: JavaGateway
    # IP address (or hostname) of Zabbix Java gateway.
    # Only required if Java pollers are started.
    # Mandatory: no
    # Default:
    # JavaGateway=
    ### Option: JavaGatewayPort
    # Port that Zabbix Java gateway listens on.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # JavaGatewayPort=10052
    ### Option: StartJavaPollers
    # Number of pre-forked instances of Java pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartJavaPollers=0
    ### Option: StartVMwareCollectors
    # Number of pre-forked vmware collector instances.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartVMwareCollectors=0
    ### Option: VMwareFrequency
    # How often Zabbix will connect to VMware service to obtain a new data.
    # Mandatory: no
    # Range: 10-86400
    # Default:
    # VMwareFrequency=60
    ### Option: VMwarePerfFrequency
    # How often Zabbix will connect to VMware service to obtain performance data.
    # Mandatory: no
    # Range: 10-86400
    # Default:
    # VMwarePerfFrequency=60
    ### Option: VMwareCacheSize
    # Size of VMware cache, in bytes.
    # Shared memory size for storing VMware data.
    # Only used if VMware collectors are started.
    # Mandatory: no
    # Range: 256K-2G
    # Default:
    # VMwareCacheSize=8M
    ### Option: VMwareTimeout
    # Specifies how many seconds vmware collector waits for response from VMware service.
    # Mandatory: no
    # Range: 1-300
    # Default:
    # VMwareTimeout=10
    ### Option: SNMPTrapperFile
    # Temporary file used for passing data from SNMP trap daemon to the server.
    # Must be the same as in zabbix_trap_receiver.pl or SNMPTT configuration file.
    # Mandatory: no
    # Default:
    # SNMPTrapperFile=/tmp/zabbix_traps.tmp
    SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
    ### Option: StartSNMPTrapper
    # If 1, SNMP trapper process is started.
    # Mandatory: no
    # Range: 0-1
    # Default:
    # StartSNMPTrapper=0
    ### Option: ListenIP
    # List of comma delimited IP addresses that the trapper should listen on.
    # Trapper will listen on all network interfaces if this parameter is missing.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    # ListenIP=127.0.0.1
    ### Option: HousekeepingFrequency
    # How often Zabbix will perform housekeeping procedure (in hours).
    # Housekeeping is removing outdated information from the database.
    # To prevent Housekeeper from being overloaded, no more than 4 times HousekeepingFrequency
    # hours of outdated information are deleted in one housekeeping cycle, for each item.
    # To lower load on server startup housekeeping is postponed for 30 minutes after server start.
    # With HousekeepingFrequency=0 the housekeeper can be only executed using the runtime control option.
    # In this case the period of outdated information deleted in one housekeeping cycle is 4 times the
    # period since the last housekeeping cycle, but not less than 4 hours and not greater than 4 days.
    # Mandatory: no
    # Range: 0-24
    # Default:
    # HousekeepingFrequency=1
    ### Option: MaxHousekeeperDelete
    # The table "housekeeper" contains "tasks" for housekeeping procedure in the format:
    # [housekeeperid], [tablename], [field], [value].
    # No more than 'MaxHousekeeperDelete' rows (corresponding to [tablename], [field], [value])
    # will be deleted per one task in one housekeeping cycle.
    # If set to 0 then no limit is used at all. In this case you must know what you are doing!
    # Mandatory: no
    # Range: 0-1000000
    # Default:
    # MaxHousekeeperDelete=5000
    ### Option: CacheSize
    # Size of configuration cache, in bytes.
    # Shared memory size for storing host, item and trigger data.
    # Mandatory: no
    # Range: 128K-64G
    # Default:
    CacheSize=512M
    ### Option: CacheUpdateFrequency
    # How often Zabbix will perform update of configuration cache, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # CacheUpdateFrequency=60
