Triggers for LLD with json
  • apg
    • Nov 2020
    I have problem with incorrect trigger
    We have json, say ,
    {"data":[{"name":"N1","check":true,"connect":true,"stream": true}]}
    and I parse and make item prototype . All is OK with it. But I'd like, that I see trigger for stream , when it is false only when check is true. What I have: if I write trigger
    stream.last()=false and check.last()=false
    I see problem , which immediately closed and I can see, that problem duration was 0.
    The same is placed, when I make trigger separate trigger
    check.last()=false
    and make stream.last()=false dependent on check.last()
    What's wrong?
  • apg
    • Nov 2020
    One more addition. What I see in the message about alert:
    Problem: Stream state for N1
    Problem started at 00:02:01 on 2020.11.27
    Problem name: Stream state for N1
    Host: nnn
    Severity: Disaster
    Operational data: true
    Original problem ID: 76123587
    at the same time previous message
    Problem started at 06:18:01 on 2020.11.27
    Host: nnn
    Severity: Disaster
    Operational data: false
    Original problem ID: 76176693
    • apg
      • Nov 2020
      Thank you for reply. For me it's a bug. Do you know, may be there is a discussion, like ZBX..... already opened for this problem?
        • 4996
        Trigger recalculation appears every time one of the items receives new value. Even if you get values to both of those items from same json, there is still a minuscule gap between them due to processing. One item gets new value, recalculate and problem appears, second gets new value, new recalculate, problem closes.. duration 0.
        I have experienced similar situation with 2 logfile items (logrt.count() ) used in one trigger. Even if in "latest data" it all looks like a same second, in DB it has difference in 0.0000x part of a second... and it was enough to trigger false alarm.
          • 4996
          Don't know, I have not searched for bugreport.
