I use Zabbix 2.2.7 on Centos 7.1.1503 (Core).
Today I was adding a custom template and when I went to restart the server the software crashed. Systemd reported "Job for zabbix-server-mysql.service failed", so it looks like problem is with zabbiz_server_mysql:
Yesterday I ran a yum update that updated my mysql server, client, and libraries. I'm assuming this could have caused the problem.
I've checked the most obvious things to my mind: the mysql server is running, the socket exists, I can connect with the zabbix user and password I've configured, the zabbix database and tables exist.
Attached below is the full trace from my server log. Any help would be most appreciated.
Cheers,
Adam
Unit zabbix-server-mysql.service entered failed state.
kernel: zabbix_server[6993]: segfault at 18 ip 00007fee4d960c00 sp 00007fff5fc3c4f8 error 4 in libpthread-2.17.so[7fee4d957000+16000]
Cheers,
Adam
6897:20150409:142632.871 Starting Zabbix Server. Zabbix 2.2.7 (revision 50148).
6897:20150409:142632.871 ****** Enabled features ******
6897:20150409:142632.871 SNMP monitoring: YES
6897:20150409:142632.871 IPMI monitoring: YES
6897:20150409:142632.871 WEB monitoring: YES
6897:20150409:142632.871 VMware monitoring: YES
6897:20150409:142632.871 Jabber notifications: YES
6897:20150409:142632.871 Ez Texting notifications: YES
6897:20150409:142632.871 ODBC: YES
6897:20150409:142632.871 SSH2 support: YES
6897:20150409:142632.871 IPv6 support: YES
6897:20150409:142632.871 ******************************
6897:20150409:142632.871 Got signal [signal:15(SIGTERM),sender_pid:1,sender_uid:0,reaso n:0]. Exiting ...
6897:20150409:142634.874 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x90]. Crashing ...
6897:20150409:142634.874 ====== Fatal information: ======
6897:20150409:142634.874 Program counter: 0x452145
6897:20150409:142634.874 === Registers: ===
6897:20150409:142634.874 r8 = 0 = 0 = 0
6897:20150409:142634.874 r9 = 0 = 0 = 0
6897:20150409:142634.874 r10 = 7fff0e358ca0 = 140733431778464 = 140733431778464
6897:20150409:142634.874 r11 = 246 = 582 = 582
6897:20150409:142634.874 r12 = 2354c70 = 37047408 = 37047408
6897:20150409:142634.874 r13 = 7616d8 = 7739096 = 7739096
6897:20150409:142634.874 r14 = 7df = 2015 = 2015
6897:20150409:142634.874 r15 = 9 = 9 = 9
6897:20150409:142634.874 rdi = 4 = 4 = 4
6897:20150409:142634.874 rsi = 4d16b0 = 5052080 = 5052080
6897:20150409:142634.874 rbp = 7fff0e359080 = 140733431779456 = 140733431779456
6897:20150409:142634.874 rbx = 1 = 1 = 1
6897:20150409:142634.874 rdx = 4d11e8 = 5050856 = 5050856
6897:20150409:142634.874 rax = 0 = 0 = 0
6897:20150409:142634.874 rcx = 0 = 0 = 0
6897:20150409:142634.874 rsp = 7fff0e345f80 = 140733431701376 = 140733431701376
6897:20150409:142634.874 rip = 452145 = 4530501 = 4530501
6897:20150409:142634.874 efl = 10246 = 66118 = 66118
6897:20150409:142634.874 csgsfs = 33 = 51 = 51
6897:20150409:142634.874 err = 4 = 4 = 4
6897:20150409:142634.874 trapno = e = 14 = 14
6897:20150409:142634.874 oldmask = 4000 = 16384 = 16384
6897:20150409:142634.874 cr2 = 90 = 144 = 144
6897:20150409:142634.874 === Backtrace: ===
6897:20150409:142634.875 16: /usr/sbin/zabbix_server(print_fatal_info+0x287) [0x46ca77]
6897:20150409:142634.875 15: /usr/sbin/zabbix_server() [0x46ccf6]
6897:20150409:142634.875 14: /lib64/libc.so.6(+0x35650) [0x7fe7ce3b8650]
6897:20150409:142634.875 13: /usr/sbin/zabbix_server(DCsync_history+0x45) [0x452145]
6897:20150409:142634.875 12: /usr/sbin/zabbix_server(free_database_cache+0x55) [0x455df5]
6897:20150409:142634.875 11: /usr/sbin/zabbix_server(zbx_on_exit+0x101) [0x419081]
6897:20150409:142634.875 10: /lib64/libc.so.6(+0x35650) [0x7fe7ce3b8650]
6897:20150409:142634.875 9: /lib64/libc.so.6(__write+0x10) [0x7fe7ce46a9e0]
6897:20150409:142634.875 8: /lib64/libc.so.6(_IO_file_write+0x43) [0x7fe7ce3f9e73]
6897:20150409:142634.875 7: /lib64/libc.so.6(_IO_do_write+0x7c) [0x7fe7ce3fb2dc]
6897:20150409:142634.875 6: /lib64/libc.so.6(_IO_file_close_it+0x170) [0x7fe7ce3fabd0]
