Zabbix Agent 2 container problem - container starting with network disabled
  • Singularity
    • Aug 2020
    • 81
    System OS version is Amazon linux 2
    If I start a docker conntainer of zabbix agent 2, it is starting with NetworkDisabled: true
    Because there is not networking, container mapping fails.
    I am new to docker and using the following command to create docker container
    docker run --name zabbix-agent2 -p 10050:10050 -v "/var/run/docker.sock:/var/run/docker.sock" -e ZBX_HOSTNAME="XXXXXX" -e ZBX_SERVER_HOST="XXX.XX.X.XXX" --privileged -e ZBX_TIMEOUT=15 -e ZBX_DEBUGLEVEL=3 -d zabbix/zabbix-agent2:alpine-5.0.4
    "Entrypoint": [
    "/sbin/tini",
    "/usr/bin/docker-entrypoint.sh"
    "NetworkDisabled": true,
    "OnBuild": null,
  • AVP.Riga
    • Oct 2020
    • 59
    Good day,
    Maybe you should to add to the docker run command additional parameter like NetworkDisabled:false ?
    • Singularity
      • Aug 2020
      • 81
      Thanks for the help.
      For some reason container was not being attached to any network.
      I did ifconfig and found no ethernet or nothing was attached to the container.
      Added --network=host while running docker to create container solved the problem. Maybe the team managing the infrastructure has placed restrictions or something.
      Will figure out more and will update.
      Thanks again.
      • AVP.Riga
        • Oct 2020
        • 59
        Good morning,
        You're welcome!
