Can't install Zabbix in Ubuntu 20.10
  • seanr22a
    • Oct 2020
    I'm well aware of that latest official supported Ubuntu release is 20.04 but I thought I would give it a try on the latest 20.10
    It seems like Zabbix depends on a old package ttf-dejavu that have been hanging around for a long time and has finally been removed in 20.10
    root@gamil:~# apt install zabbix-server-mysql zabbix-frontend-php zabbix-apache-conf zabbix-agent
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
    zabbix-frontend-php : Depends: ttf-dejavu-core but it is not installable or
    ttf-japanese-gothic but it is not installable
    E: Unable to correct problems, you have held broken packages.
    root@gamil:~#
    Ubuntu says this package has been removed for good in 20.10 but I found the latest version of the dejavu-core and installed but it doesn't help.
    Someone found a workaround ?
  • fwells11
    • Nov 2020
    it's in the Universe repo
    sudo add-apt-repository universe
    Make sure it got added to repo and is enabled: grep ^deb /etc/apt/sources.list
    apt update
    Try running your Zabbix install again.
