Zabbix proxy big lag
  • porlock
    • May 2012
    • 13
    I receive a 16000 items values over zabbix trapper every 5 minutes on zabbix proxy, and observe a huge lag betwen zabbix server and zabbix proxy, more than 2 hours .. :-(
    Both machines that is zabbix server and zabbix proxy have a more than 90% of CPU idle, and a lots of ram free, and there is no network lag between them (ping latency aprox 0.107 ms)
    Proxy config:
    ProxyMode=0
    Server=192.168.0.40
    ServerPort=10051
    Hostname=proxy_41
    ListenPort=10051
    SourceIP=192.168.0.41
    LogFile=/var/log/zabbix/zabbix_proxy.log
    LogFileSize=0
    DebugLevel=3
    PidFile=/var/run/zabbix/zabbix_proxy.pid
    DBHost=
    DBName=zabbix
    DBUser=zabbix
    DBPassword=xxxxxxxxxxxxxx
    DBSocket=/var/lib/mysql/mysql.sock
    ProxyLocalBuffer=0
    ProxyOfflineBuffer=24
    ConfigFrequency=60
    DataSenderFrequency=1
    StartPollers=256
    StartTrappers=384
    StartPingers=200
    StartDiscoverers=10
    StartHTTPPollers=0
    SNMPTrapperFile=/opt/snmpprobe/log/share/zabbix.log
    StartSNMPTrapper=1
    HousekeepingFrequency=1
    CacheSize=128M
    StartDBSyncers=40
    HistoryTextCacheSize=64M
    ExternalScripts=/usr/lib/zabbix/externalscripts
    LogSlowQueries=1000
    Server config:
    LogFile=/var/log/zabbix/zabbix_server.log
    LogFileSize=0
    PidFile=/var/run/zabbix/zabbix_server.pid
    DBHost=
    DBName=zabbix
    DBUser=zabbix
    DBPassword=xxxxxxxx
    SNMPTrapperFile=/var/log/snmptt/snmptt.log
    CacheSize=32M
    HistoryCacheSize=64M
    TrendCacheSize=32M
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    Stats from zabbix server and zabbix proxy are fine, utylization is minimal.
    Number of records on zabbix proxy db continually grows, it’s seams that the problem is on zabbix proxy, I caught by tcpdump packet transmitted between zabbix proxy and zabbix server and it have a 2 hours delayed clock field.
    I use:
    Arch : x86_64
    Version : 2.4.4
    Release : 1.el6
    Repo : installed
    From repo : zabbix
    Arch : x86_64
    Version : 2.4.4
    Release : 1.el6
    Repo : installed
    From repo : zabbix
    Installed Packages
    Arch : x86_64
    Version : 9.4.1
    Release : 1PGDG.rhel6
    Repo : installed
    From repo : pgdg94
    I try to recreate zabbix proxy db but it does nothing.
  • ingus.vilnis
    • Mar 2014
    • 908
    Performance tuning may have affect on your issue.
    I assume that you don't have any statistics about performance on your proxy_41. Even though you have host proxy_41 added to frontend, looks like you are monitoring the proxy from server therefore it is displaying the same values for both server and proxy. Check your own Latest data screenshot. All the processes with same names have the same values. The values are from server and not from proxy. Set the proxy_41 host to be monitored by itself - proxy_41.
    How will you know when the proxy is unreachable, you will ask. Create an item on Zabbix server template with key zabbix[proxy,"proxy_41",lastaccess] which will tell when the proxy contacted Zabbix server for the last time. Create a trigger which fires if the time is more than 120 seconds for example. https://www.zabbix.com/documentation...types/internal
    With this done please collect statistics about proxy usage and then report with screenshots of Zabbix proxy performance graphs from proxy template. Based on the graphs we can then try to adjust the proxy config settings.
    How many hosts are you monitoring? Your settings would be suitable for thousands of monitored machines.
    Few notes on the current settings -
    StartPollers=256 - check the graphs to adjust to ~30% usage.
    StartTrappers=384 - check the graphs to adjust to ~30% usage.
    StartPingers=200 - check the graphs to adjust to ~30% usage.
    StartDiscoverers=10 - how many discovery rules do you use? Each rule may be used by 1 discoverer at a time. If you have 1 discovery rule then having 10 discoveres is useless.
    CacheSize=128M - check the graphs to adjust to ~99-90% free. (all of the caches)
    StartDBSyncers=40 - crazy value. Might cause you lots of problems on DB performance. Each DB syncer is capable of processing ~1000 new values per second. Unless you have 40.000 NVPS, set this back to default 4.
    All the same rules apply to Zabbix server configuration as well.
    Good luck with tuning!
    Best Regards,
    Ingus
