Good day,
I can't run zabbix 5.2 from the docker.
Warning during compose:
issue after docker containers start:
container 18613b78b22b error:
Steps to reproduce and log:
[root@centos8mindock ~]# sudo yum install -y docker-ce
Complete!
[root@centos8mindock ~]# sudo curl -L "https://github.com/docker/compose/releases/downloa d/1.27.4/docker-compose-$(uname -s)-$(uname -m)" -o /usr/local/bin/docker-compose
Complete!
[root@centos8mindock ~]# sudo systemctl enable docker
[root@centos8mindock ~]# sudo systemctl start docker
[root@centos8mindock ~]# sudo systemctl status docker
[root@centos8mindock ~]# git clone https://github.com/zabbix/zabbix-docker.git
[root@centos8mindock ~]# ls
[root@centos8mindock ~]# cd zabbix-docker/
[root@centos8mindock zabbix-docker]# ls -ahl
[root@centos8mindock zabbix-docker]# git checkout 5.2
Your branch is up to date with 'origin/5.2'.[/CODE]
[root@centos8mindock zabbix-docker]# docker-compose -f docker-compose_v3_alpine_mysql_lat est.yaml up -d
[root@centos8mindock zabbix-docker]# docker ps
[root@centos8mindock zabbix-docker]# docker inspect 18613b78b22b
[B]WARNING: The following deploy sub-keys are not supported and have been ignored: resources .reservations.cpus[/B]
18613b78b22b zabbix/zabbix-web-nginx-mysql:alpine-5.2-latest "docker-entrypoint.sh" 2 minutes ago Up 2 minutes ([B]unhealthy[/B]) 0.0.0.0:8443->8443/tcp, 0.0.0.0:8081->8080/tcp zabbix-docker_zabbix-web-nginx-mysql_1 3f0f9a675cc7 zabbix/zabbix-web-apache-mysql:alpine-5.2-latest "docker-entrypoint.s…" 2 minutes ago Up 2 minutes ([B]unhealthy[/B]) 0.0.0.0:80->8080/tcp, 0.0.0.0:443->8443/tcp zabbix-docker_zabbix-web-apache-mysql_1
"ExitCode": 7, "Output": " % Total % Received % Xferd Average Speed Time Time Time Current\n Dload Upload Total Spent Left Speed\n\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\ncurl: (7) Failed to connect to localhost port 8080: Connection refused\n"
Installed: checkpolicy-2.9-1.el8.x86_64 container-selinux-2:2.124.0-1.module_el8.2.0+305+5e198a41.noarch containerd.io-1.3.7-3.1.el8.x86_64 docker-ce-3:19.03.13-3.el8.x86_64 docker-ce-cli-1:19.03.13-3.el8.x86_64 libcgroup-0.41-19.el8.x86_64 policycoreutils-python-utils-2.9-9.el8.noarch python3-audit-3.0-0.17.20191104git1c2f876.el8.x86_64 python3-libsemanage-2.9-2.el8.x86_64 python3-policycoreutils-2.9-9.el8.noarch python3-setools-4.2.2-2.el8.x86_64
Installed: emacs-filesystem-1:26.1-5.el8.noarch git-2.18.4-2.el8_2.x86_64 git-core-2.18.4-2.el8_2.x86_64 git-core-doc-2.18.4-2.el8_2.noarch libsecret-0.18.6-1.el8.x86_64 perl-Carp-1.42-396.el8.noarch perl-Data-Dumper-2.167-399.el8.x86_64 perl-Digest-1.17-395.el8.noarch perl-Digest-MD5-2.55-396.el8.x86_64 perl-Encode-4:2.97-3.el8.x86_64 perl-Errno-1.28-416.el8.x86_64 perl-Error-1:0.17025-2.el8.noarch perl-Exporter-5.72-396.el8.noarch perl-File-Path-2.15-2.el8.noarch perl-File-Temp-0.230.600-1.el8.noarch perl-Getopt-Long-1:2.50-4.el8.noarch perl-Git-2.18.4-2.el8_2.noarch perl-HTTP-Tiny-0.074-1.el8.noarch perl-IO-1.38-416.el8.x86_64 perl-IO-Socket-IP-0.39-5.el8.noarch perl-IO-Socket-SSL-2.066-4.el8.noarch perl-MIME-Base64-3.15-396.el8.x86_64 perl-Mozilla-CA-20160104-7.el8.noarch perl-Net-SSLeay-1.88-1.el8.x86_64 perl-PathTools-3.74-1.el8.x86_64 perl-Pod-Escapes-1:1.07-395.el8.noarch perl-Pod-Perldoc-3.28-396.el8.noarch perl-Pod-Simple-1:3.35-395.el8.noarch