Is it possible to have the System Status widget from versions 3 and under on 4.0+?
  • dpeterson
    • Apr 2014
    • 26
    I just updated one of my Zabbix environments to 4.0 from 3.0. The first thing I noticed is I no longer have the system status overview that I had in 3.0. Here is a screenshot of what I am talking about in 3.0 right before the upgrade:
    I tried to replicate this in 4.0 but none of the widgets seems to be working correctly. I am receiving data from all my hosts and nodes, but can't seem to get this system status back on the front page. I tried the problems by severity widget, but I am not seeing any of the triggers I had on the dashboard pre upgrade:
    Click image for larger version  Name:	Zabbix2.PNG Views:	0 Size:	87.6 KB ID:	412996
    Does anyone know how to recreate this widget for versions 4.0+? Any help would be appreciated.
    Thanks!
    • 4996
    Problems by Severity should show you things, if there is any.. it just does not show you 0-s. If it does not show any, that you know, that have to be there... Then problem is somewhere else...
