Optimal DB configuration (MySQL)
  • authex
    • Jan 2014
    • 32
    Hi there,
    I was wondering if anyone could lend any help; I'm running the following setup:
    Ubuntu 14.04.2 LTS
    Zabbix Server Version 2.2.9
    MySQL Version 14.14
    My environment was running perfectly fine; but then we got spikes on "Zabbix unreachable poller processes more than 75% busy"
    Ever since then, we are unable to get information about 3 servers (Ping) graphs; therefore, showing offline in Zabbix.
    As far as the number of hosts; we only have 25 clients, running approx 70 values per second.
    Please review my.cnf below:
    [client]
    port            = 3306
    socket          = /var/run/mysqld/mysqld.sock
    [mysqld_safe]
    nice            = 0
    [mysqld]
    user            = mysql
    pid-file        = /var/run/mysqld/mysqld.pid
    port            = 3306
    basedir         = /usr
    datadir         = /var/lib/mysql
    tmpdir          = /tmp
    lc-messages-dir = /usr/share/mysql
    skip-external-locking
    bind-address            = 127.0.0.1
    key_buffer              = 16M
    max_allowed_packet      = 16M
    thread_stack            = 192K
    thread_cache_size       = 8
    myisam-recover         = BACKUP
    max_connections        = 500
    query_cache_limit       = 100M
    query_cache_size        = 100M
    log_error = /var/log/mysql/error.log
    expire_logs_days        = 10
    max_binlog_size         = 100M
    [mysqldump]
    quick
    quote-names
    [mysql]
    #no-auto-rehash
    [isamchk]
    key_buffer              = 16M
    !includedir /etc/mysql/conf.d/
  • kloczek
    • Jun 2006
    • 1771
    Because probably you are still using passive items (not "Zabbix agent (active)" type).
    I've not been using MyISAM very long time and IIRC this engine does not support foreign keys which are used by zabbix schema.
    If I'm right and if you been doing some delete operations on hosts or templates you may hove already some garbage on DB.
    $ grep -c "FOREIGN KEY" schema.sql
    134
    Most of FKs are on delete cascade.