6897:20150409:142634.875 5: /lib64/libc.so.6(fclose+0x180) [0x7fe7ce3eeb10]
6897:20150409:142634.875 4: /usr/sbin/zabbix_server(__zbx_zabbix_log+0x33e) [0x45019e]
6897:20150409:142634.875 3: /usr/sbin/zabbix_server(MAIN_ZABBIX_ENTRY+0x142) [0x419262]
6897:20150409:142634.875 2: /usr/sbin/zabbix_server(daemon_start+0x1c4) [0x46c044]
6897:20150409:142634.875 1: /lib64/libc.so.6(__libc_start_main+0xf5) [0x7fe7ce3a4af5]
6897:20150409:142634.875 0: /usr/sbin/zabbix_server() [0x414375]
6897:20150409:142634.875 === Memory map: ===
6897:20150409:142634.875 00400000-0050d000 r-xp 00000000 09:01 60558400 /usr/sbin/zabbix_server_mysql
6897:20150409:142634.875 0070d000-0075e000 r--p 0010d000 09:01 60558400 /usr/sbin/zabbix_server_mysql
6897:20150409:142634.875 0075e000-00762000 rw-p 0015e000 09:01 60558400 /usr/sbin/zabbix_server_mysql
6897:20150409:142634.875 00762000-00768000 rw-p 00000000 00:00 0
6897:20150409:142634.875 02330000-02374000 rw-p 00000000 00:00 0 [heap]
6897:20150409:142634.875 02374000-02393000 rw-p 00000000 00:00 0 [heap]
6897:20150409:142634.875 7fe7c8bff000-7fe7c8c0a000 r-xp 00000000 09:01 60557927 /usr/lib64/libnss_files-2.17.so
6897:20150409:142634.875 7fe7c8c0a000-7fe7c8e09000 ---p 0000b000 09:01 60557927 /usr/lib64/libnss_files-2.17.so
6897:20150409:142634.875 7fe7c8e09000-7fe7c8e0a000 r--p 0000a000 09:01 60557927 /usr/lib64/libnss_files-2.17.so
6897:20150409:142634.875 7fe7c8e0a000-7fe7c8e0b000 rw-p 0000b000 09:01 60557927 /usr/lib64/libnss_files-2.17.so
6897:20150409:142634.875 7fe7c8e0b000-7fe7c8e6a000 r-xp 00000000 09:01 60555878 /usr/lib64/libpcre.so.1.2.0
6897:20150409:142634.875 7fe7c8e6a000-7fe7c906a000 ---p 0005f000 09:01 60555878 /usr/lib64/libpcre.so.1.2.0
6897:20150409:142634.875 7fe7c906a000-7fe7c906b000 r--p 0005f000 09:01 60555878 /usr/lib64/libpcre.so.1.2.0
6897:20150409:142634.875 7fe7c906b000-7fe7c906c000 rw-p 00060000 09:01 60555878 /usr/lib64/libpcre.so.1.2.0
6897:20150409:142634.875 7fe7c906c000-7fe7c906e000 r-xp 00000000 09:01 60555819 /usr/lib64/libfreebl3.so
6897:20150409:142634.875 7fe7c906e000-7fe7c926d000 ---p 00002000 09:01 60555819 /usr/lib64/libfreebl3.so
6897:20150409:142634.875 7fe7c926d000-7fe7c926e000 r--p 00001000 09:01 60555819 /usr/lib64/libfreebl3.so
6897:20150409:142634.875 7fe7c926e000-7fe7c926f000 rw-p 00002000 09:01 60555819 /usr/lib64/libfreebl3.so
6897:20150409:142634.875 7fe7c926f000-7fe7c9290000 r-xp 00000000 09:01 60555889 /usr/lib64/libselinux.so.1
6897:20150409:142634.875 7fe7c9290000-7fe7c9490000 ---p 00021000 09:01 60555889 /usr/lib64/libselinux.so.1
6897:20150409:142634.875 7fe7c9490000-7fe7c9491000 r--p 00021000 09:01 60555889 /usr/lib64/libselinux.so.1
6897:20150409:142634.875 7fe7c9491000-7fe7c9492000 rw-p 00022000 09:01 60555889 /usr/lib64/libselinux.so.1
6897:20150409:142634.875 7fe7c9492000-7fe7c9494000 rw-p 00000000 00:00 0
6897:20150409:142634.875 7fe7c9494000-7fe7c949b000 r-xp 00000000 09:01 60556376 /usr/lib64/libffi.so.6.0.1
6897:20150409:142634.875 7fe7c949b000-7fe7c969a000 ---p 00007000 09:01 60556376 /usr/lib64/libffi.so.6.0.1
6897:20150409:142634.875 7fe7c969a000-7fe7c969b000 r--p 00006000 09:01 60556376 /usr/lib64/libffi.so.6.0.1
6897:20150409:142634.875 7fe7c969b000-7fe7c969c000 rw-p 00007000 09:01 60556376 /usr/lib64/libffi.so.6.0.1
6897:20150409:142634.875 7fe7c969c000-7fe7c96a3000 r-xp 00000000 09:01 60557939 /usr/lib64/librt-2.17.so
6897:20150409:142634.875 7fe7c96a3000-7fe7c98a2000 ---p 00007000 09:01 60557939 /usr/lib64/librt-2.17.so
6897:20150409:142634.875 7fe7c98a2000-7fe7c98a3000 r--p 00006000 09:01 60557939 /usr/lib64/librt-2.17.so
6897:20150409:142634.875 7fe7c98a3000-7fe7c98a4000 rw-p 00007000 09:01 60557939 /usr/lib64/librt-2.17.so
6897:20150409:142634.875 7fe7c98a4000-7fe7c98ac000 r-xp 00000000 09:01 60557490 /usr/lib64/libcrypt-2.17.so
6897:20150409:142634.875 7fe7c98ac000-7fe7c9aab000 ---p 00008000 09:01 60557490 /usr/lib64/libcrypt-2.17.so
6897:20150409:142634.875 7fe7c9aab000-7fe7c9aac000 r--p 00007000 09:01 60557490 /usr/lib64/libcrypt-2.17.so
