JMX monitoring doesn't work through proxy
  • convertor
    • Nov 2014
    some nodes were successfully monitored by zabbix server through Java gateway.
    then I set up zabbix-proxy and additional Java gateway on zabbix-proxy - and it doesn't work for some reason.
    On server GUI I see that jmx is gray on these nodes.
    On zabbix-proxy log I see no approaches to send anything to Java gateway or use it somehow.
    10052 port is listening by Java gateway on zabbix-proxy node.
  • wdijkerman
    • Jan 2015
    • 18
    If the zabbix-proxy is configured to use an Java Gateway, the hosts should be monitored by this proxy. Is this the case?
    Kind regards,
    Werner
    • LenR
      • Sep 2009
      • 1011
      It will work, so it's probably a configuration, firewall or network error.
      I have a java gateway on my zabbix proxy, make sure those parts are working. Make sure that your proxy can connect to the client jmx port (nmap).
      Check the logs and tcpdump will tell you a lot :-)