    ### Option: StartDBSyncers
    # Number of pre-forked instances of DB Syncers.
    # Mandatory: no
    # Range: 1-100
    # Default:
    # StartDBSyncers=4
    ### Option: HistoryCacheSize
    # Size of history cache, in bytes.
    # Shared memory size for storing history data.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    HistoryCacheSize=50M
    ### Option: HistoryIndexCacheSize
    # Size of history index cache, in bytes.
    # Shared memory size for indexing history cache.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    # HistoryIndexCacheSize=4M
    ### Option: TrendCacheSize
    # Size of trend cache, in bytes.
    # Shared memory size for storing trends data.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    # TrendCacheSize=4M
    ### Option: ValueCacheSize
    # Size of history value cache, in bytes.
    # Shared memory size for caching item history data requests.
    # Setting to 0 disables value cache.
    # Mandatory: no
    # Range: 0,128K-64G
    # Default:
    ValueCacheSize=512M
    ### Option: Timeout
    # Specifies how long we wait for agent, SNMP device or external check (in seconds).
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    Timeout=30
    ### Option: TrapperTimeout
    # Specifies how many seconds trapper may spend processing new data.
    # Mandatory: no
    # Range: 1-300
    # Default:
    # TrapperTimeout=300
    ### Option: UnreachablePeriod
    # After how many seconds of unreachability treat a host as unavailable.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnreachablePeriod=45
    ### Option: UnavailableDelay
    # How often host is checked for availability during the unavailability period, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnavailableDelay=60
    ### Option: UnreachableDelay
    # How often host is checked for availability during the unreachability period, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnreachableDelay=15
    ### Option: AlertScriptsPath
    # Full path to location of custom alert scripts.
    # Default depends on compilation options.
    # To see the default path run command "zabbix_server --help".
    # Mandatory: no
    # Default:
    # AlertScriptsPath=${datadir}/zabbix/alertscripts
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    ### Option: ExternalScripts
    # Full path to location of external scripts.
    # Mandatory: no
    # Default:
    # ExternalScripts=${datadir}/zabbix/externalscripts
    ExternalScripts=/usr/lib/zabbix/externalscripts
    ### Option: FpingLocation
    # Location of fping.
    # Make sure that fping binary has root ownership and SUID flag set.
    # Mandatory: no
    # Default:
    # FpingLocation=/usr/sbin/fping
    FpingLocation=/usr/bin/fping
    ### Option: Fping6Location
    # Location of fping6.
    # Make sure that fping6 binary has root ownership and SUID flag set.
    # Make empty if your fping utility is capable to process IPv6 addresses.
    # Mandatory: no
    # Default:
    # Fping6Location=/usr/sbin/fping6
    Fping6Location=/usr/bin/fping6
    ### Option: SSHKeyLocation
    # Location of public and private keys for SSH checks and actions.
    # Mandatory: no
    # Default:
    # SSHKeyLocation=
    ### Option: LogSlowQueries
    # How long a database query may take before being logged (in milliseconds).
    # Only works if DebugLevel set to 3, 4 or 5.
    # 0 - don't log slow queries.
    # Mandatory: no
    # Range: 1-3600000
    # Default:
    # LogSlowQueries=0
    LogSlowQueries=3000
    ### Option: TmpDir
    # Temporary directory.
    # Mandatory: no
    # Default:
    # TmpDir=/tmp
    ### Option: StartProxyPollers
    # Number of pre-forked instances of pollers for passive proxies.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartProxyPollers=1
    ### Option: ProxyConfigFrequency
    # How often Zabbix Server sends configuration data to a Zabbix Proxy in seconds.
    # This parameter is used only for proxies in the passive mode.
    # Mandatory: no
    # Range: 1-3600*24*7
    # Default:
    # ProxyConfigFrequency=3600
    ### Option: ProxyDataFrequency
    # How often Zabbix Server requests history data from a Zabbix Proxy in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # ProxyDataFrequency=1