6897:20150409:142634.876 7fe7c9aac000-7fe7c9aad000 rw-p 00008000 09:01 60557490 /usr/lib64/libcrypt-2.17.so
6897:20150409:142634.876 7fe7c9aad000-7fe7c9adb000 rw-p 00000000 00:00 0
6897:20150409:142634.876 7fe7c9adb000-7fe7c9ade000 r-xp 00000000 09:01 60556039 /usr/lib64/libkeyutils.so.1.5
6897:20150409:142634.876 7fe7c9ade000-7fe7c9cdd000 ---p 00003000 09:01 60556039 /usr/lib64/libkeyutils.so.1.5
6897:20150409:142634.876 7fe7c9cdd000-7fe7c9cde000 r--p 00002000 09:01 60556039 /usr/lib64/libkeyutils.so.1.5
6897:20150409:142634.876 7fe7c9cde000-7fe7c9cdf000 rw-p 00003000 09:01 60556039 /usr/lib64/libkeyutils.so.1.5
6897:20150409:142634.876 7fe7c9cdf000-7fe7c9cec000 r-xp 00000000 09:01 60558487 /usr/lib64/libkrb5support.so.0.1
6897:20150409:142634.876 7fe7c9cec000-7fe7c9eec000 ---p 0000d000 09:01 60558487 /usr/lib64/libkrb5support.so.0.1
6897:20150409:142634.876 7fe7c9eec000-7fe7c9eed000 r--p 0000d000 09:01 60558487 /usr/lib64/libkrb5support.so.0.1
6897:20150409:142634.876 7fe7c9eed000-7fe7c9eee000 rw-p 0000e000 09:01 60558487 /usr/lib64/libkrb5support.so.0.1
6897:20150409:142634.876 7fe7c9eee000-7fe7c9f64000 r-xp 00000000 09:01 60556052 /usr/lib64/libgmp.so.10.2.0
6897:20150409:142634.876 7fe7c9f64000-7fe7ca163000 ---p 00076000 09:01 60556052 /usr/lib64/libgmp.so.10.2.0
6897:20150409:142634.876 7fe7ca163000-7fe7ca164000 r--p 00075000 09:01 60556052 /usr/lib64/libgmp.so.10.2.0
6897:20150409:142634.876 7fe7ca164000-7fe7ca165000 rw-p 00076000 09:01 60556052 /usr/lib64/libgmp.so.10.2.0
6897:20150409:142634.876 7fe7ca165000-7fe7ca18b000 r-xp 00000000 09:01 60558254 /usr/lib64/libhogweed.so.2.5
6897:20150409:142634.876 7fe7ca18b000-7fe7ca38a000 ---p 00026000 09:01 60558254 /usr/lib64/libhogweed.so.2.5
6897:20150409:142634.876 7fe7ca38a000-7fe7ca38b000 r--p 00025000 09:01 60558254 /usr/lib64/libhogweed.so.2.5
6897:20150409:142634.876 7fe7ca38b000-7fe7ca38c000 rw-p 00026000 09:01 60558254 /usr/lib64/libhogweed.so.2.5
6897:20150409:142634.876 7fe7ca38c000-7fe7ca3bb000 r-xp 00000000 09:01 60558256 /usr/lib64/libnettle.so.4.7
6897:20150409:142634.876 7fe7ca3bb000-7fe7ca5bb000 ---p 0002f000 09:01 60558256 /usr/lib64/libnettle.so.4.7
6897:20150409:142634.876 7fe7ca5bb000-7fe7ca5bc000 r--p 0002f000 09:01 60558256 /usr/lib64/libnettle.so.4.7
6897:20150409:142634.876 7fe7ca5bc000-7fe7ca5bd000 rw-p 00030000 09:01 60558256 /usr/lib64/libnettle.so.4.7
6897:20150409:142634.876 7fe7ca5bd000-7fe7ca5cf000 r-xp 00000000 09:01 60556369 /usr/lib64/libtasn1.so.6.2.3
6897:20150409:142634.876 7fe7ca5cf000-7fe7ca7cf000 ---p 00012000 09:01 60556369 /usr/lib64/libtasn1.so.6.2.3
6897:20150409:142634.876 7fe7ca7cf000-7fe7ca7d0000 r--p 00012000 09:01 60556369 /usr/lib64/libtasn1.so.6.2.3
6897:20150409:142634.876 7fe7ca7d0000-7fe7ca7d1000 rw-p 00013000 09:01 60556369 /usr/lib64/libtasn1.so.6.2.3
6897:20150409:142634.876 7fe7ca7d1000-7fe7ca83e000 r-xp 00000000 09:01 60559329 /usr/lib64/libtspi.so.1.2.0
6897:20150409:142634.876 7fe7ca83e000-7fe7caa3d000 ---p 0006d000 09:01 60559329 /usr/lib64/libtspi.so.1.2.0
6897:20150409:142634.876 7fe7caa3d000-7fe7caa3e000 r--p 0006c000 09:01 60559329 /usr/lib64/libtspi.so.1.2.0
6897:20150409:142634.876 7fe7caa3e000-7fe7caa40000 rw-p 0006d000 09:01 60559329 /usr/lib64/libtspi.so.1.2.0
6897:20150409:142634.876 7fe7caa40000-7fe7caa41000 rw-p 00000000 00:00 0
6897:20150409:142634.876 7fe7caa41000-7fe7caa7d000 r-xp 00000000 09:01 60557207 /usr/lib64/libp11-kit.so.0.0.0
6897:20150409:142634.876 7fe7caa7d000-7fe7cac7c000 ---p 0003c000 09:01 60557207 /usr/lib64/libp11-kit.so.0.0.0
6897:20150409:142634.876 7fe7cac7c000-7fe7cac85000 r--p 0003b000 09:01 60557207 /usr/lib64/libp11-kit.so.0.0.0
6897:20150409:142634.876 7fe7cac85000-7fe7cac87000 rw-p 00044000 09:01 60557207 /usr/lib64/libp11-kit.so.0.0.0
6897:20150409:142634.876 7fe7cac87000-7fe7cacb9000 r-xp 00000000 09:01 60556094 /usr/lib64/libidn.so.11.6.11
6897:20150409:142634.876 7fe7cacb9000-7fe7caeb8000 ---p 00032000 09:01 60556094 /usr/lib64/libidn.so.11.6.11
