LDAP for multiple domais
  • kuchenIT
    • Nov 2020
    Hi everyone,
    We have a Zabbix server for many years now. Since we are growing we need to enable LDAP access for all domains.
    Currently we are only able to enable users form one domain (in my case <company>.de) to login on zabbix.
    We have some other domains in our Forest as well like <company>.com, <company>.at
    now my question is how does I need to setup the Zabbix Base DN to use all of our domains.
    on other system we just don't give any baseDN so it searches in all domains, but Zabbix needs one.
    LDAP already checks the Global Catalog
    any guesses how to set it up?
    Regards
    Alex
  • Hamardaban
    • May 2019
    • 2714
    As far as I understand you have a forest of domains united by trust relationships?
    Then you need to specify a group from the one domain (any from yours forest) as BaseDN.
    And include AD users from other domains in it.
    Zabbix server should be able to access this AD group and get a list of users using the BindDN account.
    • kuchenIT
      • Nov 2020
      yes, we have a Forest with a bunch of Domains, so i have to create a group in my AD and add users to this group in order to give them access?
      I Will try it.
      • kuchenIT
        • Nov 2020
        I test with an Additional AD group.
        Sadly, with no luck. As soon as I set the group as BaseDN the login test results in "Login name or password wrong".
        I also tested to not specify the group CN, and specify the OU above instead, this also didn't help.
        • Hamardaban
          • May 2019
          • 2714
          To find out how to correctly write BindDN, run the command in the command line on the domain controller: dsquery user -name outerdomsinusername
          You may use GlobalCatalog and port 3268 ( dsquery server –isgc show GC location) and User principal name like blabla@<company>.com
          Also check the availability of the domain controller on port 3268 from the Zabbix server.
          https://www.zabbix.com/forum/zabbix-...tiple-base-dns
          https://www.zabbix.com/forum/zabbix-...ltiple-domains
          https://discourse.igniterealtime.org...ectory/48875/3
          • kuchenIT
            • Nov 2020
            thanks, but I already read through this posts, but it either only work with different subdomains what we don't have.
            the port 3268 works, because we use them already.
            but as soon I what to use the group not working again i also tried (&(sAMAccount)(memberOf=CN=path,OU=to,OU=group,DC= company,DC=com))
            only getting errors, I guess the best way there give the possabilty to select more than one domain
