Zabbix and Centos/Rhel 7.1
  • jugin
    • Apr 2015
    There is bug in gnutls-3.3.8-12.
    When upgrade centos to version 7.1, zabbix server crash
    with:
    zbx_tcp_listen() fatal error: unable to serve on any address [[-]:10051]
    Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x18]. Crashing ...
    Only one solution downgrade gnutls to version 3.1.8.
  • Xiol
    • Apr 2015
    I tried downgrading gnutls as suggested, but this didn't fix the issue.
    While Zabbix stopped segfaulting, it still wouldn't listen on any addresses.
    I'm currently scrambling to reinstall our Zabbix monitoring boxes. Any idea when a fix will be available?
    • jugin
      • Apr 2015
      It seems that you try to start zabbix_server after crash and when
      downgrade gnutls. After crash some zabbix_server threads are
      running.
      Try pkill -9 -f zabbix_server, systemctl start zabbix_server.
      • romuald
        • Oct 2014
        Hi
        I faced the same issue after I had upgraded CentOS to 7.1. I've managed to fix it by upgrading trousers package to the latest version. Hope it will help you as well
        • volter
          • Dec 2011
          • 85
          • THUHV
            • Dec 2009
            • 28
            I have exactly this problem, and i just run "yum update" on my Centos Zabbix server and the problem went out. Hope to help you solve your problem