6897:20150409:142634.876 7fe7caeb8000-7fe7caeb9000 r--p 00031000 09:01 60556094 /usr/lib64/libidn.so.11.6.11
6897:20150409:142634.876 7fe7caeb9000-7fe7caeba000 rw-p 00032000 09:01 60556094 /usr/lib64/libidn.so.11.6.11
6897:20150409:142634.876 7fe7caeba000-7fe7caef4000 r-xp 00000000 09:01 60558957 /usr/lib64/libnspr4.so
6897:20150409:142634.876 7fe7caef4000-7fe7cb0f3000 ---p 0003a000 09:01 60558957 /usr/lib64/libnspr4.so
6897:20150409:142634.876 7fe7cb0f3000-7fe7cb0f4000 r--p 00039000 09:01 60558957 /usr/lib64/libnspr4.so
6897:20150409:142634.876 7fe7cb0f4000-7fe7cb0f6000 rw-p 0003a000 09:01 60558957 /usr/lib64/libnspr4.so
6897:20150409:142634.876 7fe7cb0f6000-7fe7cb0f8000 rw-p 00000000 00:00 0
6897:20150409:142634.876 7fe7cb0f8000-7fe7cb0fc000 r-xp 00000000 09:01 60558958 /usr/lib64/libplc4.so
6897:20150409:142634.876 7fe7cb0fc000-7fe7cb2fb000 ---p 00004000 09:01 60558958 /usr/lib64/libplc4.so
6897:20150409:142634.876 7fe7cb2fb000-7fe7cb2fc000 r--p 00003000 09:01 60558958 /usr/lib64/libplc4.so
6897:20150409:142634.876 7fe7cb2fc000-7fe7cb2fd000 rw-p 00004000 09:01 60558958 /usr/lib64/libplc4.so
6897:20150409:142634.876 7fe7cb2fd000-7fe7cb300000 r-xp 00000000 09:01 60558959 /usr/lib64/libplds4.so
6897:20150409:142634.876 7fe7cb300000-7fe7cb4ff000 ---p 00003000 09:01 60558959 /usr/lib64/libplds4.so
6897:20150409:142634.876 7fe7cb4ff000-7fe7cb500000 r--p 00002000 09:01 60558959 /usr/lib64/libplds4.so
6897:20150409:142634.876 7fe7cb500000-7fe7cb501000 rw-p 00003000 09:01 60558959 /usr/lib64/libplds4.so
6897:20150409:142634.876 7fe7cb501000-7fe7cb526000 r-xp 00000000 09:01 60558960 /usr/lib64/libnssutil3.so
6897:20150409:142634.876 7fe7cb526000-7fe7cb726000 ---p 00025000 09:01 60558960 /usr/lib64/libnssutil3.so
6897:20150409:142634.876 7fe7cb726000-7fe7cb72c000 r--p 00025000 09:01 60558960 /usr/lib64/libnssutil3.so
6897:20150409:142634.876 7fe7cb72c000-7fe7cb72d000 rw-p 0002b000 09:01 60558960 /usr/lib64/libnssutil3.so
6897:20150409:142634.876 7fe7cb72d000-7fe7cb84a000 r-xp 00000000 09:01 60559173 /usr/lib64/libnss3.so
6897:20150409:142634.876 7fe7cb84a000-7fe7cba49000 ---p 0011d000 09:01 60559173 /usr/lib64/libnss3.so
6897:20150409:142634.877 7fe7cba49000-7fe7cba4e000 r--p 0011c000 09:01 60559173 /usr/lib64/libnss3.so
6897:20150409:142634.877 7fe7cba4e000-7fe7cba50000 rw-p 00121000 09:01 60559173 /usr/lib64/libnss3.so
6897:20150409:142634.877 7fe7cba50000-7fe7cba52000 rw-p 00000000 00:00 0
6897:20150409:142634.877 7fe7cba52000-7fe7cba76000 r-xp 00000000 09:01 60559175 /usr/lib64/libsmime3.so
6897:20150409:142634.877 7fe7cba76000-7fe7cbc75000 ---p 00024000 09:01 60559175 /usr/lib64/libsmime3.so
6897:20150409:142634.877 7fe7cbc75000-7fe7cbc78000 r--p 00023000 09:01 60559175 /usr/lib64/libsmime3.so
6897:20150409:142634.877 7fe7cbc78000-7fe7cbc79000 rw-p 00026000 09:01 60559175 /usr/lib64/libsmime3.so
6897:20150409:142634.877 7fe7cbc79000-7fe7cbcb3000 r-xp 00000000 09:01 60559176 /usr/lib64/libssl3.so
6897:20150409:142634.877 7fe7cbcb3000-7fe7cbeb2000 ---p 0003a000 09:01 60559176 /usr/lib64/libssl3.so
6897:20150409:142634.877 7fe7cbeb2000-7fe7cbeb5000 r--p 00039000 09:01 60559176 /usr/lib64/libssl3.so
6897:20150409:142634.877 7fe7cbeb5000-7fe7cbeb6000 rw-p 0003c000 09:01 60559176 /usr/lib64/libssl3.so
6897:20150409:142634.877 7fe7cbeb6000-7fe7cbeb7000 rw-p 00000000 00:00 0
6897:20150409:142634.877 7fe7cbeb7000-7fe7cbed3000 r-xp 00000000 09:01 60556122 /usr/lib64/libsasl2.so.3.0.0
6897:20150409:142634.877 7fe7cbed3000-7fe7cc0d2000 ---p 0001c000 09:01 60556122 /usr/lib64/libsasl2.so.3.0.0
6897:20150409:142634.877 7fe7cc0d2000-7fe7cc0d3000 r--p 0001b000 09:01 60556122 /usr/lib64/libsasl2.so.3.0.0
6897:20150409:142634.877 7fe7cc0d3000-7fe7cc0d4000 rw-p 0001c000 09:01 60556122 /usr/lib64/libsasl2.so.3.0.0
6897:20150409:142634.877 7fe7cc0d4000-7fe7cc0db000 r-xp 00000000 09:01 60556257 /usr/lib64/libgdbm.so.4.0.0
6897:20150409:142634.877 7fe7cc0db000-7fe7cc2db000 ---p 00007000 09:01 60556257 /usr/lib64/libgdbm.so.4.0.0
