Good day,
I am trying to use the API to return results for a daily report that we will use for agent availability. We have a trigger setup that performs a check on the agent and should be in a problem state if not available.
For reference the trigger is looking at:
({Agent and Host Availability Template:zabbix[host,agent,available].last(0)}#1 | {Agent and Host Availability Template:zabbix[host,agent,available].nodata(600)}=1)
The exact name of the trigger is: Zabbix agent on {HOSTNAME} is Unreachable
I have the following json query written to try and pull down all triggers that are in a bad state, but whether I set the value to 0 or 1 I get no results, even though I know that the triggers are in an Ok state presently.
If I substitute the value for 0 above, I get no results as well. If I subsitute the description text above for any other trigger name I get results. Can anyone think of a reason why certain triggers could be being excluded? I'm really at a loss.
Thanks in advance.
"jsonrpc": "2.0",
"method": "trigger.get",
"params": {
"output": [
"triggerid",
"description",
"priority"
"search": {
"description": "Zabbix agent on"
"filter": {
"value": 1
"sortfield": "priority",
"sortorder": "DESC",
"expandData": 1,
"expandDescription": 1
"id": 15,
"auth": "MASKEDFORSECURITY"
Thanks in advance.
