SOLVED!
SOLVED!
appliance@zabbix:~$ sudo /etc/init.d/zabbix-server stop * Stopping Zabbix server zabbix_server No process in pidfile '/var/run/zabbix/zabbix_server.pid' found running; none killed. ...done. appliance@zabbix:~$ appliance@zabbix:~$ ls /var/run/zabbix/ zabbix_agentd.pid zabbix_java_gateway.pid appliance@zabbix:~$ appliance@zabbix:~$ ps -aux | grep zabbix zabbix 1150 0.0 0.0 21308 1972 ? S 10:05 0:00 /usr/sbin/zabbix_agentd zabbix 1151 0.0 0.0 21308 2268 ? S 10:05 0:00 /usr/sbin/zabbix_agentd: collector [idle 1 sec] zabbix 1152 0.0 0.0 21308 3472 ? S 10:05 0:00 /usr/sbin/zabbix_agentd: listener #1 [waiting for connection] zabbix 1153 0.0 0.0 21308 3472 ? S 10:05 0:00 /usr/sbin/zabbix_agentd: listener #2 [waiting for connection] zabbix 1154 0.0 0.0 21308 3472 ? S 10:05 0:00 /usr/sbin/zabbix_agentd: listener #3 [waiting for connection] zabbix 1155 0.0 0.0 21308 4136 ? S 10:05 0:00 /usr/sbin/zabbix_agentd: active checks #1 [idle 1 sec] zabbix 1180 0.1 0.3 5448276 58948 ? Sl 10:05 0:02 java -server -Dlogback.configurationFile=/etc/zabbix/zabbix_java_gateway_logback.xml -classpath lib:lib/android-json-4.3_r3.1.jar:lib/logback-classic-0.9.27.jar:lib/logback-core-0.9.27.jar:lib/slf4j-api-1.6.1.jar:bin/zabbix-java-gateway-3.4.12.jar -Dzabbix.pidFile=/var/run/zabbix/zabbix_java_gateway.pid -Dzabbix.timeout=3 -Dsun.rmi.transport.tcp.responseTimeout=3000 com.zabbix.gateway.JavaGateway applian+ 1803 0.0 0.0 19652 2184 pts/0 S+ 10:41 0:00 grep --color=auto zabbix appliance@zabbix:~$
