Can't change ExternalScripts parameter
  • docent
    • Oct 2010
    • 26
    Hi!
    I have Zabbix 5.0.5.
    I'v changed parameters AlertScriptsPath and ExternalScripts in configuration file zabbix_server.conf to /etc/zabbix/alertscripts and /etc/zabbix/externalscripts respectively, but Zabbix still trying to open external scripts from the directory /usr/lib/zabbix/externalscripts. Alert scripts open from new path /etc/zabbix/alertscripts.
    ### Option: AlertScriptsPath
    # Full path to location of custom alert scripts.
    # Default depends on compilation options.
    # To see the default path run command "zabbix_server --help".
    # Mandatory: no
    # Default:
    # AlertScriptsPath=${datadir}/zabbix/alertscripts
    #AlertScriptsPath=/usr/lib/zabbix/alertscripts
    AlertScriptsPath=/etc/zabbix/alertscripts
    ### Option: ExternalScripts
    # Full path to location of external scripts.
    # Mandatory: no
    # Default:
    # ExternalScripts=${datadir}/zabbix/externalscripts
    #ExternalScripts=/usr/lib/zabbix/externalscripts
    ExternalScripts=/etc/zabbix/externalscripts
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Maybe you have specified ExternalScripts option multiple times?
    $ grep ExternalScripts /etc/zabbix/zabbix_server.conf
    • docent
      • Oct 2010
      • 26
      root@zbxa:/etc/zabbix# grep ExternalScripts /etc/zabbix/zabbix_server.conf
      • docent
        • Oct 2010
        • 26
        Sorry
        I found mistake.
        The proxy has been configured on this host