6897:20150409:142634.877 7fe7cc2db000-7fe7cc2dc000 r--p 00007000 09:01 60556257 /usr/lib64/libgdbm.so.4.0.0
6897:20150409:142634.877 7fe7cc2dc000-7fe7cc2dd000 rw-p 00008000 09:01 60556257 /usr/lib64/libgdbm.so.4.0.0
6897:20150409:142634.877 7fe7cc2dd000-7fe7cc2e5000 r-xp 00000000 09:01 60558394 /usr/lib64/libOpenIPMIutils.so.0.0.1
6897:20150409:142634.877 7fe7cc2e5000-7fe7cc4e4000 ---p 00008000 09:01 60558394 /usr/lib64/libOpenIPMIutils.so.0.0.1
6897:20150409:142634.877 7fe7cc4e4000-7fe7cc4e5000 r--p 00007000 09:01 60558394 /usr/lib64/libOpenIPMIutils.so.0.0.1
6897:20150409:142634.877 7fe7cc4e5000-7fe7cc4e6000 rw-p 00008000 09:01 60558394 /usr/lib64/libOpenIPMIutils.so.0.0.1
6897:20150409:142634.877 7fe7cc4e6000-7fe7cc515000 r-xp 00000000 09:01 60558479 /usr/lib64/libk5crypto.so.3.1
6897:20150409:142634.877 7fe7cc515000-7fe7cc714000 ---p 0002f000 09:01 60558479 /usr/lib64/libk5crypto.so.3.1
6897:20150409:142634.877 7fe7cc714000-7fe7cc716000 r--p 0002e000 09:01 60558479 /usr/lib64/libk5crypto.so.3.1
6897:20150409:142634.877 7fe7cc716000-7fe7cc717000 rw-p 00030000 09:01 60558479 /usr/lib64/libk5crypto.so.3.1
6897:20150409:142634.877 7fe7cc717000-7fe7cc718000 rw-p 00000000 00:00 0
6897:20150409:142634.877 7fe7cc718000-7fe7cc71b000 r-xp 00000000 09:01 60555899 /usr/lib64/libcom_err.so.2.1
6897:20150409:142634.877 7fe7cc71b000-7fe7cc91a000 ---p 00003000 09:01 60555899 /usr/lib64/libcom_err.so.2.1
6897:20150409:142634.877 7fe7cc91a000-7fe7cc91b000 r--p 00002000 09:01 60555899 /usr/lib64/libcom_err.so.2.1
6897:20150409:142634.877 7fe7cc91b000-7fe7cc91c000 rw-p 00003000 09:01 60555899 /usr/lib64/libcom_err.so.2.1
6897:20150409:142634.877 7fe7cc91c000-7fe7cc9ef000 r-xp 00000000 09:01 60558485 /usr/lib64/libkrb5.so.3.3
6897:20150409:142634.877 7fe7cc9ef000-7fe7ccbef000 ---p 000d3000 09:01 60558485 /usr/lib64/libkrb5.so.3.3
6897:20150409:142634.877 7fe7ccbef000-7fe7ccbfc000 r--p 000d3000 09:01 60558485 /usr/lib64/libkrb5.so.3.3
6897:20150409:142634.877 7fe7ccbfc000-7fe7ccbff000 rw-p 000e0000 09:01 60558485 /usr/lib64/libkrb5.so.3.3
6897:20150409:142634.877 7fe7ccbff000-7fe7ccc48000 r-xp 00000000 09:01 60558475 /usr/lib64/libgssapi_krb5.so.2.2
6897:20150409:142634.877 7fe7ccc48000-7fe7cce48000 ---p 00049000 09:01 60558475 /usr/lib64/libgssapi_krb5.so.2.2
6897:20150409:142634.877 7fe7cce48000-7fe7cce49000 r--p 00049000 09:01 60558475 /usr/lib64/libgssapi_krb5.so.2.2
6897:20150409:142634.877 7fe7cce49000-7fe7cce4b000 rw-p 0004a000 09:01 60558475 /usr/lib64/libgssapi_krb5.so.2.2
6897:20150409:142634.877 7fe7cce4b000-7fe7cce54000 r-xp 00000000 09:01 60557733 /usr/lib64/libltdl.so.7.3.0
6897:20150409:142634.877 7fe7cce54000-7fe7cd053000 ---p 00009000 09:01 60557733 /usr/lib64/libltdl.so.7.3.0
6897:20150409:142634.877 7fe7cd053000-7fe7cd054000 r--p 00008000 09:01 60557733 /usr/lib64/libltdl.so.7.3.0
6897:20150409:142634.877 7fe7cd054000-7fe7cd055000 rw-p 00009000 09:01 60557733 /usr/lib64/libltdl.so.7.3.0
6897:20150409:142634.877 7fe7cd055000-7fe7cd079000 r-xp 00000000 09:01 60555820 /usr/lib64/liblzma.so.5.0.99
6897:20150409:142634.877 7fe7cd079000-7fe7cd278000 ---p 00024000 09:01 60555820 /usr/lib64/liblzma.so.5.0.99
6897:20150409:142634.877 7fe7cd278000-7fe7cd279000 r--p 00023000 09:01 60555820 /usr/lib64/liblzma.so.5.0.99
6897:20150409:142634.877 7fe7cd279000-7fe7cd27a000 rw-p 00024000 09:01 60555820 /usr/lib64/liblzma.so.5.0.99
6897:20150409:142634.877 7fe7cd27a000-7fe7cd28f000 r-xp 00000000 09:01 60555892 /usr/lib64/libz.so.1.2.7
6897:20150409:142634.877 7fe7cd28f000-7fe7cd48e000 ---p 00015000 09:01 60555892 /usr/lib64/libz.so.1.2.7
6897:20150409:142634.877 7fe7cd48e000-7fe7cd48f000 r--p 00014000 09:01 60555892 /usr/lib64/libz.so.1.2.7
6897:20150409:142634.877 7fe7cd48f000-7fe7cd490000 rw-p 00015000 09:01 60555892 /usr/lib64/libz.so.1.2.7
6897:20150409:142634.877 7fe7cd490000-7fe7cd494000 r-xp 00000000 09:01 60556006 /usr/lib64/libgpg-error.so.0.10.0
