Zabbix-Frontend connection error Remote database on another server.
  • vincent1890
    • Nov 2020
    • 11
    Hello
    OS:Ubuntu 18.04 / Zabbix 5.2 / Srv Database MariaDB 5.5.57
    Unable to install Zabbix-Frontend this blocks the connection of the database with the error "MySQL server hasgone away" see screenshot
    I am trying to install Zabbix Server/Front end on one server and Database is on another server.
    Yet on the server the connection to the Database is done correctly see screenshot
    My my.cnf
    HTML Code:
    [client]
    #password = your_password
    port = 3306
    socket = /tmp/mysql.sock
    # The MariaDB server
    [mysqld]
    port = 3306
    skip-external-locking
    key_buffer_size = 16M
    max_allowed_packet = 1M
    table_open_cache = 64
    sort_buffer_size = 512K
    net_buffer_length = 8K
    read_buffer_size = 256K
    read_rnd_buffer_size = 512K
    myisam_sort_buffer_size = 8M
    default-storage-engine = MyISAM
    #skip-innodb
    # Point the following paths to different dedicated disks
    #tmpdir = /tmp/
    # Replication Master Server (default)
    # binary logging is required for replication
    log-bin=mysql-bin
    # binary logging format - mixed recommended
    binlog_format=mixed
    [mysqldump]
    quick
    max_allowed_packet = 16M
    [mysql]
    no-auto-rehash
    # Remove the next comment character if you are not familiar with SQL
    #safe-updates
    [myisamchk]
    key_buffer_size = 20M
    sort_buffer_size = 20M
    read_buffer = 2M
    write_buffer = 2M
    [mysqlhotcopy]
    interactive-timeout
    What do I have to do and how do I resolve this please?
    Thank
  • vincent1890
    • Nov 2020
    • 11
    I managed to find an alternative to finish the installation of the Frontend-Zabbix but this one is not really top and I would need info to secure this alternative install please.
    I all just copy paste the file zabbix.conf.php.example into zabbix.conf.php and replace the Database values but then the setup must surely fill in other values in zabbix.conf.php I guess and probably do other actions but I don’t know which ones so If someone would like to help me or if one of the developer of the frontend sees this message I would like him to help me and that we can solve this problem rather recurring apparently but without solution for the moment.
    Thank you and have a good day
    • tim.mooney
      • Dec 2012
      • 1436
      When you did the CREATE USER within MariaDB, did you specify 'zabbix'@'your-zabbix-server-fqdn-here' as the user? Did you use the same 'zabbix'@'your-zabbix-server-fqdn-here' when you issued the GRANT statement?
      Is there a firewall active on your MariaDB server?
      • vincent1890
        • Nov 2020
        • 11
        Thank you for your reply @tim.mooney
        Unfortunately the MySQL user I think is not in question because as I said in my previous message (which was still not visible without moderation) when I manually create the conf php file everything works fine but I guess i would have to perform other manipulation to properly finish the installation.