perl-Pod-Usage-4:1.69-395.el8.noarch perl-Scalar-List-Utils-3:1.49-2.el8.x86_64 perl-Socket-4:2.027-3.el8.x86_64 perl-Storable-1:3.11-3.el8.x86_64 perl-Term-ANSIColor-4.06-396.el8.noarch perl-Term-Cap-1.17-395.el8.noarch perl-TermReadKey-2.37-7.el8.x86_64 perl-Text-ParseWords-3.30-395.el8.noarch perl-Text-Tabs+Wrap-2013.0523-395.el8.noarch perl-Time-Local-1:1.280-1.el8.noarch perl-URI-1.73-3.el8.noarch perl-Unicode-Normalize-1.25-396.el8.x86_64 perl-constant-1.33-396.el8.noarch perl-interpreter-4:5.26.3-416.el8.x86_64 perl-libnet-3.11-3.el8.noarch perl-libs-4:5.26.3-416.el8.x86_64 perl-macros-4:5.26.3-416.el8.x86_64 perl-parent-1:0.237-1.el8.noarch perl-podlators-4.11-1.el8.noarch perl-threads-1:2.21-2.el8.x86_64 perl-threads-shared-1.58-2.el8.x86_64
Created symlink /etc/systemd/system/multi-user.target.wants/docker.service → /usr/lib/sys temd/system/docker.service.
● docker.service - Docker Application Container Engine Loaded: loaded (/usr/lib/systemd/system/docker.service; enabled; vendor preset: disab> Active: [B]active [/B](running) since Thu 2020-11-12 08:56:58 EST; 7s ago Docs: https://docs.docker.com Main PID: 8969 (dockerd) Tasks: 8 Memory: 135.8M CGroup: /system.slice/docker.service └─8969 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock Nov 12 08:56:57 centos8mindock dockerd[8969]: time="2020-11-12T08:56:57.208521683-05:00"> Nov 12 08:56:57 centos8mindock dockerd[8969]: time="2020-11-12T08:56:57.263392025-05:00"> Nov 12 08:56:57 centos8mindock dockerd[8969]: time="2020-11-12T08:56:57.263415364-05:00"> Nov 12 08:56:57 centos8mindock dockerd[8969]: time="2020-11-12T08:56:57.263517264-05:00"> Nov 12 08:56:57 centos8mindock dockerd[8969]: time="2020-11-12T08:56:57.640326268-05:00"> Nov 12 08:56:57 centos8mindock dockerd[8969]: time="2020-11-12T08:56:57.916467623-05:00"> Nov 12 08:56:57 centos8mindock dockerd[8969]: time="2020-11-12T08:56:57.968331944-05:00"> Nov 12 08:56:57 centos8mindock dockerd[8969]: time="2020-11-12T08:56:57.968481728-05:00"> Nov 12 08:56:58 centos8mindock dockerd[8969]: time="2020-11-12T08:56:58.016738777-05:00"> Nov 12 08:56:58 centos8mindock systemd[1]: Started Docker Application Container Engine. lines 1-20/20 (END)...skipping...
anaconda-ks.cfg zabbix-docker
total 268K drwxr-xr-x. 17 root root 4.0K Nov 12 08:57 . dr-xr-x---. 3 root root 172 Nov 12 08:57 .. drwxr-xr-x. 5 root root 48 Nov 12 08:57 agent drwxr-xr-x. 3 root root 20 Nov 12 08:57 agent2 -rwxr-xr-x. 1 root root 1.6K Nov 12 08:57 build.sh -rw-r--r--. 1 root root 12K Nov 12 08:57 docker-compose_v3_alpine_mysql_latest.yaml -rw-r--r--. 1 root root 12K Nov 12 08:57 docker-compose_v3_alpine_mysql_local.yaml -rw-r--r--. 1 root root 12K Nov 12 08:57 docker-compose_v3_alpine_pgsql_latest.yaml -rw-r--r--. 1 root root 13K Nov 12 08:57 docker-compose_v3_alpine_pgsql_local.yaml -rw-r--r--. 1 root root 12K Nov 12 08:57 docker-compose_v3_centos_mysql_latest.yaml -rw-r--r--. 1 root root 12K Nov 12 08:57 docker-compose_v3_centos_mysql_local.yaml -rw-r--r--. 1 root root 12K Nov 12 08:57 docker-compose_v3_centos_pgsql_latest.yaml -rw-r--r--. 1 root root 13K Nov 12 08:57 docker-compose_v3_centos_pgsql_local.yaml -rw-r--r--. 1 root root 11K Nov 12 08:57 docker-compose_v3_ubuntu_mysql_latest.yaml -rw-r--r--. 1 root root 12K Nov 12 08:57 docker-compose_v3_ubuntu_mysql_local.yaml -rw-r--r--. 