    ### Option: StartLLDProcessors
    # Number of pre-forked instances of low level discovery processors.
    # Mandatory: no
    # Range: 1-100
    # Default:
    # StartLLDProcessors=2
    ### Option: AllowRoot
    # Allow the server to run as 'root'. If disabled and the server is started by 'root', the server
    # will try to switch to the user specified by the User configuration option instead.
    # Has no effect if started under a regular user.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Default:
    # AllowRoot=0
    ### Option: User
    # Drop privileges to a specific, existing user on the system.
    # Only has effect if run as 'root' and AllowRoot is disabled.
    # Mandatory: no
    # Default:
    # User=zabbix
    ### Option: Include
    # You may include individual files or all files in a directory in the configuration file.
    # Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
    # Mandatory: no
    # Default:
    # Include=
    # Include=/usr/local/etc/zabbix_server.general.conf
    # Include=/usr/local/etc/zabbix_server.conf.d/
    # Include=/usr/local/etc/zabbix_server.conf.d/*.conf
    ### Option: SSLCertLocation
    # Location of SSL client certificates.
    # This parameter is used only in web monitoring.
    # Mandatory: no
    # Default:
    # SSLCertLocation=${datadir}/zabbix/ssl/certs
    ### Option: SSLKeyLocation
    # Location of private keys for SSL client certificates.
    # Mandatory: no
    # Default:
    # SSLKeyLocation=${datadir}/zabbix/ssl/keys
    ### Option: SSLCALocation
    # Override the location of certificate authority (CA) files for SSL server certificate verification.
    # If not set, system-wide directory will be used.
    # This parameter is used only in web monitoring and SMTP authentication.
    # Mandatory: no
    # Default:
    # SSLCALocation=
    ### Option: StatsAllowedIP
    # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of external Zabbix instances.