6897:20150409:142634.877 7fe7cd494000-7fe7cd693000 ---p 00004000 09:01 60556006 /usr/lib64/libgpg-error.so.0.10.0
6897:20150409:142634.877 7fe7cd693000-7fe7cd694000 r--p 00003000 09:01 60556006 /usr/lib64/libgpg-error.so.0.10.0
6897:20150409:142634.877 7fe7cd694000-7fe7cd695000 rw-p 00004000 09:01 60556006 /usr/lib64/libgpg-error.so.0.10.0
6897:20150409:142634.878 7fe7cd695000-7fe7cd712000 r-xp 00000000 09:01 60556014 /usr/lib64/libgcrypt.so.11.8.2
6897:20150409:142634.878 7fe7cd712000-7fe7cd911000 ---p 0007d000 09:01 60556014 /usr/lib64/libgcrypt.so.11.8.2
6897:20150409:142634.878 7fe7cd911000-7fe7cd912000 r--p 0007c000 09:01 60556014 /usr/lib64/libgcrypt.so.11.8.2
6897:20150409:142634.878 7fe7cd912000-7fe7cd915000 rw-p 0007d000 09:01 60556014 /usr/lib64/libgcrypt.so.11.8.2
6897:20150409:142634.878 7fe7cd915000-7fe7cd916000 rw-p 00000000 00:00 0
6897:20150409:142634.878 7fe7cd916000-7fe7cda3e000 r-xp 00000000 09:01 60558261 /usr/lib64/libgnutls.so.28.41.0
6897:20150409:142634.878 7fe7cda3e000-7fe7cdc3d000 ---p 00128000 09:01 60558261 /usr/lib64/libgnutls.so.28.41.0
6897:20150409:142634.878 7fe7cdc3d000-7fe7cdc47000 r--p 00127000 09:01 60558261 /usr/lib64/libgnutls.so.28.41.0
6897:20150409:142634.878 7fe7cdc47000-7fe7cdc4a000 rw-p 00131000 09:01 60558261 /usr/lib64/libgnutls.so.28.41.0
6897:20150409:142634.878 7fe7cdc4a000-7fe7cdc5f000 r-xp 00000000 09:01 60558841 /usr/lib64/libgcc_s-4.8.3-20140911.so.1
6897:20150409:142634.878 7fe7cdc5f000-7fe7cde5e000 ---p 00015000 09:01 60558841 /usr/lib64/libgcc_s-4.8.3-20140911.so.1
6897:20150409:142634.878 7fe7cde5e000-7fe7cde5f000 r--p 00014000 09:01 60558841 /usr/lib64/libgcc_s-4.8.3-20140911.so.1
6897:20150409:142634.878 7fe7cde5f000-7fe7cde60000 rw-p 00015000 09:01 60558841 /usr/lib64/libgcc_s-4.8.3-20140911.so.1
6897:20150409:142634.878 7fe7cde60000-7fe7cdf49000 r-xp 00000000 09:01 60555822 /usr/lib64/libstdc++.so.6.0.19
6897:20150409:142634.878 7fe7cdf49000-7fe7ce148000 ---p 000e9000 09:01 60555822 /usr/lib64/libstdc++.so.6.0.19
6897:20150409:142634.878 7fe7ce148000-7fe7ce150000 r--p 000e8000 09:01 60555822 /usr/lib64/libstdc++.so.6.0.19
6897:20150409:142634.878 7fe7ce150000-7fe7ce152000 rw-p 000f0000 09:01 60555822 /usr/lib64/libstdc++.so.6.0.19
6897:20150409:142634.878 7fe7ce152000-7fe7ce167000 rw-p 00000000 00:00 0
6897:20150409:142634.878 7fe7ce167000-7fe7ce17d000 r-xp 00000000 09:01 60557935 /usr/lib64/libpthread-2.17.so
6897:20150409:142634.878 7fe7ce17d000-7fe7ce37d000 ---p 00016000 09:01 60557935 /usr/lib64/libpthread-2.17.so
6897:20150409:142634.878 7fe7ce37d000-7fe7ce37e000 r--p 00016000 09:01 60557935 /usr/lib64/libpthread-2.17.so
6897:20150409:142634.878 7fe7ce37e000-7fe7ce37f000 rw-p 00017000 09:01 60557935 /usr/lib64/libpthread-2.17.so
6897:20150409:142634.878 7fe7ce37f000-7fe7ce383000 rw-p 00000000 00:00 0
6897:20150409:142634.878 7fe7ce383000-7fe7ce539000 r-xp 00000000 09:01 60557285 /usr/lib64/libc-2.17.so
6897:20150409:142634.878 7fe7ce539000-7fe7ce739000 ---p 001b6000 09:01 60557285 /usr/lib64/libc-2.17.so
6897:20150409:142634.878 7fe7ce739000-7fe7ce73d000 r--p 001b6000 09:01 60557285 /usr/lib64/libc-2.17.so
6897:20150409:142634.878 7fe7ce73d000-7fe7ce73f000 rw-p 001ba000 09:01 60557285 /usr/lib64/libc-2.17.so
6897:20150409:142634.878 7fe7ce73f000-7fe7ce744000 rw-p 00000000 00:00 0
6897:20150409:142634.878 7fe7ce744000-7fe7ce75a000 r-xp 00000000 09:01 60557937 /usr/lib64/libresolv-2.17.so
6897:20150409:142634.878 7fe7ce75a000-7fe7ce95a000 ---p 00016000 09:01 60557937 /usr/lib64/libresolv-2.17.so
6897:20150409:142634.878 7fe7ce95a000-7fe7ce95b000 r--p 00016000 09:01 60557937 /usr/lib64/libresolv-2.17.so
6897:20150409:142634.878 7fe7ce95b000-7fe7ce95c000 rw-p 00017000 09:01 60557937 /usr/lib64/libresolv-2.17.so
6897:20150409:142634.878 7fe7ce95c000-7fe7ce95e000 rw-p 00000000 00:00 0
6897:20150409:142634.878 7fe7ce95e000-7fe7ce961000 r-xp 00000000 09:01 60557859 /usr/lib64/libdl-2.17.so
6897:20150409:142634.878 7fe7ce961000-7fe7ceb60000 ---p 00003000 09:01 60557859 /usr/lib64/libdl-2.17.so
