Zabbix Agent 2 Oracle monitoring
  • nioh
    • Dec 2020
    • 15
    Hi!
    I have configured Zabbix Agent 2 for Oracle monitoring.
    It works ok with default items. However when i configure custom querys the result value is always a string, and contains the result heading, not only the value.
    Is this something that i can change in the configuration?
    I attchaed an image of an example of the value i get from the custom query.
    I would like to get a Numeric or Float value, not a text string
    Seems like this custom query functionality is quite useless if all i get back is a string.
    Thanks!
  • lbjensen
    • Apr 2013
    • 16
    Hi
    You could put in
    set heading off
    set feedback off
    in your script for onlu returning the result
    You could also do preprocessing after the item is in Zabbix with the regex
    I have a question for you.
    How dod you configure the plugin for Oracle?
    I have a database server and the zabbix-agent2 running, but I get 0 values and only the error
    "Connection failed: ORA-00000: DPI-1047: Cannot locate a 64-bit Oracle Client library: "libclntsh.so: cannot open shared object file"
    Cheers
    Lars
    • nioh
      • Dec 2020
      • 15
      Originally posted by cyber
      oracle.custom.query items? But it is returning json, so your results are normal
      oracle.custom.query[<connString>,<user>,<password>,<service>, queryName, <args…>]
      Result of a custom query. JSON object
      Oooh i see. Obivously its json, heh.
      How would i go ahead to convert it into a single digit? Zabbix triggers dont really like strings
      • nioh
        • Dec 2020
        • 15
        Originally posted by lbjensen
        Hi
        You could put in
        set heading off
        set feedback off
        Cheers
        Lars
        Do you have oracle instantclient installed on your zabbix server?
        • nioh
          • Dec 2020
          • 15
          Preprocessing....JSONpath etc...
          I see, thanks! Will do some reading about it.
          Or do you have an example as well on how to solve my example in image above?
          • Pfeifer8714
            • Dec 2020
            Thanks for the information keep sharing and helping people PrepaidCardStatus
            • djbelotto
              • Mar 2021
              Hello dears,
              I tried to configure the LD_LIBRARY in every files as: /etc/bashrc /home/zabbix/.bash_profile /etc/sysconfig/zabbix-server ... etc.. and zabbix could not load this libclntsh lib...
              I am using CENTOS 8 and ZABBIX 5.4
              Could someone help me, please?
              Or could someone recommend me an other plugin to oracle monitoring..?
              • olivierm
                • Mar 2021
                good pm,
                i have the exact same problem.
                dont understand. the lib is there and i put all oracle ENV.
                it's like the zabbix agent doesn't care about ENV.
                Did someone solve the problem ? (centos 8 and zabbix 5.4)
                • olivierm
                  • Mar 2021
                  it's resolve by using only IP adress in agent config file (/etc/zabbix/) instead of FQDN. dont know why
                  And/Or adding file /etc/sysconfig/zabbix-agent2 with
                  ORACLE_HOME=/opt/oracle/product/18c/dbhomeXE
                  ORACLE_SID=XE
                  LD_LIBRARY_PATH=/opt/oracle/product/18c/dbhomeXE/lib
                  PATH="/bin:/opt/oracle/product/18c/dbhomeXE/bin:/opt/oracle/product/18c/dbhomeXE/lib"
                  export ORACLE_HOME
                  export LD_LIBRARY_PATH
                  export ORACLE_SID
                  export PATH
                    • 4996
                      • 4996
                      • adoang
                        • Sep 2021
                        I am facing issue when load asm. zabbix_server (Zabbix) 5.0.15. Please advise
                        Cannot create item: item with the same key "oracle.asm_free_size["{#DG_NAME}"]" already exists.
                        • lptarik
                          lptarik commented
                          Change the DB_NAME to DBNAME , you will get asm but i still don't get data for items