1 root root 12K Nov 12 08:57 docker-compose_v3_ubuntu_pgsql_latest.yaml -rw-r--r--. 1 root root 13K Nov 12 08:57 docker-compose_v3_ubuntu_pgsql_local.yaml -rw-r--r--. 1 root root 931 Nov 12 08:57 .env_agent -rw-r--r--. 1 root root 346 Nov 12 08:57 .env_db_mysql -rw-r--r--. 1 root root 433 Nov 12 08:57 .env_db_mysql_proxy -rw-r--r--. 1 root root 297 Nov 12 08:57 .env_db_pgsql -rw-r--r--. 1 root root 121 Nov 12 08:57 .env_java -rw-r--r--. 1 root root 1.9K Nov 12 08:57 .env_prx -rw-r--r--. 1 root root 34 Nov 12 08:57 .env_prx_mysql -rw-r--r--. 1 root root 36 Nov 12 08:57 .env_prx_sqlite3 -rw-r--r--. 1 root root 1.8K Nov 12 08:57 .env_srv -rw-r--r--. 1 root root 1.1K Nov 12 08:57 .env_web -rwxr-xr-x. 1 root root 1.2K Nov 12 08:57 generate-stackbrew-library.sh drwxr-xr-x. 8 root root 163 Nov 12 08:57 .git drwxr-xr-x. 3 root root 23 Nov 12 08:57 .github -rw-r--r--. 1 root root 52 Nov 12 08:57 .gitignore drwxr-xr-x. 5 root root 48 Nov 12 08:57 java-gateway -rw-r--r--. 1 root root 12K Nov 12 08:57 kubernetes.yaml -rw-r--r--. 1 root root 18K Nov 12 08:57 LICENSE -rw-r--r--. 1 root root 6 Nov 12 08:57 .MYSQL_PASSWORD -rw-r--r--. 1 root root 8 Nov 12 08:57 .MYSQL_ROOT_PASSWORD -rw-r--r--. 1 root root 6 Nov 12 08:57 .MYSQL_USER -rw-r--r--. 1 root root 6 Nov 12 08:57 .POSTGRES_PASSWORD -rw-r--r--. 1 root root 6 Nov 12 08:57 .POSTGRES_USER drwxr-xr-x. 5 root root 48 Nov 12 08:57 proxy-mysql drwxr-xr-x. 5 root root 48 Nov 12 08:57 proxy-sqlite3 -rw-r--r--. 1 root root 3.8K Nov 12 08:57 README.md drwxr-xr-x. 5 root root 48 Nov 12 08:57 server-mysql drwxr-xr-x. 5 root root 48 Nov 12 08:57 server-pgsql drwxr-xr-x. 5 root root 48 Nov 12 08:57 snmptraps drwxr-xr-x. 5 root root 48 Nov 12 08:57 web-apache-mysql drwxr-xr-x. 5 root root 48 Nov 12 08:57 web-apache-pgsql drwxr-xr-x. 5 root root 48 Nov 12 08:57 web-nginx-mysql drwxr-xr-x. 5 root root 48 Nov 12 08:57 web-nginx-pgsql drwxr-xr-x. 3 root root 18 Nov 12 08:57 zabbix-appliance
[CODE]Already on '5.2'
[B]WARNING: The following deploy sub-keys are not supported and have been ignored: resources .reservations.cpus WARNING: The following deploy sub-keys are not supported and have been ignored: resources .reservations.cpus WARNING: The following deploy sub-keys are not supported and have been ignored: resources .reservations.cpus WARNING: The following deploy sub-keys are not supported and have been ignored: resources .reservations.cpus WARNING: The following deploy sub-keys are not supported and have been ignored: resources .reservations.cpus WARNING: The following deploy sub-keys are not supported and have been ignored: resources .reservations.cpus WARNING: The following deploy sub-keys are not supported and have been ignored: resources .reservations.cpus WARNING: The following deploy sub-keys are not supported and have been ignored: resources .reservations.cpus[/B] Creating network "zabbix-docker_zbx_net_backend" with driver "bridge" Creating network "zabbix-docker_zbx_net_frontend" with driver "bridge" Creating network "zabbix-docker_default" with the default driver Creating volume "zabbix-docker_snmptraps" with default driver Pulling zabbix-java-gateway (zabbix/zabbix-java-gateway:alpine-5.2-latest)... alpine-5.2-latest: Pulling from zabbix/zabbix-java-gateway 188c0c94c7c5: Pull complete