Zabbix 5.x after upgrade Login to frontend is always guest
  • iand999
    • May 2020
    my configid=1 and session_key is already a hex string; however logging in as Admin still has guest privs
    • raoel
      • Dec 2020
      • 9
      #17
      I guess so, Ian, because your problem seems different
      • FrankB
        • Feb 2009
        • 19
        #18
        Hi raoel,
        in the working zabbix 5.06 Installation configid is 100100000000001 and it's a Big Int.
        This is empty after upgrading to 5.2.2 ?
        >>Looks like it's related to "session_key". I changed it from empty into a 32-hexadecimal string in the table "config" on the SQL-server and now I can log in ....
        I dont' know what this means - where do you change it ? I have no session_key field in config (5.0.6)
        I have to provision a snapshot of my first upgrade to 5.2 to look into it - had no time for this the last weeks.
        We have an old Dataset since 2.x, too.
        Regards
        Frank
        • TheTuxKeeper
          • Jan 2011
          I tracked down the bug and created https://support.zabbix.com/browse/ZBX-18894.
          Thanks for all your debugging. It still took some time, but the several hints lead the way to where the bug really was.
          Setting the session_key column in the config table fixes the issue. The update statement in the frontend code has the "configid = 1" condition. https://github.com/zabbix/zabbix/blo...elper.php#L120
          Regards
          Daniel
          • raoel
            • Dec 2020
            • 9
            #20
            FrankB I changed it directly in the database.
            It's a new field in 5.2.x and it needs to be filled to work.
            TheTuxKeeper thanks for creating an issue! I was a bit too busy to do it myself right now.
            • Nemesiz
              • Aug 2021
              I jumped in this problem (always guest login) after upgrade to 5.4 Did not had time to search for the problem until now.
              I use NGINX and PHP-FPM.
              Sending login form to index.php it will replay only with redirect. NO COOKIE!!!
              From https://www.php.net/manual/en/functi...-handler-notes chicken and egg problem. I added session_write_close() before redirect in index.php
              PHP Code:
              // login via form
              if (hasRequest('enter') && CWebUser::login(getRequest('name', ZBX_GUEST_USER), getRequest('password', ''))) {
              CSessionHelper::set('sessionid', CWebUser::$data['sessionid']);
              if (
              CWebUser::$data['autologin'] != $autologin) {
              API::User()->update([
              'userid' => CWebUser::$data['userid'],
              'autologin' => $autologin
              session_write_close(); // chicken and egg problem
              $redirect = array_filter([CWebUser::isGuest() ? '' : $request, CWebUser::$data['url'], CMenuHelper::getFirstUrl()]);
              redirect(reset($redirect));
              Now the problem is gone for me.
