Zabbix missing new templates after upgrade
  • Coma
    • Oct 2016
    • 36
    I upgraded our zabbix 4.4 to 5.2 by creating a new zabbix install and then exporter the mysql. But how do I add the new templates that zabbix 5.2 should come with? Is there an easy way too add these?
  • Hamardaban
    • May 2019
    • 2714
    https://www.zabbix.com/documentation...out_of_the_box
    • If you are upgrading from previous versions, you can find these templates in the templates directory of the downloaded latest Zabbix version. While in Configuration → Templates you can import them manually from this directory.
    • It is also possible to download the template from Zabbix git repository directly (make sure the template is compatible with your Zabbix version).
    • Coma
      • Oct 2016
      • 36
      a big Thanks! but is there no way to just add everything, without you having to add one at a time? some of the templates has other templates they are linked to and so on. ?
      • Coma
        • Oct 2016
        • 36
        First i try to import: "Cisco UCS SNMP" but get
        • Cannot import template "Cisco UCS SNMP", linked template "Generic SNMP" does not exist.
        so i try to import "Generic SNMP" and then get
        • Cannot import template "Network Generic Device SNMP", linked templates "EtherLike-MIB SNMP, Generic SNMP, Interfaces Simple SNMP" do not exist.
        there has to be a simpler way to import all the new templates? than going through them all one by one?
        • dave08
          • Jan 2020
          • 29
          Hi! I'm having the same problem, wondering why the previous cisco ucs snmpv2 stopped getting all the data.
          Were you able to find a simpler way than import the templates individually?
          Thanks and regards.