ec4dd1fe2a8c: Pull complete 0ce0710d4bea: Pull complete 9c23a1f4dc37: Pull complete 6adb0299d44e: Pull complete bd66e0d99ed6: Pull complete 2185528abcd2: Pull complete Digest: sha256:e8d3a1164dc94b057860af751aa21d408233de42ad6 fdb1e5c6bdb93042e7ade Status: Downloaded newer image for zabbix/zabbix-java-gateway:alpine-5.2-latest Pulling zabbix-snmptraps (zabbix/zabbix-snmptraps:alpine-5.2-latest)... alpine-5.2-latest: Pulling from zabbix/zabbix-snmptraps 188c0c94c7c5: Already exists 3b34582952e4: Pull complete c8ef745f8708: Pull complete c0872882213b: Pull complete 4e1b92f82574: Pull complete 3b770dc26bcf: Pull complete Digest: sha256:c8aa616b71c56d797dc6e706f86df2287be1890ade2 c713f6441f0ad48462c9b Status: Downloaded newer image for zabbix/zabbix-snmptraps:alpine-5.2-latest Pulling mysql-server (mysql:8.0)... 8.0: Pulling from library/mysql bb79b6b2107f: Pull complete 49e22f6fb9f7: Pull complete 842b1255668c: Pull complete 9f48d1f43000: Pull complete c693f0615bce: Pull complete 8a621b9dbed2: Pull complete 0807d32aef13: Pull complete a56aca0feb17: Pull complete de9d45fd0f07: Pull complete 1d68a49161cc: Pull complete d16d318b774e: Pull complete 49e112c55976: Pull complete Digest: sha256:8c17271df53ee3b843d6e16d46cff13f22c9c04d698 2eb15a9a47bd5c9ac7e2d Status: Downloaded newer image for mysql:8.0 Pulling zabbix-server (zabbix/zabbix-server-mysql:alpine-5.2-latest)... alpine-5.2-latest: Pulling from zabbix/zabbix-server-mysql 188c0c94c7c5: Already exists 62267fc0ebf4: Pull complete 471b9c7ef9aa: Pull complete 94a27e8ae61f: Pull complete 660fcd6c1b23: Pull complete Digest: sha256:2f0f2bea3a1e085fb3d6b272593809a7c4edb35fb08 51b444012935fc83bd74c Status: Downloaded newer image for zabbix/zabbix-server-mysql:alpine-5.2-latest Pulling zabbix-agent (zabbix/zabbix-agent:alpine-5.2-latest)... alpine-5.2-latest: Pulling from zabbix/zabbix-agent 188c0c94c7c5: Already exists 0f92823922a9: Pull complete 669cc7d0b303: Pull complete 8c4ceb91b07c: Pull complete 0dd5f6cc258a: Pull complete Digest: sha256:eb84f2dfb20e66787d913324d274898f7cc300b1fed ea93115e85531e66b17cd Status: Downloaded newer image for zabbix/zabbix-agent:alpine-5.2-latest Pulling zabbix-web-nginx-mysql (zabbix/zabbix-web-nginx-mysql:alpine-5.2-latest)... alpine-5.2-latest: Pulling from zabbix/zabbix-web-nginx-mysql 188c0c94c7c5: Already exists 4e8ad07b9f3f: Pull complete 2b91e24fd160: Pull complete 1d2644fd262b: Pull complete 532837d1cf75: Pull complete 4321c3364ee2: Pull complete Digest: sha256:398cca6d7166734098bb4eb5ed8536bcd4c797a8ac8 e539ec40937db2b3f6d5f Status: Downloaded newer image for zabbix/zabbix-web-nginx-mysql:alpine-5.2-latest Pulling zabbix-web-apache-mysql (zabbix/zabbix-web-apache-mysql:alpine-5.2-latest)... alpine-5.2-latest: Pulling from zabbix/zabbix-web-apache-mysql 188c0c94c7c5: Already exists acc5ad415c2a: Pull complete 8f6e9501831e: Pull complete 8deb43763734: Pull complete 1ab253894aa3: Pull complete 37d006052cdf: Pull complete Digest: sha256:36e5957903b61f21a2ee4d23d893b8d1d78b798bab6 8bb9229e8664a43ae0d9c Status: Downloaded newer image for zabbix/zabbix-web-apache-mysql:alpine-5.2-latest Pulling zabbix-proxy-mysql (zabbix/zabbix-proxy-mysql:alpine-5.2-latest)... alpine-5.2-latest: Pulling from zabbix/zabbix-proxy-mysql 188c0c94c7c5: Already exists 9b01cac3b9f5: Pull complete