Zabbix calculated item on failed step scenario not working
  • leoonardoo
    • Sep 2017
    I'm trying to setup a calculated item based on "Failed step of scenario". So I tried:
    last("web.test.error[MyScenario]")
    But it didn't work, the error message is:
    Cannot evaluate expression: "Cannot evaluate function "last()": not enough data.".
    While on the same scenario the "in" works with no problems:
    last("web.test.in[MyScenario,,bps]")
    Why? How can I translate a problem in the web scenario to a very simple 0(down)/1(up) calculated item???
  • leoonardoo
    • Sep 2017
    YES! I was using the wrong item, I meant to use "web.test.fail" not web.test.error !!!
    Thank you!
      • 4996
      Ehh.. again .. documentation, documentation, documentation..
      https://www.zabbix.com/documentation...nitoring/items
      Last error message of scenario <Scenario> This item returns the last error message text of the scenario. A new value is stored only if the scenario has a failed step. If all steps are ok, no new value is collected.
      Item key: web.test.error[Scenario]
      Type: Character
      If your scenario has not had any errors, you don't have any data to evaluate, exactly as error says. And for creating a trigger, this item is pretty useless. You should use web.test.fail[Scenario]<>0
