Extend Zabbix 5.2 appliance Hyper-V 2012
  • Obaida Khazem
    • Dec 2020
    Hello ,
    I success to extend the disk using parted command :
    [root@appliance ~]# parted
    GNU Parted 3.2
    Using /dev/sda
    Welcome to GNU Parted! Type 'help' to view a list of commands.
    (parted) print
    Model: Msft Virtual Disk (scsi)
    Disk /dev/sda: 64.4GB
    Sector size (logical/physical): 512B/512B
    Partition Table: msdos
    Disk Flags:
    Number Start End Size Type File system Flags
    1 1049kB 538MB 537MB primary ext4 boot
    2 538MB 4833MB 4295MB primary xfs
    3 4833MB 5907MB 1074MB primary xfs
    4 5907MB 60.0GB 54.1GB extended
    5 5908MB 60.0GB 54.1GB logical xfs
    but when i check the disk size using df -h command i still see the /var/lib/mysql 4.5G
    [root@appliance ~]# df -h
    Filesystem Size Used Avail Use% Mounted on
    devtmpfs 1.9G 0 1.9G 0% /dev
    tmpfs 2.0G 0 2.0G 0% /dev/shm
    tmpfs 2.0G 17M 1.9G 1% /run
    tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
    /dev/sda2 4.0G 980M 3.1G 24% /
    /dev/sda1 488M 80M 373M 18% /boot
    /dev/sda3 1014M 40M 975M 4% /tmp
    tmpfs 392M 0 392M 0% /run/user/0
    /dev/sda5 4.5G 706M 3.8G 16% /var/lib/mysql
    please help me how to extend the /var/lib/mysql
  • provels
    • Apr 2020
    • 93
    If I understand correctly, you have increased the size of the virtual disk but the file system doesn't recognize it. If so, that happened to me as well. After extending the VHD, you need to attach the new space to the existing file system.
    Take a look at this thread, around post #10. Hope it helps. Database Error - Error connecting to database: No such file or directory - ZABBIX Forums
    • Obaida Khazem
      Obaida Khazem commented
      thank you for your replay , I tried the solution she voted for but unfortunately did not work in version 5.2 .
      I fix my appliance v4.4 before from the same post you have write .
  • tim.mooney
    • Dec 2012
    • 1436
    Someone else had a similar problem with the latest VM, and I responded with the exact same links that provels did. Unfortunately, those links now appear to be outdated, because the latest appliance VM is no longer using LVM. See: https://www.zabbix.com/forum/zabbix-...ing-login-page
    Since you've already successfully resized the partition, the last step is to resize the filesystem on top of the partition. Since you've indicated that /var/lib/mysql is an 'xfs' filesystem, you probably want:
    xfs_growfs /dev/sda5
    • Obaida Khazem
      Thank you very much, you helped me a lot and that is was the solution
  • Obaida Khazem
    • Dec 2020
    1- Extend the disk on hyper-v .
    2- extend the disk using parted command :
    # parted
    # resizepart " will ask you to choose disk
    3- Check if you success to resized the partition :
    # parted
    # print
    4- the last step is to resize the filesystem on top of the partition :
    # xfs_growfs /dev/sda5
    • pgp82
      • Nov 2020
      • 23
      # parted
      # parted
      # print
      Hi Obaida Khazem Which disk did you select when doing resizepart? I'm in the same boat as you. I have done parted on sda5 where mysql is. However when I do the xfs_growsfs it did not grow the mysql partition.
      • Obaida Khazem
        • Dec 2020
        HI , let me see the disk partition you have :
        run the command df -h and send the result also run parted then print and send the result .
        • pgp82
          • Nov 2020
          • 23
          hi Obaida Khazem here is my df -h and parted outputs.
          devtmpfs 3.9G 0 3.9G 0% /dev
          tmpfs 3.9G 0 3.9G 0% /dev/shm
          tmpfs 3.9G 8.5M 3.9G 1% /run
          tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
          /dev/sda2 4.0G 1000M 3.1G 25% /
          /dev/sda5 4.5G 4.5G 20K 100% /var/lib/mysql
          tmpfs 787M 0 787M 0% /run/user/0
          GNU Parted 3.2
          Using /dev/sda
          (parted) print
          Disk /dev/sda: 32.2GB
          Disk Flags:
          4 5907MB 10.7GB 4831MB extended
          5 5908MB 10.7GB 4830MB logical xfs
          • pgp82
            • Nov 2020
            • 23
            hi Obaida Khazem just wondering if you had time to take a look at above?
            • Obaida Khazem
              • Dec 2020
              Hi ,
              sorry for the late respond .
              First think you need to do is to extend the extended partition /dev/sda5 , i extended him used gparted-live-1.0.0-3-i686.iso
              1- start the Hyper-v VM with the disk boot .
              2- right click on mouse on /dev/sda4 : >> choose Resize/Move "see pic 1 "
              3- on the Resize/Move : Move the arrow to the end of the right side " see pic 2" , after that save the configration on the green V icon on the top , restart your server and then do this commands :
              4-
              # parted
              # resizepart " will ask you to choose disk " your disk is 5 "
              5-
              thank you ,
              • pgp82
                • Nov 2020
                • 23
                Hi ,
                4-
                # parted
                5-
                thank you ,
                Hi Obaida Khazem Thank you for your reply and I did exactly what you have suggested. But my sda5 still shows 100%. See below.
                GNU Parted 3.2
                Using /dev/sda
                (parted) print
                Disk Flags:
                4 5907MB 32.2GB 26.3GB extended
                (parted)
                /dev/sda2 4.0G 995M 3.1G 25% /
                Any idea what is going on here?
                • pgp82
                  • Nov 2020
                  • 23
                  GNU Parted 3.2
                  Using /dev/sda
                  (parted) print
                  Disk Flags:
                  (parted)
                  hi Obaida Khazem all ok now. I ended up using gparted live and extended sda5 as well. Now it's showing the correct disk usage.
                  • tothk
                    • Aug 2022
                    hello,
                    i just resized the particion with cfdisk Click image for larger version
                    but zabbix still have the old disksize
                    can anybody help me with this problem ?