b9b32e3f6e2d: Pull complete e6178bc646e2: Pull complete d0f0719779fc: Pull complete Digest: sha256:9fd786262f36480032f8ac2e0f441f41128ca594be5 237b024d9fd5b09881cf0 Status: Downloaded newer image for zabbix/zabbix-proxy-mysql:alpine-5.2-latest Pulling zabbix-proxy-sqlite3 (zabbix/zabbix-proxy-sqlite3:alpine-5.2-latest)... alpine-5.2-latest: Pulling from zabbix/zabbix-proxy-sqlite3 188c0c94c7c5: Already exists b7cce079dd86: Pull complete ecc424cb1ac1: Pull complete 7a71fd621eeb: Pull complete 59170ff0c351: Pull complete Digest: sha256:98935b7ed51d841b9e7fb97c7f97540d5ed169bb44f 1c3fb6db4fe4d74fd9cd8 Status: Downloaded newer image for zabbix/zabbix-proxy-sqlite3:alpine-5.2-latest Pulling db_data_mysql (busybox:)... latest: Pulling from library/busybox 9758c28807f2: Pull complete Digest: sha256:a9286defaba7b3a519d585ba0e37d0b2cbee74ebfe5 90960b0b1d6a5e97d1e1d Status: Downloaded newer image for busybox:latest Creating zabbix-docker_db_data_mysql_1 ... done Creating zabbix-docker_mysql-server_1 ... done Creating zabbix-docker_zabbix-snmptraps_1 ... done Creating zabbix-docker_zabbix-java-gateway_1 ... done Creating zabbix-docker_zabbix-server_1 ... done Creating zabbix-docker_zabbix-web-apache-mysql_1 ... done Creating zabbix-docker_zabbix-proxy-mysql_1 ... done Creating zabbix-docker_zabbix-agent_1 ... done Creating zabbix-docker_zabbix-proxy-sqlite3_1 ... done Creating zabbix-docker_zabbix-web-nginx-mysql_1 ... done
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 18613b78b22b zabbix/zabbix-web-nginx-mysql:alpine-5.2-latest "docker-entrypoint.sh" 2 minutes ago Up 2 minutes ([B]unhealthy[/B]) 0.0.0.0:8443->8443/tcp, 0.0.0.0:8081->8080/tcp zabbix-docker_zabbix-web-nginx-mysql_1 6c13436eefe9 zabbix/zabbix-proxy-mysql:alpine-5.2-latest "/sbin/tini -- /usr/…" 2 minutes ago Up 2 minutes 0.0.0.0:10071->10051/tcp zabbix-docker_zabbix-proxy-mysql_1 38710764ecc9 zabbix/zabbix-proxy-sqlite3:alpine-5.2-latest "/sbin/tini -- /usr/…" 2 minutes ago Up 2 minutes 0.0.0.0:10061->10051/tcp zabbix-docker_zabbix-proxy-sqlite3_1 3fc00255f0ab zabbix/zabbix-agent:alpine-5.2-latest "/sbin/tini -- /usr/…" 2 minutes ago Up 2 minutes zabbix-docker_zabbix-agent_1 3f0f9a675cc7 zabbix/zabbix-web-apache-mysql:alpine-5.2-latest "docker-entrypoint.s…" 2 minutes ago Up 2 minutes ([B]unhealthy[/B]) 0.0.0.0:80->8080/tcp, 0.0.0.0:443->8443/tcp zabbix-docker_zabbix-web-apache-mysql_1 4428da48c19c zabbix/zabbix-server-mysql:alpine-5.2-latest "/sbin/tini -- /usr/…" 2 minutes ago Up 2 minutes 0.0.0.0:10051->10051/tcp zabbix-docker_zabbix-server_1 b681c7fdffd2 zabbix/zabbix-snmptraps:alpine-5.2-latest "/usr/bin/supervisor…" 2 minutes ago Up 2 minutes 0.0.0.0:162->1162/udp zabbix-docker_zabbix-snmptraps_1 1f77be0b1df9 mysql:8.0 "docker-entrypoint.s…" 2 minutes ago Up 2 minutes zabbix-docker_mysql-server_1 aa8eea8d5ef0 zabbix/zabbix-java-gateway:alpine-5.2-latest "docker-entrypoint.s…" 2 minutes ago Up 2 minutes zabbix-docker_zabbix-java-gateway_1
"Id": "18613b78b22b42701126bfcde1a6518f40530649575eb313d 4731a058a74223a",
"Created": "2020-11-12T14:01:27.664538362Z",
"Path": "docker-entrypoint.sh",
"Args": [],
"State": {
"Status": "running",
"Running": true,
"Paused": false,
"Restarting": false,
"OOMKilled": false,
"Dead": false,
"Pid": 12059,
"ExitCode": 0,
"Error": "",