6897:20150409:142634.878 7fe7ceb60000-7fe7ceb61000 r--p 00002000 09:01 60557859 /usr/lib64/libdl-2.17.so
6897:20150409:142634.878 7fe7ceb61000-7fe7ceb62000 rw-p 00003000 09:01 60557859 /usr/lib64/libdl-2.17.so
6897:20150409:142634.878 7fe7ceb62000-7fe7cebc5000 r-xp 00000000 09:01 60557478 /usr/lib64/libcurl.so.4.3.0
6897:20150409:142634.878 7fe7cebc5000-7fe7cedc4000 ---p 00063000 09:01 60557478 /usr/lib64/libcurl.so.4.3.0
6897:20150409:142634.878 7fe7cedc4000-7fe7cedc6000 r--p 00062000 09:01 60557478 /usr/lib64/libcurl.so.4.3.0
6897:20150409:142634.878 7fe7cedc6000-7fe7cedc7000 rw-p 00064000 09:01 60557478 /usr/lib64/libcurl.so.4.3.0
6897:20150409:142634.878 7fe7cedc7000-7fe7cedd5000 r-xp 00000000 09:01 60556566 /usr/lib64/liblber-2.4.so.2.10.2
6897:20150409:142634.878 7fe7cedd5000-7fe7cefd4000 ---p 0000e000 09:01 60556566 /usr/lib64/liblber-2.4.so.2.10.2
6897:20150409:142634.878 7fe7cefd4000-7fe7cefd5000 r--p 0000d000 09:01 60556566 /usr/lib64/liblber-2.4.so.2.10.2
6897:20150409:142634.878 7fe7cefd5000-7fe7cefd6000 rw-p 0000e000 09:01 60556566 /usr/lib64/liblber-2.4.so.2.10.2
6897:20150409:142634.878 7fe7cefd6000-7fe7cf025000 r-xp 00000000 09:01 60558495 /usr/lib64/libldap-2.4.so.2.10.2
6897:20150409:142634.878 7fe7cf025000-7fe7cf224000 ---p 0004f000 09:01 60558495 /usr/lib64/libldap-2.4.so.2.10.2
6897:20150409:142634.878 7fe7cf224000-7fe7cf226000 r--p 0004e000 09:01 60558495 /usr/lib64/libldap-2.4.so.2.10.2
6897:20150409:142634.878 7fe7cf226000-7fe7cf228000 rw-p 00050000 09:01 60558495 /usr/lib64/libldap-2.4.so.2.10.2
6897:20150409:142634.878 7fe7cf228000-7fe7cf22d000 r-xp 00000000 09:01 60558385 /usr/lib64/libOpenIPMIposix.so.0.0.1
6897:20150409:142634.878 7fe7cf22d000-7fe7cf42c000 ---p 00005000 09:01 60558385 /usr/lib64/libOpenIPMIposix.so.0.0.1
6897:20150409:142634.878 7fe7cf42c000-7fe7cf42d000 r--p 00004000 09:01 60558385 /usr/lib64/libOpenIPMIposix.so.0.0.1
6897:20150409:142634.878 7fe7cf42d000-7fe7cf42e000 rw-p 00005000 09:01 60558385 /usr/lib64/libOpenIPMIposix.so.0.0.1
6897:20150409:142634.878 7fe7cf42e000-7fe7cf51b000 r-xp 00000000 09:01 60558377 /usr/lib64/libOpenIPMI.so.0.0.5
6897:20150409:142634.878 7fe7cf51b000-7fe7cf71b000 ---p 000ed000 09:01 60558377 /usr/lib64/libOpenIPMI.so.0.0.5
6897:20150409:142634.878 7fe7cf71b000-7fe7cf731000 r--p 000ed000 09:01 60558377 /usr/lib64/libOpenIPMI.so.0.0.5
6897:20150409:142634.878 7fe7cf731000-7fe7cf737000 rw-p 00103000 09:01 60558377 /usr/lib64/libOpenIPMI.so.0.0.5
6897:20150409:142634.878 7fe7cf737000-7fe7cf73b000 rw-p 00000000 00:00 0
6897:20150409:142634.879 7fe7cf73b000-7fe7cf763000 r-xp 00000000 09:01 60557477 /usr/lib64/libssh2.so.1.0.1
6897:20150409:142634.879 7fe7cf763000-7fe7cf963000 ---p 00028000 09:01 60557477 /usr/lib64/libssh2.so.1.0.1
6897:20150409:142634.879 7fe7cf963000-7fe7cf964000 r--p 00028000 09:01 60557477 /usr/lib64/libssh2.so.1.0.1
6897:20150409:142634.879 7fe7cf964000-7fe7cf965000 rw-p 00029000 09:01 60557477 /usr/lib64/libssh2.so.1.0.1
6897:20150409:142634.879 7fe7cf965000-7fe7cfa66000 r-xp 00000000 09:01 60557908 /usr/lib64/libm-2.17.so
6897:20150409:142634.879 7fe7cfa66000-7fe7cfc65000 ---p 00101000 09:01 60557908 /usr/lib64/libm-2.17.so
6897:20150409:142634.879 7fe7cfc65000-7fe7cfc66000 r--p 00100000 09:01 60557908 /usr/lib64/libm-2.17.so
6897:20150409:142634.879 7fe7cfc66000-7fe7cfc67000 rw-p 00101000 09:01 60557908 /usr/lib64/libm-2.17.so
6897:20150409:142634.879 7fe7cfc67000-7fe7cfe24000 r-xp 00000000 09:01 60557472 /usr/lib64/libcrypto.so.1.0.1e
6897:20150409:142634.879 7fe7cfe24000-7fe7d0024000 ---p 001bd000 09:01 60557472 /usr/lib64/libcrypto.so.1.0.1e
6897:20150409:142634.879 7fe7d0024000-7fe7d003e000 r--p 001bd000 09:01 60557472 /usr/lib64/libcrypto.so.1.0.1e
6897:20150409:142634.879 7fe7d003e000-7fe7d004a000 rw-p 001d7000 09:01 60557472 /usr/lib64/libcrypto.so.1.0.1e
6897:20150409:142634.879 7fe7d004a000-7fe7d004e000 rw-p 00000000 00:00 0
