Problem with zabbix_agentd 3.0.31 on Debian 9
  • Celso Annes
    • Dec 2020
    • 15
    I was using zabbix_agentd 3.0.28 after updating to zabbix_agentd 3.0.31 i find out some triggers stoped working.
    I saw that some changes occurred:
    Was...
    /etc/zabbix/zabbix_agentd.d
    Now
    /etc/zabbix/zabbix_agentd.conf.d/
    the logs have changed as well:
    Was:
    /var/log/zabbix/zabbix_agentd.log
    Now:
    /var/log/zabbix-agent/zabbix_agentd.log
    My zabbix_agentd.conf was:
    PidFile=/var/run/zabbix/zabbix_agentd.pid
    LogFile=/var/log/zabbix/zabbix_agentd.log
    LogFileSize=100
    EnableRemoteCommands=1
    LogRemoteCommands=1
    Server=100.220.254.1
    AllowRoot=1
    Include=/etc/zabbix/zabbix_agentd.d/
    I had to update to match the new configuration of the folders:
    LogFile=/var/log/zabbix-agent/zabbix_agentd.log
    LogFileSize=100
    LogRemoteCommands=1
    AllowRoot=1
    Include=/etc/zabbix/zabbix_agentd.conf.d/*.conf
    I have agents running on both versions, 3.0.28 and 3.0.31, the ones that are running on version 3.0.31 some triggers are not working properly.
    Here is one that is not working on version 3.0.31 but works fine on 3.0.28.
    {viabat:system.run[/sbin/iptables-save | grep "INPUT DROP" | wc -l].last()}=0 or {viabat:proc.num[,,,fail2ban\-server].last()}=0 or {viabat:system.run[/sbin/iptables-save | grep -i "f2b-ASTERISK" | wc -l].last()}=0 or {viabat:system.run[/sbin/iptables-save | grep -i "f2b-ssh" | wc -l].last()}=0
    Looking into zabbix_agentd.log i see that the commands are being running but the return change according to the version:
    21881:20201202:120144.809 EXECUTE_STR() command:'/sbin/iptables-save | grep "INPUT DROP" | wc -l' len:1 cmd_result:'[COLOR=#27ae60][B]1[/B][/COLOR]'
    21881:20201202:120144.809 Sending back [[COLOR=#16a085][B]1[/B][/COLOR]]
    On version 3.0.28 is returning 1 (ONE).
    18670:20201202:120059.957 EXECUTE_STR() command:'/sbin/iptables-save | grep "INPUT DROP" | wc -l' len:1 cmd_result:'[COLOR=#c0392b][B]0[/B][/COLOR]'
    18670:20201202:120059.957 Sending back [[COLOR=#c0392b][B]0[/B][/COLOR]]
    On version 3.0.31 is returning 0 (ZERO).
    If i run the commands directly on terminal, I have the followed return:
    # /sbin/iptables-save | grep "INPUT DROP" | wc -l
    1
    # /sbin/iptables-save | grep -i "f2b-ASTERISK" | wc -l
    3
    # /sbin/iptables-save | grep -i "f2b-ssh" | wc -l
    3
    Based on the return of the commands on the terminal, that are greater than zero, the Zabbix should not up an alert, but its upping an alert like the result is like zero.
    I have no idea why it is returning zero.
    Anyone know what is happening, what can be done to solve this problem?
    Thanks.
  • Celso Annes
    • Dec 2020
    • 15
    I managed to solve it!
    The problem is that the newer version zabbix_agentd 3.0.31 no longer runs as a root user, now when installed or updated it runs with the zabbix user, so it cannot run commands that need privileged permissions.
    I solved the problem with this official documentation: https://www.zabbix.com/documentation..._agent_as_root