"StartedAt": "2020-11-12T14:01:37.424889127Z",
"FinishedAt": "0001-01-01T00:00:00Z",
"Health": {
"Status": "unhealthy",
"FailingStreak": 14,
"Log": [
"Start": "2020-11-12T09:03:47.634320645-05:00",
"End": "2020-11-12T09:03:48.377967158-05:00",
[B]"ExitCode": 7,
"Output": " % Total % Received % Xferd Average Speed Time Time Time Current\n Dload Upload Total Spent Left Speed\n\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\ncurl: (7) Failed to connect to localhost port 8080: Connection refused\n"[/B]
"Start": "2020-11-12T09:03:58.412184665-05:00",
"End": "2020-11-12T09:03:59.127510609-05:00",
"ExitCode": 7,
"Start": "2020-11-12T09:04:09.226513355-05:00",
"End": "2020-11-12T09:04:09.852368622-05:00",
"ExitCode": 7,
"Start": "2020-11-12T09:04:19.873123262-05:00",
"End": "2020-11-12T09:04:20.619911283-05:00",
"ExitCode": 7,
"Start": "2020-11-12T09:04:30.652517897-05:00",
"End": "2020-11-12T09:04:31.300676526-05:00",
"ExitCode": 7,
"Image": "sha256:735415509b848ac42649ddddcf7c3116155dcde476 e237e10de23201f7605168",
"ResolvConfPath": "/var/lib/docker/containers/18613b78b22b42701126bfcde1a6518f40530649575eb313d4 731a058a74223a/resolv.conf",
"HostnamePath": "/var/lib/docker/containers/18613b78b22b42701126bfcde1a6518f40530649575eb313d4 731a058a74223a/hostname",
"HostsPath": "/var/lib/docker/containers/18613b78b22b42701126bfcde1a6518f40530649575eb313d4 731a058a74223a/hosts",
"LogPath": "/var/lib/docker/containers/18613b78b22b42701126bfcde1a6518f40530649575eb313d4 731a058a74223a/18613b78b22b42701126bfcde1a6518f40530649575eb313d4 731a058a74223a-json.log",
"Name": "/zabbix-docker_zabbix-web-nginx-mysql_1",
"RestartCount": 0,
"Driver": "overlay2",
"Platform": "linux",
"MountLabel": "",
"ProcessLabel": "",
"AppArmorProfile": "",
"ExecIDs": null,
"HostConfig": {
"Binds": [
"/etc/timezone:/etc/timezone:ro",
"/root/zabbix-docker/zbx_env/etc/ssl/nginx:/etc/ssl/nginx:ro",
"/root/zabbix-docker/zbx_env/usr/share/zabbix/modules:/usr/share/zabbix/modules:ro",
"/etc/localtime:/etc/localtime:ro"
"ContainerIDFile": "",
"LogConfig": {
"Type": "json-file",
"Config": {}
"NetworkMode": "zabbix-docker_zbx_net_backend",
"PortBindings": {
"8080/tcp": [
"HostIp": "",
"HostPort": "8081"
"8443/tcp": [
"HostIp": "",
"HostPort": "8443"
"RestartPolicy": {
"Name": "",
"MaximumRetryCount": 0
"AutoRemove": false,
"VolumeDriver": "",
"VolumesFrom": [],
"CapAdd": null,
"CapDrop": null,
"Capabilities": null,
"Dns": null,
"DnsOptions": null,
"DnsSearch": null,
"ExtraHosts": null,
"GroupAdd": null,
"IpcMode": "private",
"Cgroup": "",
"Links": null,
"OomScoreAdj": 0,
"PidMode": "",
"Privileged": false,
"PublishAllPorts": false,
"ReadonlyRootfs": false,
"SecurityOpt": null,
"UTSMode": "",
"UsernsMode": "",
"ShmSize": 67108864,
"Sysctls": {
"net.core.somaxconn": "65535"
"Runtime": "runc",
"ConsoleSize": [
0,
0
"Isolation": "",
"CpuShares": 0,
"Memory": 536870912,
"NanoCpus": 700000000,
"CgroupParent": "",
"BlkioWeight": 0,
"BlkioWeightDevice": null,
"BlkioDeviceReadBps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteIOps": null,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpusetCpus": "",
"CpusetMems": "",
"Devices": null,
"DeviceCgroupRules": null,
"DeviceRequests": null,
"KernelMemory": 0,
"KernelMemoryTCP": 0,
"MemoryReservation": 268435456,
"MemorySwap": 1073741824,
"MemorySwappiness": null,
