Zabbix configuration for AD LDAP authentication not working
  • cjbidwell
    • Dec 2019
    • 16
    Hi all,
    I've been troubleshooting this for a long time trying to figure out why it's not working. I'm using RHEL8 with selinux enabled. I've set the associated setsebool parameters for zabbix. I don't get any errors relating to selinux. I've disabled it temporarily and retested and it still gives the same error.
    I've imported my active directory certificate and put into /etc/openldap/certs. Here is my ldap.conf:
    TLS_CACERTDIR /etc/openldap/certs
    TLS_REQCERT allow
    # Turning this off breaks GSSAPI used with krb5 when rdns = false
    SASL_NOCANON on
    Can anyone help me further troubleshoot this?
    What's interesting is that on my previous RHEL7 installation, it worked. ...and I thought I setup everything else exactly how
    I did on the RHEL7 instance. But I can't, for the life of me, figure out why this isn't working.
    Thanks!
  • Hamardaban
    • May 2019
    • 2714
    I think you have a strange specified BaseDN
    Bind DN LDAP account for binding and searching over the LDAP server, examples:
    uid=ldap_search,ou=system (for OpenLDAP),
    CN=ldap_search,OU=user_group,DC=company,DC=com (for Microsoft Active Directory)
    Anonymous binding is also supported.
    • cjbidwell
      • Dec 2019
      • 16
      I don't believe it's that. Do you mean not having CN in my search? It's set the exact same way it was on my RHEL7 which did work.
      • Hamardaban
        • May 2019
        • 2714
        Make sure that you have all the necessary packages installed. Look in the web server logs - are there any php errors?