6897:20150409:142634.879 7fe7d004e000-7fe7d00b0000 r-xp 00000000 09:01 60557950 /usr/lib64/libssl.so.1.0.1e
6897:20150409:142634.879 7fe7d00b0000-7fe7d02b0000 ---p 00062000 09:01 60557950 /usr/lib64/libssl.so.1.0.1e
6897:20150409:142634.879 7fe7d02b0000-7fe7d02b4000 r--p 00062000 09:01 60557950 /usr/lib64/libssl.so.1.0.1e
6897:20150409:142634.879 7fe7d02b4000-7fe7d02bb000 rw-p 00066000 09:01 60557950 /usr/lib64/libssl.so.1.0.1e
6897:20150409:142634.879 7fe7d02bb000-7fe7d0383000 r-xp 00000000 09:01 60558395 /usr/lib64/libnetsnmp.so.31.0.2
6897:20150409:142634.879 7fe7d0383000-7fe7d0582000 ---p 000c8000 09:01 60558395 /usr/lib64/libnetsnmp.so.31.0.2
6897:20150409:142634.879 7fe7d0582000-7fe7d0585000 r--p 000c7000 09:01 60558395 /usr/lib64/libnetsnmp.so.31.0.2
6897:20150409:142634.879 7fe7d0585000-7fe7d0587000 rw-p 000ca000 09:01 60558395 /usr/lib64/libnetsnmp.so.31.0.2
6897:20150409:142634.879 7fe7d0587000-7fe7d05bd000 rw-p 00000000 00:00 0
6897:20150409:142634.879 7fe7d05bd000-7fe7d061d000 r-xp 00000000 09:01 60558288 /usr/lib64/libodbc.so.2.0.0
6897:20150409:142634.879 7fe7d061d000-7fe7d081c000 ---p 00060000 09:01 60558288 /usr/lib64/libodbc.so.2.0.0
6897:20150409:142634.879 7fe7d081c000-7fe7d081d000 r--p 0005f000 09:01 60558288 /usr/lib64/libodbc.so.2.0.0
6897:20150409:142634.879 7fe7d081d000-7fe7d0824000 rw-p 00060000 09:01 60558288 /usr/lib64/libodbc.so.2.0.0
6897:20150409:142634.879 7fe7d0824000-7fe7d0825000 rw-p 00000000 00:00 0
6897:20150409:142634.879 7fe7d0825000-7fe7d0983000 r-xp 00000000 09:01 60556036 /usr/lib64/libxml2.so.2.9.1
6897:20150409:142634.879 7fe7d0983000-7fe7d0b82000 ---p 0015e000 09:01 60556036 /usr/lib64/libxml2.so.2.9.1
6897:20150409:142634.879 7fe7d0b82000-7fe7d0b8a000 r--p 0015d000 09:01 60556036 /usr/lib64/libxml2.so.2.9.1
6897:20150409:142634.879 7fe7d0b8a000-7fe7d0b8c000 rw-p 00165000 09:01 60556036 /usr/lib64/libxml2.so.2.9.1
6897:20150409:142634.879 7fe7d0b8c000-7fe7d0b8e000 rw-p 00000000 00:00 0
6897:20150409:142634.879 7fe7d0b8e000-7fe7d0b9b000 r-xp 00000000 09:01 60558271 /usr/lib64/libiksemel.so.3.1.1
6897:20150409:142634.879 7fe7d0b9b000-7fe7d0d9a000 ---p 0000d000 09:01 60558271 /usr/lib64/libiksemel.so.3.1.1
6897:20150409:142634.879 7fe7d0d9a000-7fe7d0d9b000 r--p 0000c000 09:01 60558271 /usr/lib64/libiksemel.so.3.1.1
6897:20150409:142634.879 7fe7d0d9b000-7fe7d0d9c000 rw-p 0000d000 09:01 60558271 /usr/lib64/libiksemel.so.3.1.1
6897:20150409:142634.879 7fe7d0d9c000-7fe7d109b000 r-xp 00000000 09:01 2099013 /usr/lib64/mysql/libmysqlclient.so.18.1.0
6897:20150409:142634.879 7fe7d109b000-7fe7d129a000 ---p 002ff000 09:01 2099013 /usr/lib64/mysql/libmysqlclient.so.18.1.0
6897:20150409:142634.879 7fe7d129a000-7fe7d12a0000 r--p 002fe000 09:01 2099013 /usr/lib64/mysql/libmysqlclient.so.18.1.0
6897:20150409:142634.879 7fe7d12a0000-7fe7d136d000 rw-p 00304000 09:01 2099013 /usr/lib64/mysql/libmysqlclient.so.18.1.0
6897:20150409:142634.879 7fe7d136d000-7fe7d1372000 rw-p 00000000 00:00 0
6897:20150409:142634.879 7fe7d1372000-7fe7d1393000 r-xp 00000000 09:01 60555810 /usr/lib64/ld-2.17.so
6897:20150409:142634.879 7fe7d156e000-7fe7d158a000 rw-p 00000000 00:00 0
6897:20150409:142634.879 7fe7d158f000-7fe7d1592000 rw-p 00000000 00:00 0
6897:20150409:142634.879 7fe7d1592000-7fe7d1593000 rw-p 00000000 00:00 0
6897:20150409:142634.879 7fe7d1593000-7fe7d1594000 r--p 00021000 09:01 60555810 /usr/lib64/ld-2.17.so
6897:20150409:142634.879 7fe7d1594000-7fe7d1595000 rw-p 00022000 09:01 60555810 /usr/lib64/ld-2.17.so
6897:20150409:142634.879 7fe7d1595000-7fe7d1596000 rw-p 00000000 00:00 0
6897:20150409:142634.879 7fff0e334000-7fff0e36c000 rw-p 00000000 00:00 0 [stack]
6897:20150409:142634.879 7fff0e3fe000-7fff0e400000 r-xp 00000000 00:00 0 [vdso]
6897:20150409:142634.879 ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
6897:20150409:142634.879 ================================
6897:20150409:142634.879 Please consider attaching a disassembly listing to your bug report.
6897:20150409:142634.879 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