"OomKillDisable": false,
"PidsLimit": null,
"Ulimits": null,
"CpuCount": 0,
"CpuPercent": 0,
"IOMaximumIOps": 0,
"IOMaximumBandwidth": 0,
"Mounts": [
"Type": "bind",
"Source": "/root/zabbix-docker/.MYSQL_USER",
"Target": "/run/secrets/MYSQL_USER",
"ReadOnly": true
"Type": "bind",
"Source": "/root/zabbix-docker/.MYSQL_PASSWORD",
"Target": "/run/secrets/MYSQL_PASSWORD",
"ReadOnly": true
"MaskedPaths": [
"/proc/asound",
"/proc/acpi",
"/proc/kcore",
"/proc/keys",
"/proc/latency_stats",
"/proc/timer_list",
"/proc/timer_stats",
"/proc/sched_debug",
"/proc/scsi",
"/sys/firmware"
"ReadonlyPaths": [
"/proc/bus",
"/proc/fs",
"/proc/irq",
"/proc/sys",
"/proc/sysrq-trigger"
"GraphDriver": {
"Data": {
"LowerDir": "/var/lib/docker/overlay2/c699e3c422fbe1217816937f63d6881160cf7d141952a28163 5c049d169e13f6-init/diff:/var/lib/docker/overlay2/922b86825d1bea8177f890f7d38950e34fdcb1c4e96b97bc94 7aeb4b53c04c5c/diff:/var/lib/docker/overlay2/ec8293b9bee34a18caf645d426fa0477cabe55b96f4e16ed37 6767272e65e18e/diff:/var/lib/docker/overlay2/85f5dcee4295edb7bb451b2cddba0ce66335cfd5169c1a89f5 6d8eaf0efa99b8/diff:/var/lib/docker/overlay2/90876dcfb51f427a0ba0c7f6e28b4be5ed2b2b4c81847d425e 98b6c2ef2774ae/diff:/var/lib/docker/overlay2/f019f9f95eae79fb7ed09b81c780a52eec03f648b1b4fa4db3 4fde8ea169b064/diff:/var/lib/docker/overlay2/d10557902df1681e3e3480020f4e2ddb4ace9b2da8b2b6eb71 3e3d5c9ef2947a/diff",
"MergedDir": "/var/lib/docker/overlay2/c699e3c422fbe1217816937f63d6881160cf7d141952a28163 5c049d169e13f6/merged",
"UpperDir": "/var/lib/docker/overlay2/c699e3c422fbe1217816937f63d6881160cf7d141952a28163 5c049d169e13f6/diff",
"WorkDir": "/var/lib/docker/overlay2/c699e3c422fbe1217816937f63d6881160cf7d141952a28163 5c049d169e13f6/work"
"Name": "overlay2"
"Mounts": [
"Type": "bind",
"Destination": "/run/secrets/MYSQL_USER",
"Mode": "",
"RW": false,
"Propagation": "rprivate"
"Type": "bind",
"Destination": "/run/secrets/MYSQL_PASSWORD",
"Mode": "",
"RW": false,
"Type": "bind",
"Source": "/etc/timezone",
"Destination": "/etc/timezone",
"Mode": "ro",
"RW": false,
"Type": "bind",
"Source": "/root/zabbix-docker/zbx_env/etc/ssl/nginx",
"Destination": "/etc/ssl/nginx",
"Mode": "ro",
"RW": false,
"Type": "bind",
"Source": "/root/zabbix-docker/zbx_env/usr/share/zabbix/modules",
"Destination": "/usr/share/zabbix/modules",
"Mode": "ro",
"RW": false,
"Type": "bind",
"Source": "/etc/localtime",
"Destination": "/etc/localtime",
"Mode": "ro",
"RW": false,
"Config": {
"Hostname": "18613b78b22b",
"Domainname": "",
"User": "1997",
"AttachStdin": false,
"AttachStdout": false,
"AttachStderr": false,
"ExposedPorts": {
"8080/tcp": {},
"8443/tcp": {}
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"MYSQL_USER_FILE=/run/secrets/MYSQL_USER",
"MYSQL_PASSWORD_FILE=/run/secrets/MYSQL_PASSWORD",
"MYSQL_ROOT_PASSWORD_FILE=/run/secrets/MYSQL_ROOT_PASSWORD",
"MYSQL_DATABASE=zabbix",
"ZBX_SERVER_NAME=Composed installation",
"PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"TERM=xterm",
"ZBX_VERSION=5.2.1",
"ZBX_SOURCES=https://git.zabbix.com/scm/zbx/zabbix.git"
"Cmd": null,
"Healthcheck": {
"Test": [
"CMD",
"curl",
"-f",
"http://localhost:8080/"
"Interval": 10000000000,
"Timeout": 5000000000,
"StartPeriod": 30000000000,
"Retries": 3
"Image": "zabbix/zabbix-web-nginx-mysql:alpine-5.2-latest",
"Volumes": {
"/etc/localtime": {},