    # Stats request will be accepted only from the addresses listed here. If this parameter is not set no stats requests
    # will be accepted.
    # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally
    # and '::/0' will allow any IPv4 or IPv6 address.
    # '0.0.0.0/0' can be used to allow any IPv4 address.
    # Example: StatsAllowedIP=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
    # Mandatory: no
    # Default:
    # StatsAllowedIP=
    ####### LOADABLE MODULES #######
    ### Option: LoadModulePath
    # Full path to location of server modules.
    # Mandatory: no
    # Default:
    # LoadModulePath=${libdir}/modules
    # Module to load at server startup. Modules are used to extend functionality of the server.
    # Formats:
    # LoadModule=<module.so>
    # LoadModule=<path/module.so>
    # LoadModule=</abs_path/module.so>
    # Either the module must be located in directory specified by LoadModulePath or the path must precede the module name.
    # If the preceding path is absolute (starts with '/') then LoadModulePath is ignored.
    # It is allowed to include multiple LoadModule parameters.
    # Mandatory: no
    # Default:
    # LoadModule=
    ####### TLS-RELATED PARAMETERS #######
    ### Option: TLSCAFile
    # Full pathname of a file containing the top-level CA(s) certificates for
    # peer certificate verification.
    # Mandatory: no
    # Default:
    # TLSCAFile=
    ### Option: TLSCRLFile
    # Full pathname of a file containing revoked certificates.
    # Mandatory: no
    # Default:
    # TLSCRLFile=
    ### Option: TLSCertFile
    # Full pathname of a file containing the server certificate or certificate chain.
    # Mandatory: no
    # Default:
    # TLSCertFile=
    ### Option: TLSKeyFile
    # Full pathname of a file containing the server private key.
    # Mandatory: no
    # Default:
    # TLSKeyFile=
    ####### For advanced users - TLS ciphersuite selection criteria #######
    ### Option: TLSCipherCert13
    # Cipher string for OpenSSL 1.1.1 or newer in TLS 1.3.
    # Override the default ciphersuite selection criteria for certificate-based encryption.
    # Mandatory: no
    # Default:
    # TLSCipherCert13=
    # GnuTLS priority string or OpenSSL (TLS 1.2) cipher string.
    # Example for GnuTLS:
    # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
    # Example for OpenSSL:
    # EECDH+aRSA+AES128:RSA+aRSA+AES128
    # Mandatory: no
    # Default:
    # TLSCipherCert=
    ### Option: TLSCipherPSK13
    # Override the default ciphersuite selection criteria for PSK-based encryption.
    # Example:
    # TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA25 6
    # Mandatory: no
    # Default:
    # TLSCipherPSK13=
    # NONE:+VERS-TLS1.2:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL
    # kECDHEPSK+AES128:kPSK+AES128
    # Mandatory: no
    # Default:
    # TLSCipherPSK=
    ### Option: TLSCipherAll13
    # Override the default ciphersuite selection criteria for certificate- and PSK-based encryption.
    # Example:
    # TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA25 6:TLS_AES_128_GCM_SHA256
    # Mandatory: no
    # Default:
    # TLSCipherAll13=
    # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
    # EECDH+aRSA+AES128:RSA+aRSA+AES128:kECDHEPSK+AES128 :kPSK+AES128
    # Mandatory: no
    # Default:
    # TLSCipherAll=
    ### Option: DBTLSConnect
    # Setting this option enforces to use TLS connection to database.
    # required - connect using TLS
    # verify_ca - connect using TLS and verify certificate
    # verify_full - connect using TLS, verify certificate and verify that database identity specified by DBHost
    # matches its certificate
    # On MySQL starting from 5.7.11 and PostgreSQL following values are supported: "required", "verify_ca" and
    # "verify_full".
    # On MariaDB starting from version 10.2.6 "required" and "verify_full" values are supported.
    # Default is not to set any option and behavior depends on database configuration
    # Mandatory: no
    # Default:
    # DBTLSConnect=
    ### Option: DBTLSCAFile
    # Full pathname of a file containing the top-level CA(s) certificates for database certificate verification.
    # Supported only for MySQL and PostgreSQL
    # Mandatory: no
    # (yes, if DBTLSConnect set to one of: verify_ca, verify_full)
    # Default:
    # DBTLSCAFile=
    ### Option: DBTLSCertFile
    # Full pathname of file containing Zabbix server certificate for authenticating to database.
    # Mandatory: no
    # Default:
    # DBTLSCertFile=
    ### Option: DBTLSKeyFile
    # Full pathname of file containing the private key for authenticating to database.
    # Mandatory: no
    # Default:
    # DBTLSKeyFile=
    ### Option: DBTLSCipher
    # The list of encryption ciphers that Zabbix server permits for TLS protocols up through TLSv1.2
    # Mandatory no
    # Default:
    # DBTLSCipher=
    ### Option: DBTLSCipher13
    # The list of encryption ciphersuites that Zabbix server permits for TLSv1.3 protocol
    # Supported only for MySQL, starting from version 8.0.16
    # Mandatory no
    # Default:
    # DBTLSCipher13=
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Better check web server log.
    • killmasta93
      • Oct 2019
      • 45
      the only thing odd i found was the php which i added on the config of the www.conf
      pm.max_requests = 500
      and reboot and on the general settings on the webgui i put only 50 items to show before i had around 800 so far its working again ill post back to see what happens
      • MBrunner
        • Oct 2020
        • 16
        5.0.2 has sometimes trouble with latest data. If possible make an upgrade to 5.0.4
        Relatet topic: https://www.zabbix.com/forum/zabbix-...-5-0-2-upgrade
        • killmasta93
          • Oct 2019
          • 45
          Thanks for the reply, i reading to update from 5.0.2 to 5.0.4 i would just run
           sudo apt install --only-upgrade 'zabbix-server.*'
          currently running PostgreSQL12.3 , timescaledb
          • tim.mooney
            • Dec 2012
            • 1436
            You probably want to upgrade the web interface (if it's on the same system as zabbix-server) and the agent/agent2 to the same 5.0.4 version too.
            • killmasta93
              • Oct 2019
              • 45
              Thanks for the reply, zabbix web and database on the same server so it wouldn't matter?
