Problem closes without recovery expression fulfilment
  • dirai19
    • Jul 2019
    Hi.
    There is item, for example "item1"
    Type: int
    History store period: 90d
    And there is trigger for this item.
    Problem expression:
    {host:item1.change()}<0
    Recovery expression:
    ({host:item1.max(7884000)} - {host:item1.last()}) = 0
    Recovery expression logic: recovery happens if last item value = max value for 3 months period
    But strange behavior occurs when problem closes with recovery expression still being False
    Have anyone got something similar?
    Any suggestions what can it be?
  • tim.mooney
    • Dec 2012
    • 1436
    Review the section of the manual on recovery expressions, https://www.zabbix.com/documentation...iggers/trigger
    In particular:
    Recovery expression Logical expression (optional) defining additional conditions that have to be met before the problem is resolved, after the original problem expression has already been evaluated as FALSE.
    Recovery expression is useful for trigger hysteresis. It is not possible to resolve a problem by recovery expression alone if the problem expression is still TRUE.
    This field is only available if 'Recovery expression' is selected for OK event generation.
    Supported since Zabbix 3.2.0.
    Note the words I've emphasized.
    • dirai19
      • Jul 2019
      Thanks for answer.
      I've read docs, expressions work as expected.
      I've got advice to check if Zabbix value cache is fully used. And it is.
      Now this is my main version why problem occured
        • 4990
        IIRC, if there is not enough historic data in cache, then it should do db query each time to obtain additional needed data and you should see that as "cache misses"... More you have those cache misses, slower your trigger calculation gets...
        https://www.zabbix.com/documentation...ms/value_cache