"/etc/ssl/nginx": {},
"/etc/timezone": {},
"/usr/share/zabbix/modules": {}
"WorkingDir": "/usr/share/zabbix",
"Entrypoint": [
"OnBuild": null,
"Labels": {
"com.docker.compose.config-hash": "5ebdb8c3338bef6fee2d8bb98e59ad7849e4af03e0bec0834 78a4c4080fc677c",
"com.docker.compose.container-number": "1",
"com.docker.compose.oneoff": "False",
"com.docker.compose.project": "zabbix-docker",
"com.docker.compose.project.config_files": "docker-compose_v3_alpine_mysql_latest.yaml",
"com.docker.compose.project.working_dir": "/root/zabbix-docker",
"com.docker.compose.service": "zabbix-web-nginx-mysql",
"com.docker.compose.version": "1.27.4",
"com.zabbix.company": "Zabbix LLC",
"com.zabbix.component": "zabbix-frontend",
"com.zabbix.dbtype": "mysql",
"com.zabbix.description": "Zabbix frontend on Nginx web-server with MySQL database support",
"com.zabbix.os": "alpine",
"com.zabbix.webserver": "nginx",
"org.opencontainers.image.authors": "Alexey Pustovalov <[email protected]>",
"org.opencontainers.image.description": "Zabbix web-interface based on Nginx web server with MySQL database support",
"org.opencontainers.image.documentation": "https://www.zabbix.com/documentation/5.2/manual/installation/containers",
"org.opencontainers.image.licenses": "GPL v2.0",
"org.opencontainers.image.source": "https://git.zabbix.com/scm/zbx/zabbix.git",
"org.opencontainers.image.title": "Zabbix web-interface (Nginx, MySQL)",
"org.opencontainers.image.url": "https://zabbix.com/",
"org.opencontainers.image.vendor": "Zabbix LLC",
"org.opencontainers.image.version": "5.2.1"
"StopSignal": "SIGTERM",
"StopTimeout": 10
"NetworkSettings": {
"Bridge": "",
"SandboxID": "53651ec0d3d703d79571754d358c5feee4a19d8449ca10ca6 dab2ba598095773",
"HairpinMode": false,
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"Ports": {
"8080/tcp": [
"HostIp": "0.0.0.0",
"HostPort": "8081"
"8443/tcp": [
"HostPort": "8443"
"SandboxKey": "/var/run/docker/netns/53651ec0d3d7",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null,
"EndpointID": "",
"Gateway": "",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": "",
"Networks": {
"zabbix-docker_zbx_net_backend": {
"IPAMConfig": null,
"Links": [
"zabbix-docker_mysql-server_1:mysql-server",
"zabbix-docker_mysql-server_1:mysql-server_1",
"zabbix-docker_mysql-server_1:zabbix-docker_mysql-server_1",
"zabbix-docker_zabbix-server_1:zabbix-docker_zabbix-server_1",
"zabbix-docker_zabbix-server_1:zabbix-server",
"zabbix-docker_zabbix-server_1:zabbix-server_1"
"Aliases": [
"zabbix-web-nginx-mysql-alpine",
"zabbix-web-nginx-alpine-mysql",
"18613b78b22b"
"NetworkID": "3b763364d1a8e9348cc56f340696f851235fe795bc052be09 4f70b6b00d68c3c",
"EndpointID": "6738f3cd3fa7a09ef952492194563ac5d2a125e754beeff61 c033ba8bff924bb",
"Gateway": "172.16.239.1",
"IPAddress": "172.16.239.7",
"IPPrefixLen": 24,
"IPv6Gateway": "",
"MacAddress": "02:42:ac:10:ef:07",
"DriverOpts": null
"zabbix-docker_zbx_net_frontend": {
"IPAMConfig": null,
"Links": [
"Aliases": [
"18613b78b22b"
"NetworkID": "80fcddc9306dee63b68b6f498788bc543fb096b443d2ff757 80c85ce597589b7",
"EndpointID": "0d45a7afaabc2a3b541fda8af3ef937a60b5261772c31a3ab 89bd3c9c265dd23",
"Gateway": "172.16.238.1",
"IPAddress": "172.16.238.5",
"IPPrefixLen": 24,
"IPv6Gateway": "",
"MacAddress": "02:42:ac:10:ee:05",
"DriverOpts": null
