I am trying to upgrade to 2.4.4 from 2.0.2. I have a script which runs as a cron on my zabbix server host. This worked fine on 2.0.2. But I have facing issues on 2.4.4
Here is the script:
Output on 2.0.2:
Output on 2.4.4:
I believe the issue lies within the syntax of my zabbix_sender command in the script. Any help would be greatly appreciated!
Here is the script:
#!/bin/bash
## Named config passed in on the command line.
config_name=$1
## read in global shell variables.
. /home/zabbix/zabbix/conf/zabbix_script_global_variables.cfg
## Assemble the reference to the sql config file.
sqlsrv="--defaults-extra-file=${sql_cfg_home_dir}/${config_name}.cfg"
## call the stored procedure and send output to the zabbix host.
mopts="$sqlsrv -N"
/usr/local/mysql/bin/mysql $mopts << __EOF__ | gawk -v confname=${config_name} '{ print confname " "$0 ; }'| /usr/bin/zabbix_sender -v -v -z ${zabbix_host} -i -
show global status
where Variable_name not in
( "COMPRESSION" , "INNODB_HAVE_ATOMIC_BUILTINS" , "RPL_STATUS" , "SLAVE_RUNNING" , "SSL_SESSION_CACHE_MODE" ,
"SSL_VERSION" , "SSL_CIPHER" , "SSL_CIPHER_LIST" )
__EOF__
zabbix_sender [7138]: Warning: [line 14] 'Key value' required
zabbix_sender [7139]: DEBUG: answer [{
"response":"success",
"info":"Processed 187 Failed 63 Total 250 Seconds spent 0.001199"}]
info from server: "Processed 187 Failed 63 Total 250 Seconds spent 0.001199"
zabbix_sender [7140]: DEBUG: answer [{
"info":"Processed 91 Failed 63 Total 154 Seconds spent 0.000763"}]
info from server: "Processed 91 Failed 63 Total 154 Seconds spent 0.000763"
sent: 404; skipped: 1; total: 405
zabbix_sender [5090]: Warning: [line 14] 'Key value' required Sending failed.
